DeWManche
Everything posted by DeWManche
  1. Wait, it depends on the year. I have a 92 MJ and have to custom wire in my quarts clock because I have no plug.
  2. Wa state, Bellingham. 1989 Jeep Comanche 240,000 k miles4.0 L Straight 65-Spd Manual4wdLong Bed https://bellingham.craigslist.org/cto/d/bellingham-1989-jeep-comanche-4x4/6821546332.html
  3. Super exited to see how this build goes!! keep up the good work.
  4. Yeah fully manual no electronics. And for the mounts i used 1inch square stock for most of the mounts but the front right corner of driver and left front corner of passenger mounts are angle stock welded up to the trans tunnel.
  5. I do not sorry 😩
  6. This would be so sweet! Ive been planing on starting a custom MJ camper build around July. But would love to watch you do it first, theres very little info/help I can find on a project like this. This crappy photo shopped pic of my rig is kinda my idea.
  7. Hell yeah i think I might too!!
  8. Yeah the came out of a 2 door so they tip. But they also adjust up and down witch is sweet!
  9. Hey Bob!! I fabbed up some new ones, the bench mounts where way to tall and wouldn’t allow the seats to adjust up and down.
  10. The seals came out of a ZJ (93-98) I had to trim them a bit but fit fine otherwise.
  11. Supper cool, would love to do a diesel swap. I’ve herd of guys doing 1.9 TDis but that just seems to small. Excited to see how this goes for you.
  12. How hard is it to adjust toe on this setup? I’ve been wanting to do this but I’m worried on how it will affect my alignment.
  13. This is a great idea, I think I’ll probably do it. Did you do anything on the rear?
  14. Wow this is sweet!! I think I need those pedals, where’d you find them?
  15. Also installed Grand Cherokee front door seals while I had the trim out, much thicker and adds some extra sound deadening for road noise. Still planing on doing some sort of center console with cup holders, switch panel, and extra gauges. But that can wait, I’m happy with what I got so far.
  16. The vinyl is so hard to get in and seated nicely. Honestly probably took me three hours.
  17. Got tired of Dailing my loud, stinky, and uncomfortable rig every day. So I took so time and money to spruce it up a bit. -Welded custom floor mounts for my new early 2000s 3 series BMW seats that I got cheep from a junk yard. -Cleaned up all the surface rust on the floorboards and painted. - lay down some knock off Dinamat (everywhere) floor, doors, roof, -All New speakers -Installed new JC Whitney vinyl floor -Also did headliner but no before pics It so much nicer! No Cadillac but wife will actually ride in it now.
  18. I’m in Washington state 98229
  19. Truck has 4.0 HO, 5 speed, 4X4, long bed, on 31s Currently has Dana 35 rear end. Picked up this 1992 Comanche around October 2017 for dirt cheap. It had a bad clunk, the seller thought it was the T-case. Towed it home and found it was just a broken motor mount causing the engine, trans and t-case to lean wich allowed the front drive shaft U-joint to smack the subframe. Some what easy fix and it’s been my daily ever since.
  20. Is any body still talking about this? I have the exact same plan as the OP and will be starting my custom pop top camper build in June or July of 2019.
