Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    Seriously?
    I don't have money or property so there's a natural limit to the number of MJs I can own at any one time. :(
  2. these issues needed to be overcome: this is max flex with the awful poly bushings More photos than you can shake a stick at here: www.picturetrail.com/petermontie
  3. flex can be atrocious if you use anything but beat up rubber C-bushings. the coil buckets don't line up quite right with the coils the track bar hole in the axle likes to wallow out the control arms hang down pretty bad On the plus side there's no need for a swaybar. :D
  4. I was sick of smelling burning oil. :D
  5. I like it. but it's not for everyone.
  6. sometimes 1/4" may seem more prudent than overkill...
  7. It means that you should probably stick to the 3/4 ton truck axles. :D
  8. 79 F-150 will have the cast-in radius arm monts. really only good if you're going with the radius arm suspension too.
  9. don't touch that 2.8. Buy a 3.4 and rebuild it. The castings and inner oil passages are vastly superior in the newer blocks. :thumbsup:
  10. good choice on getting the folding type of crane. :thumbsup:
  11. what's this "emission test" you guys keep talking about? :D
  12. close. turns out it actually occurred in 1997 in Michigan. :thumbsup: http://www.snopes.com/humor/letters/dammed.asp
  13. I'm assuming those are canadian numbers, but 450 does sound high. When do we get to see pics? :D
  14. Lookin' good. :thumbsup: Make sure you find the water leak before putting your carpet back.
  15. dunno. you should still be able to negate all sigs.
  16. firefox + adblocker = zap any photo you want :D
  17. are you using Explorer or Firefox?
  18. he's not hiding, he's stealthily sneaking up on his next victim. :D
  19. I clicked on the image to see the larger version, then right clicked and choose "copy image location", then pasted that here with IMG tags. The smaller image will likely never work.
  20. Pete M
    Seriously?
    Had an epic setback a few years ago due to illness and so I'm a bit behind where I want to be in life. :wall:
  21. One of them is probably Chuck Norris.
  22. Pete M
    Seriously?
    I'm an olde fart at 33.
