Everything posted by cracker
Wanting metal Tail light boxes? Possible group buy?
cracker replied to brimy311's topic in MJ Tech: Modification and Repairs
To this: :huh???: :clapping: Should take his name off the list then or put him as a MAYBE. -
I do not have specific details but I will ask him the next time I see him. He is an experienced wheeler so I know the lines are not too short and they would be set up right.
I've been looking for the same thing. -
What "same" 6x5.5? S10 is would be 5x4.75. :doh: Sorry. I assumed they shared the same lug patterns as their biggr brothers :dunce:
It might be a waggy rear 44 as they share the same 6 x 5.5 bolt pattern. I know you mentioned it looked stock but the waggy perches might be the right width to give the illusion of an OEM install. :dunno:
I think my fuse panel has had to much to drink
cracker replied to RLCollins's topic in MJ Tech: Modification and Repairs
Yes. This is what I did. I will try to snap a pic tomorrow for you. -
Totally. I have installed a second fuse pannel and I am moving things over to the new fuse panel as I find them go bad. -
I personally know someone who has gone through 10 of their cables. I wouldn't recommend the OX to anyone. I have had the ARBs but keep in mind that when engaged they turn the differential into a spool. I had good luck with them though and never had a problem with an air line. People do speak very highly on the Aussie though I have yet to own one. We do not have inclement weather out here so I am a Detroit locker guy for the rear of my MJ. :beerhead:
4x4 Conversion, dead in the water. HELP!
cracker replied to BORDENCOMANCHE's topic in MJ Tech: Modification and Repairs
Uhh...probably not a 1350. It is probably a 1310 but intended for a NON CV front driveline. Heating and plasting it with penetrant is the best bet to get it off. -
Bingo. :thumbsup: Most people don't realize this.
1.)Jeepcomj 2.)Cdn Glenwood 3.)pingpong (with bed sides if possible) 4.)88pioneer 5.)dakal 6.)Raoden83 7.)DJM/78 8.)possum 9.)Jpnjim (either style/bedside preferred) 10.)johnnyc 11.)Jeepcomj (set number two) 12.)jimoshel 13)89eliminator 14) Cracker 15) Cracker (set number two) There are your 15 ;) -
What gearing are you running? I run 5.13s :wavey:
I get about 13 MPG on 37s, 7" lift and an Aw4 that I have to manually lock the torque converter ( :doh: ). I assume when I figure out the automatic torque converter lock up I will get slightly better mileage.
Careful with that. The harmonic vibes can be brutal to your TC and pinion bearings.
Says who? :shake: And yeah, it has a SYE but I run a doubler so my driveline is shorter than stock.
:rotf: It is not that bad out here. You have inclement weather out there so I can understand that. Just because of the 'deal' I am getting, I will have a selectable in the front of the new HP60 axle but I prefer the Detroit Locker all day long :cheers:
Bilsteins all day long. It'll be money WELL spent. I run 7100s on the front of my Super Duty and the MJ and it is as pleasant as warm apple pie. :yes:
Sounds like ball joints or steering TREs. My 1 ton truck was doing that and replacing the D60 ball joints made it a new truck and it tracks straight now :thumbsup:
Totally. With a 3" lift, most quality kits will provide you new coils, new front brake lines, lower control arms and maybe a new track bar (or relocate the axle mounting hole). The rear would probably get a new (extended) shackle and an Add-A-Leaf (AAL). It will take about four hours if you have never done it before and would require a front end alignment (I just use a tape measure). As far as steps...........your lift would come with specific instructions but basically unbolt all the OEM stuff and replace it with the new AM stuff.
School me on truck boxes...
cracker replied to ncgamedog's topic in MJ Tech: Modification and Repairs
Got a pic of mine installed -
I have a dual flat crossmember set up due to my doubler (and I have have a bad tranny leak :doh: )
Hello Your answer really depends on what you want to acheive in a lift ;) Could you narrow it down a little?
I don't think this is correct. All the Saginaw boxes the Cherokee used should be the same.
This is why I am putting out a feeler and not just making them. I understand this logic completely, but I feel I owe it to those that have asked to at least put a feeler. Trust me, we understand the size of this market! Since we prototyped sliders for these trucks, we maybe have sold 3-4 sets. Thank you for checking with us. I appreciate the opportunity. :cheers: If there is a rendering to show that will help in the process. :) -
Those get ripped off out here and actually cause more damage to the vehicle in the process of getting ripped off.
