14
237? I don't think that road was there when I lived in San Jose.
Motor mount identification
cruiser54 replied to PhilisDiller's topic in MJ Tech: Modification and Repairs
country of Origin is important to know. -
After that, or even now for that matter, pump the pedal about 50 times and walk away for 20 minutes. See how that works for ya.
I hand made/scribbled a diagram and someone on Cherokee Forum made the nice rendering. As always, always feel free to "steal" my stuff and share it.
Yes.
You "watched" the fuel coming out? You shoulda been "dodging" the fuel spraying everywhere.
Connector Number Locations Connector C100: Left Of Master Cylinder On Dash Connector C101: Above Master Cylinder Connector C102: Behind LH Headlamp Connector C103: Next To RH Shock Tower Connector C104: Next To RH Shock Tower Connector C105: Behind Battery Connector C106: Next To RH Shock Tower Connector C107: Next To RH Shock Tower Connector C108: In Front Of Washer Bottle Connector C109: Next To RH Shock Tower Connector C110: RH Rear Of Rocker Cover Connector C111: RH Rear Of Rocker Cover Connector C112: RH Rear Of Rocker Cover Connector C113: RH Rear Of Rocker Cover Connector C114: RH Rear Of Rocker Cover Connector C115: Under Dash To Right Of Steering Column Connector C116: Above Master Cylinder Connector C117: In Front Of Washer Bottle Connector C118: Under LH Side Of I/P Behind Kick Panel Connector C119: Under LH Side Of I/P Behind Kick Panel Connector C120: Behind A/C Mode Select Switch Connector C121: Under LH Side Of I/P Behind Kick Panel Connector C122: Under RH Side Of I/P Behind Kick Panel Connector C123: Under RH Side Of I/P Behind Kick Panel Connector C124: Under LH Side Of I/P Behind Kick Panel Connector C125: Under LH Side Of I/P At Kick Panel Connector C126: Behind LH Rear Inner Fender Panel Connector C127: Behind LH Rear Inner Fender Panel Connector C128: Under RH Side Of I/P At Kick Panel Connector C129: Behind RH Kick Panel Connector C130: Under LH Side Of I/P At Kick Panel Connector C131: Under LH Side Of I/P At Kick Panel Connector C132: Under LH Side Of I/P At Kick Panel Connector C133: Under LH Side Of I/P At Kick Panel Connector C134: Under RH Side Of I/P At Kick Panel Connector C135: Under RH Side Of I/P At Kick Panel Connector C136: Under RH Side Of I/P At Kick Panel Connector C137: Under RH Side Of I/P At Kick Panel Connector C138: Under Front Seat Connector C139: LH Rear Inner Fender Panel Connector C140: Behind LH Rear Inner Fender Panel Connector C141: Behind LH Rear Inner Fender Panel Connector C142: Behind LH Rear Inner Fender Panel Connector C143: Behind LH Rear Inner Fender Panel Connector C144: Behind LH Rear Inner Fender Panel Connector C145: Behind LH Rear Inner Fender Panel Connector C146: Behind LH Rear Inner Fender Panel Connector C147: Behind RH Rear Inner Fender Panel Connector C148: In Console Connector C149: In LH Side Of Liftgate Connector C150: In LH Side Of Liftgate Connector C151: In LH Side Of Liftgate Connector C152: Behind A/C Mode Switch Connector C153: Near Cargo Lamp Connector C154: Above Transfer Case Connector C155: Behind RH Kick Panel Connector C156: Under I/P On Steering Column Connector C157: Below LH Side Of I/P Above Parking Brake Connector C158: Rear Center Of Cab Under Carpet Connector C159: Behind LH Rear Tail Lamp Assembly Connector C160: Behind LH Rear Inner Fender Panel Connector C161: At Rear Bumper Connector C162: At Rear Bumper Connector C168: Top Of Washer Bottle Connector C169: Below Washer Bottle Connector C170: LH Side Of Cowl Panel Grille Connector C171: To Left Of Steering Column Connector C172: In Driver's Seatbelt Buckle Connector C173: Under RH Front Seat Connector C174: Under LH Front Seat Connector C175: Behind RH Headlamp Connector C176: On Left Of Steering Column Connector C177: LH Side Of I/P Next To Light Switch Connector C178: LH Side Of I/P Next To Light Switch Connector C179: Behind RH Side Of I/P Connector C180: At Speaker Connector C181: At Speaker Connector C182: At Speaker Connector C183: At Speaker Connector C184: At Speaker Connector C185: At Speaker Connector C186: In Center Of I/P Connector C187: In Center Of I/P Connector C188: Below I/P Behind Defogger Relay Connector C189: In LH Side Of Console Connector C190: Under LH Side Of I/P At Kick Panel Connector C191: Under RH Side Of I/P At Kick Panel Connector C192: Taped To Harness Above Fuse Block