MiNi Beast
Everything posted by MiNi Beast
  1. Flight 175 let us all remember, and not forget. :USAflag: :USAflag: :USAflag: :USAflag: :USAflag: :USAflag: :USAflag: :USAflag:
  2. What harness does he need, I have one out on my 93 he can have or does he need a renix? i think he mentioned needing a renix 5-speed harness ok
  3. What harness does he need, I have one out on my 93 he can have or does he need a renix?
  4. if you do a 8.8 I would really go for the spring over option as then you only have to buy and weld one set of perches on, instead of the spring under way unless you plan on staying that way as they do have up to like 4" of lift spring under leaf packs. It's just benefucial to go spring over to gain 5" of lift and save money being you just reuse you leaf packs.
  5. :popcorn: :popcorn: :popcorn: http://www.youtube.com/watch?v=VvLo8zkbYNA
  6. www.scribd.com/doc/7057536/Jeep-AX15-Se ... ansmission
  7. :yes:
  8. They working on some good stuff over there. Here is what they got going... http://www.jcroffroad.com/index.html
  9. get solid stuff at Ruff Stuff, good guys there http://www.ruffstuffspecialties.com/cat ... p-186.html
  10. add atleast a 3in lift now to have plenty of room for tires and a better ride as well. :thumbsup:
  11. what the shaking he getys from only three ;lug nuts on one wheel, or the other?
  12. looking good. My old man just got water running in his van as well, used a wiper washer pump to run the water. :shake: All this so he could take a nap at work on lunch. :nuts:
  13. I have. Even had a brand new custom flat bed with a wood floor, guy wanted only $200 for it. Worth that in just the wood that was on the floor had good stuff on there. But the springs were awesome, so awesome I bought them for $30 and but them On my MJ when did the 8.8 swap. Which I took of the stock springs from the MJ which I got in FL. They were that nice, prolly new with the bed and all but still got them out of a JY. :yes:
  14. So is MIchigan out?
  15. yep that's a MJ :shake:
  16. copy the IMG code and paste it here and it will post the pic like I did for you. :yes:
  17. air filters are air flow restricters, can run them at short distances with out any problems. Are you sure that's not nitrous injection?
  18. ground hawgs look likes
  19. found the build up thread on these but not much on using longer springs but seems to be a good set up. http://www.naxja.org/forum/showthread.p ... 999&page=1
  20. he runs on them now. :shake:
  21. MiNi Beast
    bargains
    have to subscribe though huh?
  22. MiNi Beast
    bargains
    post the link man http://dustytimes.com/
