Fernando87mj
    2
Everything posted by Fernando87mj
  1. Jeep jk wheels on the beige one and aftermarket wheels on the red one
  2. Installed a new battery after 10 years of hand me downs and used battery's :/
  3. Oh I see I'll try to replace the o rings today again to see if that's the problem and I'll use Vaseline this time .
  4. Okay I'll check the clips today , and thanks for the advice guys I appreciate it :)
  5. Woah nice jeep man :) I really dig that rollbar [emoji106]
  6. I used bearing grease since I didn't have oil on me at the time , but thinks for the input I appreciate it I'll check out the bwd [emoji106]
  7. My 88 mj is leaking fuel from/around the injector again :( . I replaced them 2 months ago because the old injector orings where leaking so I replaced it with a napa oring set and had they had been working flawlessly until today. I Smelled a strong fuel odor and I immediately shut it off and opened the hood and saw that #5 fuel injector was leaking . So I want to ask you guys What kind of fuel injector orings do you guys recomend ?
  8. Was rear ended a few years back ,and the accident report said comanche "chief" but it's actually a base .
  9. Woah that's a really clean mj man :)
  10. here's the link to the video :thumbsup: http://m.youtube.com/watch?v=u9tihJMjHqo also note its not me that's revving the truck, its revving by itself .
  11. Hey guys my 1987 jeep comanche 4.0 5speed is having trouble idling after start up . It seems like it wants to stall but after a few seconds it'll rev itself to about 1500-2000 rpm and the near stalling will go away . My 1988 comanche 4.0 also does it but not as bad . Does anybody know what it might be ? I'll try uploading a video in a Bit .
  12. Mines doesn't have it , But my 88 does have the ballest resistor
  13. It's was a really hot day here In Vegas today ,and I noticed that I could hear my fuel pump run from inside the cab once the truck was running after a while , but the noise isnt as loud when cold. my question is , is it Normal or should I be worried ? Also it's a 1987 4.0 5speed and the engine was running at 200~210*
  14. You need a cluster from a renix jeep 87-90 that has the cable driven speedo , 91 and up is electronic . Also you need too get a cluster from a cherokee/comanche with the same engine and you need to swap the water temp sender and the the oil pressure sender which is pretty easy :) .
  15. 1987 jeep comanche 2wd swb Unknown build date ? 4.0 BA10-5 transmission Dana 44 trac lok rear axle Beige clear coat Tan interior Bench vinyl seat Mini console Vinyl floor Currently in Las Vegas Unknown purchase location Currently used as a daily driver
  16. for some reason my computer isn't letting me post pictures, so I left a link to photo bucket in my signature. the pictures are from my other Comanche (88) I bought a few weeks ago
  17. I have an 88 it's getting work done on it right now, but once I get it back id be glad to take pictures of the labels .
  18. Okay thanks ,I appreciate it hornbrod.
  19. Did the napa cable ever fit ? I have 1987 shortbed and the cable that goes to the pedal snapped and I wanted to know if the napa cable fit yours .
  20. I'd like yours but sadly mines is a short bed
  21. as you can see my bed mat is old and dry rotted , is their any companys out there that makes new bed mats and bed liners for the jeep ? :???:
  22. as you can see it does need work :rotf: i
