MiNi Beast
Everything posted by MiNi Beast
  1. done see other post
  2. well Pete your back in town so time to go back to work. Who takes 3 vacations in one year? :roll:
  3. run it in my 8.8 :thumbsup: did you fill it up past your fill plug?
  4. MiNi Beast
    Donuts???
    Yeah I tried on sat..... :roll:
  5. ... it's been said, but not by me, that it's not strong enough. 89eliminator is correct. x2. I'm far from a good welder, but those are not safe welds at all. I would keep practicing on some spare steel until you can get a better quality weld for it. Or you can go the fastest, safest and and most efficient route; have a professional do it. You mean there are people you can pay that know how to weld? :shake:
  6. Not much of a story, just was a consequence to dumb driving. Posted what happened in bicker page. And $500mj I still may want that sunroof but if you can get rid of it before I get up there then do so. Also would like to get a mj now but thinking I need to keep to the xj for the family's sake and that I can just swap everything right over.
  7. Well finally had my first roll on sat..... looking for a new body..
  8. well then.......... http://www.jcwhitney.com/ROUGH-COUNTRY- ... _10101.jcw
  9. Welcome back to 4 wheeling at least this time you got a better start, a jeep you know :D
  10. Well stay and play then. :D
  11. I ran no sway bar with 5" lift and loved it, even on my XJ with 6.5" lift I run no sway bar and love it.
  12. then leave jeez we no need you around here. :headpop: J/k easy does it here man we all friends, don't mind motion there just running low on lotion. :D
  13. :hmm: can you say........attention lady of the night!
  14. If you already have the 8.8, I'm not sure why you're considering using the D35. You are already going to need to add spring perches to either axle. Sounds like the perfect time to install the 8.8. :???: Willy Unless he has those nifty swap pads that work with the under axle perches. But X2 on doing the 8.8 swap now being you have to tear everything apart now anyways.
  15. Looks like the ZJ v8 setup on there or just a fat boys tie rod on there.
  16. http://www.greatlakes4x4.com/showthread.php?t=97782 GG for a 35
  17. Being you have only a 2wd, I would just lock the rear end and call it a day untill later on when you want to perhaps convert it to 4wd. Being its a 35 if you want to buy and ez locker for it then go ahead and do it. This will aid you well in traction and get you farther then not having it. And will get you by untill you get 4wd. I wheeled for 3 years with only 2wd, however it sucked with open diff at first, but when I put in my 8.8 with the LSD it was much better. I went through stuff even some 4x4 couldn;t make it through.
  18. 35 front huh? :rotfl2:
  19. I wanna say the guy only has 2wd but what do I know I only read it. :nuts:
  20. You would! Thats was funny but just think if the white guy gets in office he'll die from cancer before his term is up and then it will be up to the vice president.
  21. Alright well you know you love jeeps and are broke when you change your own tires manually... :nuts: Well I got the 35's on, a free set of bald ones, but I want to see how she goes before I go and get a a good set to put on there. If I no likely then going to keep running 33's. Well I saved $40 that I didn't have and changed my own tires. Took all day and the way I fell now I do not recommend it to anyone. "Work smarter not harder", has never met so much until now. But their on. As well as got my Co2 tank for my trail spare air tank, just have to get the necessities to go with it now. Thinking I may just go through here for my needs... http://www.redrock4x4.com/shop/categories/82_400.html Then made some adjustments to my steering due to the taper in the knuckle, just put in a misalignment spacer in on the bottom side of the knuckle to fill the knuckle in and keep the bolt from see-sawing and working it self loose and causing my loose steering.
  22. Hes not black so he won't be first black president.. You want a black president vote for this guy.... Image Not Found
  23. X2 It's funny though. But if you want to post stuff like this put it over here and she'll stick around.... http://www.comancheclub.com/forums/view ... highlight=
  24. YOur such a poser :roll:
