Everything posted by Torq_Shep
CRF136N's 89 Eliminator (used to be Torq's)
Torq_Shep replied to Torq_Shep's topic in Member Projects: Your Comanches
I have the wing pieces just not the bolts. The mirror is excellent! Works perfect and is in really good shape for a used mirror. -
I bought some random vacuum fittings and glue so I will try and repair the old one. The metal tube underneath is crimped off also so will need to do some repair there. -
Got a mirror from @eaglescout526 and installed it today. Unfortunately the bolts are missing from the non-existent mirrors on this truck. Found some of the right size in my parts bin but they are 10mm instead of Torx. Oh well. Also splurged on a black vinyl steering wheel as the leather one had disintegrated. Bought U-joints and fuel hose today and the rest of the major parts come in tomorrow. Does anyone know what the plugs in the gas tank go to? Charcoal canister? One of mine is busted, thinking of just plugging it... -
Goal is to get it on the road ASAP and use it for the summer while I gut my converted garage and prepare it to house another roommate. Started on fluid immediately but I have a small list of must do's before it gets on the road. This is the short list to only get it driving and nothing else. -Tires -Battery -Harmonic balancer -Reinstall fuel tank -Fuel pump -A taillight -A mirror -Rear u-joint -
1989 Comanche Eliminator 4.0/2wd/AW4 Very little rust but needs plenty of work. Supposedly was saved from being parted out by the PO. Has a bed light that looks original with an accompanying factory looking switch. Havent seen that before but maybe it is common? I own it. Built 03/89
Sorry, I thought I had done so but I put it in my profile information instead
- 10 replies
That's crazy man. Glad to hear you are okay!
Finished my year long AC ducting and unit swap last weekend. Also had a sliding door fail catastrophically so fixed that.
I have other hobbies and got tired of carrying multiple screen names =P Torq was chosen because I used it as a variable name when writing a dynamometer calibration tool for my job a number of years ago. Shep because I dress up as a giant dog and party like I am still 21 from time to time.
- 10 replies
UPDATE: Bought a drivers mirror. Still looking for a passenger mirror with the above specs (I can be pickier on that one =P) Thanks @eaglescout526 Bought a steering wheel on ebay Bought a door handle on ebay Bought a tail light from @500 MJ Still interested in a decent radio or cassette deck, and the passenger mirror. Would be interested in front fenders, passenger OEM back bumper cap (yeah right), and manual window regulators.
- 10 replies
I am looking for the following parts to get my new to me 'Manche back on the road. A passenger taillight (some damage okay) Rearview mirrors (preferably adjustable and non folding but beggars arent choosers) Passenger exterior door handle and button. Also interested in a steering wheel (preferably black rubber one with 3 spokes but will consider gray leather 3 spoke) And an Am/FM jeep radio or cassette deck 1x AMC plug.
- 10 replies
You do not need a different floor pan and you should be able to use your factory crossmember. Both my comanche and my cherokee had a seperate set of holes in the unibody frame that were threaded to accept the studs and shift the crossmember forward or back. Also the brake pedal is part of the clutch and brake pedal assembly. You will need that whole assembly.
My 89 had that same pretty blue color. Debating it on my 1990 (that or sand...).
If you are passing though SA give me a holler!
Added myself. Looks like a 3+ hour drive from me to any of y'all.
New engine in place Lined up Drivers side motor mount mocked up and set in place Passenger Side motor mount mocked up Stripped the interior to find mouse nests, mouse carcasses, and floorpan cancer...
And engine out... Exhaust folded in half when i pulled it off...
End of weekend 1: Everything is disconnected from the engine. Might try and pull it out tonight.
Stuff is happening...
Anyway, I have all of the brake parts in to finish the WJ front end swap. However, I also have a line on a full engine dropout from a 2011 Regal GS in preparation of an engine swap. If I get motivated enough I may start over Christmas!
http://comancheclub.com/topic/24430-wj-booster-and-master-cylinder-upgrade/
Changed the master cylinder/brake booster to a WJ one. Somehow I messed up the distance for the brake light switch so I bought one for a 1980 C10 and built a bracket that bolted to the brake booster bolts on the firewall.
Being that I have actually started working on my project Comanche I needed to start documenting it. This is my 4th Jeep and 2nd Comanche. I expect this build to be somewhat slow but extremely extensive. This will not be an offroad build per-se but I am planning some interesting stuff. Specs: 1990 Comanche Eliminator All factory skids AX-15 4x4 3.07s and open D35 rear 235/75/15s on TJ wheels In progress projects: WJ Brake booster WJ Knuckles and Front Brakes WJ Steering (UTK shortened factory tie rods) Minor Plans: Rust repair (floorboards and windshield frame) Vinyl flooring in cab Paint Job New window seals Fix rear bumper and tailgate (minor fender bender) Major Plans: 97+ Front clip Ford 8.8 LSD with discs out back (Gearing TBD) GM 2.0L Turbo LHU engine swap (This WILL happen, hopefully in 2017) First day home, Tires were super dry-rotted. Last registered 2013 Interior is decent. Needs minor work. New tires/rims. Probably temporary but they were cheap and allowed me to actually drive it. Seafoam treatment... Motor was missing. Seafoam treatment fixed that. And my old truck just for good measure. I really miss that thing. College tuition stole it from me.
