3
Removal of old vinyl "hockey sticks"
dasbulliwagen replied to madmax's topic in MJ Tech: Modification and Repairs
I removed my sportruck decals this way. Bad thing is now that they are gone you can still see where they were due to paint fading in the uncovered areas. -
rear bumper, will it fit?
dasbulliwagen replied to Comangi's topic in MJ Tech: Modification and Repairs
I made custom brackets to mount an XJ rear bumper to my MJ. If you put that custom one on my brackets it might interfere with the rear body, but I'm not really sure. I was able to trim the original XJ plastic rear bumper ends to fit the MJ lower bed corners. I'm not sure how that would work with a custom one. If you go into the projects section look up "Comanche Limited" for my build thread and pics of the mounts I made. With the cost of the metal to build mine and the engineering time, it might just be easier to buy the pre made brackets and weld them on to that bumper. -
When I did mine I ran out of shims so I used a couple short peices of bar stock shoved in there.
On the subject of wheels/tires
dasbulliwagen replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
For larger sizes and hub centric look at the Liberty and the Nitro. Nitro's come in sizes up to 20 inches have 5x4.5 lug pattern and are hub centric. Backspacing if its an issue can be taken care of with hub centric spacers like Spidertrax. Other good hub centric with correct pattern wheels come from 2005 and newer Dodge Charger, Magnum, and Challenger, and Chrysler 300. Base models come with a 17 inch steel bullet hole and police cars come with an 18 inch steel 5 spoke. Not to mention a ton of aluminum choices. The steelies at least have been used successfully over on Naxja.org by several people. I have JK 17 inch takeoffs on mine with spidertrax adapters. They measure right at 32 inches stock. JK wheels can also be had stock in 18 inches. Choices are out there. Let us know what you end up with. -
Manual v.s. auto your guys opinions
dasbulliwagen replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
I prefer manuals as well. For me its more a less complexity and more reliability issue compared to autos. But being an auto tech I've found that I transition pretty seamlessly, that is except for Wranglers and Miatas. Every time I get in one of those I automatically reach for the clutch not even thinking about it. Problem is I only get a clutch about 1/3rd of the time. -
No rear bumper stock. Had a lighted plate holder on the panel under the tailgate.
I consider the Sportruck to be the base model. My 87 Sportruck is was a 2.5 4 speed 2wd radio delete rear bumper delete no power steering bench seat vinyl floor steel wheel truck. Yours is highly optioned compared to mine. Nice truck though. What are your plans for it?
Need advice on wifes TJ
dasbulliwagen replied to Dadinator's topic in MJ Tech: Modification and Repairs
There are several items on that 5 volt reference circuit. It could be any one of them bad bringing it all down. I'm not saying this is definitely your problem but its possible. Don't quote me bit I think the other items on the 5 volt circuit are the crank sensor, the throttle position sensor, the ac pressure sensor, coolant temp sensor. I've also seen a bad engine ground cause issues like this. Just more stuff to check. Good luck. -
Tips to keep jeep from over heating
dasbulliwagen replied to Campbellbrothers's topic in MJ Tech: Modification and Repairs
Many of the 4.0 trail runners add hood vents to let heat escape while on the trail at low speeds. Heat wants to rise naturally, so adding vents in the hood will naturally let the heat out better. But like was said, check all the other stuff too. -
Is the Dana 30 strong enough for my build?
There are sleeve kits available to strengthen the 30 as well, but they don't really apply to the cad axle. There was a non cad axle available in 86. It came with the xj's and MJ's that had the NP228 full time 4 wheel drive option. Not that you have to have an 86 axle. But the upgrade 1 peice shafts mentioned can be made to work in the cad axles with special axle seals. -
And these are all new never installed parts correct? Any idea on package price?
Just make sure they are AMC 2.5 and not Chrysler 2.5.
Help me decide 2.8 to 3.4 or 4.0?
Too much power will also eat an AX4 or AX5 alive. If you have the A904 auto you should be OK as those were used behind slant 6's and small Chrysler V8's. There are upgrade kits available for the auto to improve its shifting that are bolt on as well. I have a couple of 86 parts vehicles that I want to build one out of and the XJ has the A904 and NP228 with the 2.8. A 3.4 inj engine with the A904 may be a future drive train for the 86 MJ I have parked. I'd like to build it in the future for my daughter to drive. I have 10 years at this point to get it done. That SHOULD be enough time! -
There are write ups about adapting the Camaro injection as a standalone system. This would be the best way to go for power reliability and economy. -
Higher comp pistons for 2.5 4cyl??
dasbulliwagen replied to 81Chero's topic in MJ Tech: Modification and Repairs
I read a story somewhere once (saved link on another computer), about a guy who's brother was a machinist and had his 2.5 block bored out to 4 inches and used Chevy small block flat top pistons. It is an unconfirmed story but after some initial research it does seem possible with minor mods. That and the pistons are cheap. The stock 2.5 bore I think is 3.850". The article talked like there was plenty of meat there for a .150" overbore. I think they said that would bump it up to 2.7L. I plan to do more research on this when I get to build my spare engine. I know 505 performance probably has all this info already but I don't really expect them to just hand it all over, especially after the email questions I had about their 2.5 cams were poorly responded to. -
Yup
Gear box adjustment question
dasbulliwagen replied to big66440's topic in MJ Tech: Modification and Repairs
When I did my caster I found the spec to be " 6.5 to 7.5 degrees positive " I had a hard time getting close to that going from stock 2.5 2wd to stock 4wd springs with an additional spring isolator. I just about maxed out the adjustment just to get to 6 degrees. It did help tremendously though. Make sure you do that part. -
I've always loved the CJ's and Wranglers and always wanted one until I got to drive a few. You can't haul much of anything in them. They aren't secure with a soft top. And they get relatively crappy gas milage. They do have a cool factor though and that is the draw for most people. You almost have to be fully accepting of the lifestyle to live with one on a daily basis. Especially with a soft top! Even though my MJ is even smaller on the interior, at least I can lock it up, not worry about the weather, and haul a literal ton of stuff in it. And its still a Jeep.
Factory shift light not working
I just realized mine isn't working either. But I think it hasn't worked because my speedo cable isn't hooked up. At least that's what I'm going to tell myself until I install the new cable. -
Usually if there's enough play in the steering box to ask about adjustment, you just need to get a rebuilt unit. If you adjust for the wear in the straight ahead position, the area that gets the most wear, you'll end up having binding of the gears when the box is turned out to areas of little wear. That adjustment is mostly just there for initial setup.
