cruiser54
    14
  1. Dexron 3. Might think about doing a drain and fill. You'll need a gallon.
  2. Cam is exactly the same in early HOs. Want the complete skinny? CRUISER'S MOSTLY RENIX TIPS HO INTO RENIX SWAP OCTOBER 31, 2015 SALAD 76 COMMENTS EDIT This swap is easier than some will lead you to believe. And generally Pooh-poohed by those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block. XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange. 2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange. YJ and 1997-1999 4.0L TJ blocks will interchange in XJ/ZJ XJ/ZJ blocks, and the 2000+ TJ/WJ blocks do not interchange without significant modifications. TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ. Now that we know which engines we can use, let’s get down to business. The HO and Renix have some differences but none that can’t be overcome very easily. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from an HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head at the rear for the sender. You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use a new Renix gasket. Exhaust ports are identical. An alternative on exhaust manifolds: As far as exhaust, you can use the Renix exhaust manifold and be fine. If you want to use the HO exhaust manifold, you must go with an HO headpipe and screw your O2 sensor into that headpipe. Standard Renix harness is plenty long to do so. A bung can be welded into the HO manifold to accept the EGR tube. You will need to use your Renix distributor as it is different than the HO design. See Tips #12 – Setting Your 4.0 to #1 TDC and #13 – Distributor Indexing to be sure you get the distributor installed correctly. The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications. The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine. As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case. XJ: “Regular” (not Grand) Cherokees ’84-’01 ZJ: Grand Cherokee ’93-’98 (Gen1) WJ: Grand Cherokee ’99-’04 (Gen2) YJ: Wrangler ’87-’95 (Gen1) TJ: Wrangler ’97-’06 (Gen2)
  3. The poor thing just needed a tune-up!!
  4. 2) c101 refreshing/eliminating is a big deal and high priority. 3)connector and relay connection refreshing is also a big deal. Take a few minutes and complete it. The vacuum harnesses should fit 87 through 90. Easy way to check for vacuum leaks using carb cleaner at idle. AND, the IAT can be removed and sprayed clean with carb cleaner.
  5. NGKs are great plugs. been using them for 50 years. What about replacing cap and rotor? every 30,000 miles plugs, wires, cap and rotor. Get a cap with brass terminals.
  6. If they hadn't changed the flexplate, it wouldn't even run. Remind me. How many of my Tips have you completed?
  7. For $20, I'd buy em for the steel!!!
  8. I have handfuls of them. I heard ones from a ZJ work in the XJ/MJ. Anyone confirm?
  9. ALL parts are a CRAP shoot anymore. Chinese Replacement Auto Parts. country of origin is the biggest factor.
  10. On TOP of the column is where the ignition switch is. 2 small nuts. 3/8"? It's a pain. Easier if you lower the column.
  11. It absolutely is connected to the intake manifold from the booster. I'm not sure I would be blaming the occasional high idle on the booster just yet.
  12. Clean your throttle body and don't believe the mechanic. http://cruiser54.com/?p=60
  13. Might be a classic example of this old saying. If you give a monkey a gorilla suit, he thinks he's King Kong.
  14. so, after it starts it goes to a higher idle than normal for a few seconds before it settles down?
  15. Why are you replacing it? They can be cleaned and checked. Also, they rarely fail.
