MiNi Beast
Everything posted by MiNi Beast
  1. See a few folks out here on bikes. Yes winter time and yet on bikes. They are snow bikes with fat tires. Kinda cool. Have to try one sometime. :D
  2. X2642784747 on a selectable up front, be added in time. For now welded is all I have and will run it till I'm completely pissed at it. Lol And yeah Wade is a line picker alright. Not sure how he does it and keeps big red so pretty. :D
  3. $3.79 unleaded and they go up everytime it snows. :(
  4. Run it. ran the $#!& out of my 30 with 37" mtrs. Just have to be a conscience wheeler and I think you'll be alright. And if you broke 3 shafts with a welded diff backing out the driveway then you sir cannot drive. You make any hard turns welded in 4wd you are going to bind. I run welded front and rear and stay reasonable and ran 40s and not many issues on a 44 stockshaft and joints. .never any shafts broken from backing out my driveway even in 4wd. 50 pt turn but no broken shafts
  5. Your slowly growing up. I'm so proud. ;-)
  6. And that would be a heavy cap with a modified xj hatch on it.
  7. Oh yeah cause you a d ick. :P
  8. Maybe Pete just doesn't like you. :rolleyes:
  9. Still seems to be a air in line issue, Did you bench bleed the master before install?
  10. Yes both good. 4 link will bind before 3 link. But not nothing to shake a stick at unless your running for mad flex. 4 link is common for those more dd weekend getters from around the boards gives some a better sense of control out on the highway.
  11. I ran the RK 3 link setup on my XJ and loved them. Bolt on but a few tack welds are suggested and you can't go wrong with them as an ungrade to an exsisting lift.
  12. Yeah sorry to disappoint you. :{ Well one side done today, new wheel bearings and seals, new brakes and fresh joint installed on the passenger side. Had some slop in the bearings, but it was time for a overhaul anyways after the abuse of the 40s. Now got to find me another set of axles for drivers side as after a closer look the inner shaft did get twisted a bit that the ujoint won't sit right. But with that the plan is to upgrade to some yukon shafts and joints perhaps a tax refund gift to myself. ;).
  13. Easy now Wade don't get all happy and ready to buy my rig now, talking about redoing the front cosmetic wise. Time to pretty it up a bit to match the bling bling.
  14. Yes axles came with 3.07s gear with 5sp 4.0 combos.
  15. So how you like them? how did you spot yours? For me I spoted them at the front of the back tires and the back of the front tires so I had a direct line of sight with the spot for when I'm looking out the window I can easily see what my tires are driving over or on.
  16. Ok so is this the answer to the empty but full tank of gas dillema?
  17. I have the same issue. Can we just swap the wires being only two and it read right? Seems that would be to easy....
  18. Hit up Keith Bailey at offroad connection over in fultondale.
  19. Was I to get a email confirmation or anything?
  20. steering box brace helps a lot. Installed one after ripping my box off twice. Even had it plated but sheared the bolts. No issues since other then a bit of stiffness from the one side.
  21. I have signed it and shared it. :D
  22. Brake line still in good working order. I make them long enough so if I drop the caliper the weight of the caliper will not break the line as it will hit the ground before it does. Lol lessoned learned.
  23. Image Not Found Image Not Found Image Not Found Image Not Found
