bowmans86mj
bowmans86mj's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. well if you do have one i am interested.. just let me know what kind of beer you would like and ill be sure to get some for you!!!
  2. how far away is that?? and how much were you asking
  3. just south of toledo ohio.. where are you guys located and how much?
  4. i noticed i have an oil leak comming out of the side of the oil pan. there is a rust spot so i was wondering if anyone had an oil pan that they wanted to sell or if anyone could find a website that had one for me?? thank you
  5. I'm posting this for my friend but he has a 1989 jeep cheroke limited and he just recently purchased lockers for the rear end and they seem to be working good but he noticed that ONLY when he turns right he hears a popping noise and i was wondering if anyone had any suggestions or opinions on what that might be.. thank you :dunno:
  6. i appreciate it but i slapped them 06 wrangler springs and a home made spacer and it seems to be working pretty good... my buddy works at a ruber factory so he can get and make me spring spacers for free.. but thank you
  7. shoot i forgot.. got another question... say i was to get rims instead of buying wheel spacers what kind of rims would give me enough clearance with the back spacing... they need to be 15/7 or 15/8.. I'm not good with this internet stuff thats why i need help finding things.. thank you
  8. ok cause i like spring compressors.. i have done 2 similar jobs before.. once with a compressor and once without and the time without i was young n doumb and was replacing a strut and about broke my jaw when i unbolted to top plate cause of all the force... but thank you all for the information..
  9. how hard/easy is it to put on new coils???
  10. excellent! well the only driving this thing will be doing is down trails and being trailered there and home.. i actually do not have a sway control system on it....
  11. so if i was to have a broke coil spring " like i do" and had a set of 2006 4.0 liter wrangler coils i COULD put them on and atleast get the same height out of stock just to get by temporarily untill i can get a lift kit?????
  12. well that sucks... i can't find dimensions online to see whats the height difference
  13. yeah.. well looking the vacuum lines actually hook up to metal lines similar to brake lines and run up the fire wall or close to it.. but again. yes it did work and thank you for all the help
  14. well i just got ahold of a set of 2006 wrangler front coil springs. will those work??? and also what kind of chevy shackles should i use?? does the year matter or 1/2 ton or 3/4 ton matter??
  15. plugged the lines and she purs like a kitten again... thank you for the help
