Wounded_Fighter
2
Everything posted by Wounded_Fighter
Frame repair measurment
Wounded_Fighter replied to moparcyco's topic in MJ Tech: Modification and Repairs
Sounds like a future bed/frame for sale... -
What Have You Towed With Your Comanche?
Wounded_Fighter replied to Goose's topic in MJ Tech: Modification and Repairs
You talking about renting a box truck just to tow it? Edit, I don't see why it would be a horrible idea with someone riding brakes in the other truck... its got possibly 8x the stopping power the comanche has lol -
Uhaul said they have nothing to tow it -
Once I have mine repaired.. I may attempt a long dangerous tow to recover my dodge3500 from my folks place. 130miles with roughly 8klb behind. Only spot I'm iffy on... is the one bridge I'll have to cross. Jacksonville's buckman bridge, Southside i295 west from i95. But that still seems safer than the curves I'd have to navigate if I took i95 north to my exit. Lol -
Wiring harness question
Wounded_Fighter replied to Aidenmoreno3's topic in MJ Tech: Modification and Repairs
Assuming you already have the 95 harness in the cab too... The harness from the 95 might already have the plugs in the locations for the p/s p/w near the doors. All you may have to do is run the wire in the door and plug n play, maybe add a fuse at the absolute minimum. -
I left it on, I figured by the time it actually rusts out I'll throw a turbo at it too. don't remember actual time frame, but I want to so 5-10m idle I could still grab the header. (Had to tighten something up so I had to test it lol)
- 18 replies
- headerwrapping
- heat soak
(and 1 more)
Tagged with:
Pacesetter headers actually states it voids warranty on headers if you wrap them. (Found out after the fact)
- 18 replies
- headerwrapping
- heat soak
(and 1 more)
Tagged with:
Timing cover
Wounded_Fighter replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
Anyone else have any thoughts? -
Timing cover
I mean everything except that part... hench the thread. Lol -
Timing cover
I already put everything back on 2weeks ago. Haha. Trying to feel for its necessity -
Timing cover
Yeah... I double checked.. both kits (timing chain and gasket kits) I got didnt come with that bumper/cushion... Took off to do timing. Never did since I owned it over a year decided its time. -
Belt noise--Harmonic Balancer (with pics)
Wounded_Fighter replied to coolwind57's topic in MJ Tech: Modification and Repairs
Now that was fun to figure out... thought I was gonna break the cover getting it out!! -
Timing cover
That is the old one... I don't recall a new one in the set so.... if this is like vital, i have to dig again. (Facepalm) -
Simple as f---. Done it twice on mine now, once to replace and once to do timing set. Might want to check timing chain while your that deep -
Theoretically speaking... what's the worst that could happen if you forget to put the guide in on the side of the cover...? (With a new timing set)
Wiring harness
Yeeesss pics! I'm using an amazon relay box -
Wiring harness
Been trying to the last week so far. Just checking for "fit" -
Wiring harness
Nothing is wrong with my current one, but if I can get my hands on a match I have an experiment I want to try. I always wanted to try out shortening the amount of wires in the bay. My idea is to move all the relays over to the corner next to the airbox. I think it would make the engine bay "cleaner" without the number of wire looms that run across the firewall and in front of the header panel as well. I'm aware of a few that need to stay over on that side but it should make a lot less wire mess. It would be even more beneficial with the battery relocate mod -
What year harnesses are the same to the 88 for engine bay. Mj/xj 87-89? Is there any major difference
Rear white back up lights wiring ?
Wounded_Fighter replied to AMC86Kid's topic in MJ Tech: Modification and Repairs
If it's an automatic that might be the neutral safety switch? Not sure if our jeeps had those, no real experience with the autos -
Shht happens
Shht happens
So. "The truth is in the pudding" right? Nothing is welded in yet. Everything is only dry fitted so far. I have a coworker who use to work at a body shop going to come take a look at the vehicle before I weld it together, give me some piece of mind in making sure I have them in the right spots. That said.. yall are probably right, it might need a little frame time. Frame thoughts aside. What do you think so far? This seems to be the only problem. Hood, and pass corner ( where the radiator support meets the front fender inner structure) though both of these came from the donor, and "should" be straight. Everything else lines up. -
Bumper and misc
Wounded_Fighter posted a topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
https://www.facebook.com/groups/341484192538182/permalink/3449015735118330/?sale_post_id=3449015735118330 Post says location is Texas Looks great, wanted, but too far for me. -
Rear main seal damage.....
No leak with it missing?