Connector C193: Behind Center Of I/P Below Lighter Connector C194: On I/P To Right Of Steering Column Connector C195: Below Washer Bottle Connector C196: Center Of Liftgate Connector C197: Center Of Liftgate Connector C198: On I/P To Right Of Steering Column Connector C199: In Driver's Seatbelt Buckle Connector C200: Under I/P To Right Of Steering Column COMANCHE Connector C100: In LH Dash Panel Forward Of Fuse Panel Connector C101: Behind LH Headlamps Connector C103: RH Side Rear Of Engine Connector C108: Near A/C Compressor Connector C109 (Diesel Engine): Near Lower Center RH Inner Fender Panel Connector C109 (Gasoline Engine): Near A/C Compressor Connector C112: Behind Battery Near Starter Relay Connector C115: Taped To Engine Harness Behind Cruise Servo Connector C119: LH Side Of Engine Near Glow Plugs Connector C120: LH Side Of Engine Near Glow Plugs Connector C200: Under LH Side Of I/P Behind LH Kick Panel Connector C202: Under LH Side Of I/P Behind LH Kick Panel Connector C203: Under LH Side Of I/P Near Ignition Switch Connector C204: Behind Mode Select Switch Connector C205: Under RH Side Of I/P Behind Kick Panel Connector C207: Under I/P Above Brake Pedal On Steering Column Connector C209: Under RH Side Of I/P At Kick Panel Connector C210: Near RH Door Jamb Switch Connector C211: To Left Of Steering Column Connector C314: In RH Side Of Liftgate Connector C315: In LH Side Of Liftgate Connector C402: Under LH Side Of I/P At Kick Panel Connector C404: Under RH Side Of I/P At Kick Panel
Headlight Switch Connector
cruiser54 replied to harlemantg@verizon.net's topic in MJ Tech: Modification and Repairs
http://cruiser54.com/?p=115 -
Keep us informed. It wouldn't hurt to suck the old fluid out of the clutch master. Then, best you can, get the crap/sediment out of it. Add new fluid and pump the hell out of it. You may be tempted to do that a second time.
Cooling issues. stripped bolt.
cruiser54 replied to TheSiLvAPython's topic in MJ Tech: Modification and Repairs
This^^ -
Likely unrelated. How's the fluid level in the clutch master? condition of the fluid? Last time you checked and topped off trans fluid?
That sounds like a cheapy thermostat and a bad fan clutch to me. -
What brand 02 sensor to buy?
cruiser54 replied to VorTekX's topic in MJ Tech: Modification and Repairs
Do the Tips. You just may fix it in the process. Aftermarket parts are hit and miss any more. NTK used to be the go-to brand, but I'm not sure that's still true. -
First off, that light is triggered by a timer. It has no clue about anything else. since you have an 88, I would suggest going to www.cruiser54.com and COMPLETING Tips 1 through 5 before buying any parts at all. -
I have NEVER needed to bleed one of those cooling systems. Been working on them since 1987. Perhaps describe your issue in more detail. Symptoms? -
what year? -
HO Jeep Cherokee AW4 trans issues
cruiser54 replied to 88mjsally's topic in MJ Tech: Modification and Repairs
Not necessarily cooked. -
All AW4s have an NSS. Here's a cheap and easy thing to do. CRUISER'S MOSTLY RENIX TIPS TRANSMISSION CONNECTOR REFRESHING OCTOBER 30, 2015 SALAD 22 COMMENTS EDIT Over near the transmission dipstick tube are 2 rather large connectors. One is black and goes to the NSS and the gray connector goes to the transmission itself . These 2 connectors carry all the info between TPS, TCU, NSS, speed sensor, and transmission solenoids. Unplug each one, visually inspect for corrosion or bent pins, spray them out with electrical contact cleaner and plug them back in. Additionally, if your Jeep is an ’87 to ’90 Renix, it’s always a good idea to reach up under the glovebox area and unplug the connector to the TCU and spray it out along with the receptacle of the TCU. While you’re there, find the fuse right in that area for the TCU. Remove it and spray out it’s receptacle and clean any corrosion from the fuse. -
Still oughta complete those Tips.
Water Pump Recommendation?
cruiser54 replied to CrustyBoy's topic in MJ Tech: Modification and Repairs
1,000 miles before your oil change, add a quart of Marvel Mystery Oil and run it. -
No need to reset the ECU. Tapping is likely a sticky lifter. -
Dreaded high idle
cruiser54 replied to Dickinson County Comanche's topic in MJ Tech: Modification and Repairs
Take your meter and a can of Freeze-Off with you to the wrecking yard... -
I was thinking of the U shaped metal clip.
