14
Remember that wipers, turn signals, AC and radio all draw from that weak Brown wire at the ignition switch.
HELP! Sputtering issue!
cruiser54 replied to Prestin_xj's topic in MJ Tech: Modification and Repairs
1,3,4, and 5. Absolutely first before firing the parts cannon at your Jeep. Takes under an hour. -
Spraying grounds with cleaner is pretty much ineffective. Your fuel pump could be failing when hot. Have you visited my website and completed Tips 1,3,4 and 5 yet? -
Recomended brand for rod bearings?
cruiser54 replied to EUREKA's topic in MJ Tech: Modification and Repairs
Measure the journals. Actually, the bearings are much softer than the crankshaft, so likely you will replace the rod bearings with whatever came out, Never .010" or the like. Like stated above, that's only after machining of the crank. -
4.0 Timing Cover differences?
cruiser54 replied to pago cruiser's topic in MJ Tech: Modification and Repairs
this^^^^^ -
How did we go from timing covers to battery trays? -
someone has to have a good used one they'd part with. -
Yes it will.
89 Jeep Comanche wiper motor problems...
cruiser54 replied to Andy in Pa's topic in MJ Tech: Modification and Repairs
Like it? I had it custom made. -
This is where something free costs a lot in time spent. This guy on Cherokee Forum reconditions injectors and supplies a copy of the flow results. trevor.skankfootracing@gmail.com
Made where? -
cool. Take it to a shop then and save yourself a ton of frustration.
This is likely to be expensive. Probably just a waste of time and money to throw a can of expensive refrigerant in. Let the shop do it. The system will need to be evacuated, and certain components replaced, along with a conversion to R134a refrigerant. How much money are you thinking of throwing at this? Budget?
Yes, sorta. Go have it diagnosed at a shop.
THIS ^^^^^
Tape it up.
After three months seals finally arrived!
cruiser54 replied to Car Enthusiast's topic in MJ Tech: Modification and Repairs
Of all the things I've lost, I miss my mind the most..... -
Yup. From Tip 8 at the end: For those with a MANUAL TRANSMISSION–the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. The square 4 wire connector is just not used. Revised 7/08/17
Your negative cables are okay. The one for the block was put on a starter mounting bolt? If so, move that to the bolt hole forward on the block. The 3rd ground is the 3 or 4 small wires with eyelets at the engine dipstick stud. all else you need is a smaller gauge wire from neg bat to inner fender. Need more pics. PO mighta been a hack. Factory had no fuse to alternator. Pos bat to relay and another from that terminal to alternator.
Your ears will thank you.
Those grounds are gross!! The places you have circled are fine to use.
CRUISER'S MOSTLY RENIX TIPS RENIX GROUND REFRESHING OCTOBER 30, 2015 SALAD 72 COMMENTS EDIT The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, failed emission tests, and wasted money replacing components unnecessarily. All the components listed below ground at the dipstick tube stud: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition Control Module, Fuel Injectors, ECU main ground (which other engine sensors ground through, including the Oxygen sensor, Knock Sensor, Cruise Control and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. If the whole stud turns, you can use a 7/32″ six point socket or wrench to hold it so the nut can be removed. Worst case, cut the wires and remove the stud and nut. Install new terminal eyelets on the wires when going back together. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Surfaces must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Apply a liberal coating of OxGard, which is available at Lowe’s and other stores. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, apply OxGard, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for its intended use and subject to corrosion and poor connections at each end. Remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Apply OxGard. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4″ socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely with a liberal coating of OxGard. 2 STRONG suggestions regarding the ground system: I prefer to add a #4 gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18″ long with a 3/8″ lug on each end works great and you can get one at any parts store already made up. NAPA has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10″ long with 3/8″ terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. NAPA part number 781115. For those of us with Comanches, it’s very important to remove the driver’s side tail lamp assembly to access the ground for the fuel pump. Remove the screw holding the black ground wire. Scrape the paint from the body and corrosion from the wire terminal. Add a 10 gauge wire, with an eyelet on each end, from that grounding point to a bolt on the frame. Better yet, on both Cherokees and Comanches, complete Tip 29 for the best fuel pump grounding. Be sure to scrape all mounting points to bare metal and apply OxGard also. If you want to UPGRADE YOUR GROUND AND BATTERY CABLES with custom made parts, contact Paul at www.jeepcables.com Revised 02/04/2017
The amount of incompetence in this world just overwhelms me some times.
