Everything posted by Warren99
I'm assuming the gas tank would be worth holding onto
Ah ok, I might just use one from a ford or whatever like scout said. And I'll be sure to hold onto it then
https://www.ebay.com/itm/115426077520?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=115426077520&targetid=1645685073528&device=c&mktype=&googleloc=9010892&poi=&campaignid=16730423415&mkgroupid=135815925780&rlsatarget=pla-1645685073528&abcId=9300841&merchantid=113795846&gclid=Cj0KCQjw852XBhC6ARIsAJsFPN2OHgycQREhk2YM2uux1dXzLAd7gOY8xeFFqEMTkgoSdFIGnUnJbiUaAnliEALw_wcB Surely this is a ridiculous price, but just curious from the experts, what would be a fair price for one in perfect condition, and what could I maybe get for mine?(The main hole is slightly spread open and cracked)
And which piece is rare, the latch?
Where would it fit to? Just glue it on or? I don't know what a factory set up even looks like, if anyone has one and doesn't mind going and taking a pic it would be much appreciated
The rear window has no handle, just solid glass. But it is possible to open by just using the friction of your hand, its not the smoothest slide though. How would a proper one look? I'm thinkin about putting this into mine and obv would like a handle. Also here's a cover for a fog light, idk if it would have been on the bumper or sport bar or either but I only found 1.
Ok thanks
Sweet, guess I'll hang on to this one then. Also, is there a proper way to take off the rubber guide things that keep the tailgate from rattling? This one still has 2 straight ones which I could rly use since mine are all bent and warped.
Nevermind, I found the connector you were talking about, it slipped off at somepoint somehow, probably on the trailer over here, and it now runs and drives. Also it came with a whole spare tail light wiring harness from that plug back. Are they Comanche unique or basically the same as the Cherokee?
Nope, I was just told it ran and drove
which connector, the one in the second pic?
Also, I need to figure out why the fuel pump doesn't turn on. I know about the bad ground behind the tail light, and someone already had cleaned it, but I cleaned it again and it didn't fix it. here's some pics of the mess of wires back there, if anything jumps out as an issue for the fuel pump please lmk. Also if there are any other common issues for a fuel pump not working please let me know.
I noticed that too
1JTMR63S9HT087039
*X8 SEATS - CLOTH LOW-BACK BUCKET -Y1 3LX ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGI APA MONOTONE PAINT PACKAGE AWE AWH POWER EQUIPMENT GROUP AWJ Visibility Group BCQ Battery - Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-4SPD AUTOMATIC DMR 3.55 Axle Ratio ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ Fog Lamps LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB MD8 Delete Front License Plate Bracket MWB SPORT BAR MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHB HVY DTY/AUX TRANS OIL COOLER NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red RAF Radio - AM/FM Cassette SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels XEA TOW HOOKS
Oh ok, I don't see it in the build sheet, not sure if it would show there tho.
Also was there ever a factory rubber bed mat? Doubt the one in it is but it looks in good condition so I'm slapping it in mine regardless.
Ok, figured it was aftermarket but never know, the plastic is still good
Yeah, I'm gonna use 100% of the interior but obviously will have some leftover things such as parking brake and dome lights if anyone is interested in stuff, but I'll be coming back to here with more questions like if that rear bumper is in some way desirable or whatever.
I figured if the sport bar had lights then it would be on the same switch as the fog lights. And yes lol, the whole frame is about to give but somehow it still runs and drives. The front driverside leaf spring bracket is literally not connected to the frame.
Just picked up this 87 Chief that I've been waiting to get for a long time. I'm actually trading labor for it, I pull the axles, trans, transfercase, and engine(I keep the a/c parts though), and I get to keep the rest of the truck. The main thing is just the interior and A/C I was after, but theres still a few more things around the truck I can still use. I made this thread because I already have a few questions and am sure I will have more later. First question is does anybody know what the switch on the right in the last pic does, the light comes on for it. Also, its supposed to run and drive, and it starts on aether but doesn't get fuel, can't hear the fuel pump turn on. The ground wire for it has already been cleaned behind the light and I did it again with no luck. Idk if this gives any useful information but I noticed the fuel gauge goes wayyy passed fuel, the pic w the gauge cluster is with the key on.
^The weirder thing was it didn't happen going down the road, I just went to fire it up one day and it had no spark.
I had a similar issue, but not nearly as bad. It wasn't very audible but it did kinda sputter randomly while I was cruising down the road, eventually it just lost all spark and didn't start. Eventually found the tip of the distributor cap was black and smashed like it was burnt out and crushed, and using sandpaper didn't help, also the contact part on the rotor was black. Replaced the rotor and cap and it fixed it altogether. I'd maybe check yours for any of those signs but other than that idk.
We have 3 in ours, only 2 currently wired for the outlet and in use. They have a high and a low setting just depending on which wires you use, and one used to run on the low setting but randomly started smoking than turned off one daybut the high wire still worked so
Cleanest MJ I've seen
Warren99 replied to Warren99's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Yeah but I think it's just a generic aftermarket dealer bumper that they put on different trucks, nothing Comanche specific, but I do like the dealer print on mine.
