Ωhm
    6
Everything posted by Ωhm
  1. I also can't remember if I loaded large PDF's or not. I was looking to post a TSB.pdf and couldn't. I found a link and posted that. Everything's fine now. Thanks
  2. Willie time
  3. TSB 18-51-88 CPS BYPASS
  4. Error code -200 Actual file size 4KB's
  5. 2nd photo shows the red wire (engine compartment lamp) I was talking about. This not your problem.
  6. Ωhm
    My Dad, the Man
    Emptiness now fills with memories. Time causes this. Thanks to all for kind words.
  7. Ωhm
    My Dad, the Man
    My father passed away last Friday. Age 98 Yesterday was viewing at the funeral home. Today we had Mass and services. Tomorrow will be burial at the cemetery. I miss my dad.
  8. NickInTime has a short utube on the MT2500 for RENIX. Mentions Keep-Alive Battery and something about bootlegged cartridges. Other than that, I'd look at power and grounds for MT2500. Could be crazy serial data output from the ECU if MT2500 proves good. https://www.youtube.com/watch?v=qPV5pEGUHWw
  9. How this for an English Blues Rock band.
  10. Check out the Ignition Control Module (ICM) w/Coil. Make sure that there's no RED WIRE plugged into the coil. Know problem. Flip your front grille, it's upside down. Welcome to CC.
  11. Ωhm
    HI-Fi CCers?
    I'm buying MP3's now. Best thing that ever happen to my music. Carry it on a stick drive, goes anywhere. Now own 989 tunes as of today. Analog sound is the best, but not to my old ears anymore. PayPlay.FM
  12. .... in the last 5 years. Printed Brandan Gillogly 02 February 2023 https://www.hagerty.com/media/market-trends/valuation/5-jeeps-that-have-doubled-in-value-in-the-last-5-years/#:~:text=XJ Jeep Cherokees have been,bed behind the front seats.
  13. Ωhm
    Neat Older Car Pics
    Dearborn MI just added a new street. New Ford World Headquarters Building in the background.
  14. Ωhm
    HI-Fi CCers?
    Sansui RA500 reverb unit I have one, so does/did @Old man with MJ.
  15. Perfect time for the trailer harness.
  16. Should be a great show. You're in for a good time.
  17. Speaking of 'Asleep at the Wheel'.
  18. There's one blue wire that runs to all taillamp bulbs. As @The86manche mentioned follow that blue wire. Make sure that RED butt splice isn't tied to GND. Check all bulbs, make sure they're 2 filaments bulbs, except license plate bulbs. I know single filament bulbs aren't supposed to fit, but people have a way of making them fit.
  19. Yes and Yes C158 is located under the drivers side seat. Not sure on how easy it is to get to. Instead try C159 located back by the LH taillamp. With C157 connected, disconnect C159 and try the same test using the headlamp switch with C159 disconnected.
  20. Ωhm
    Neat Older Car Pics
    We were young and thin.
  21. Disconnect C157. Using another fuse and C157 disconnected find out if the fuse stills blows when set to the PARK position. This will determine if your shorted to ground (STG) on the front half of the vehicle or the rear half of the vehicle. C157_B (Blue wire).
