pug
Everything posted by pug
  1. Tried bleeding the air out off lines. Still same problem.
  2. The last couple of days transmission has being hard to get into gear. I pump the clutch pedal stiffens up then will go into gear sometimes. Master cylinder is full clutch master cylinder and clutch slave 1yr old. Any ideas 1990 2.5 ax5 thanks
  3. Has anybody else had bad luck with the banks torque tube. This is going to be my 3rd one. Motor mounts transmission mounts all exsauste hangers are good. Keeps cracking in the same place. thanks
  4. Perry mo---Mark Twain lake
  5. pug
    3/8
    Local hardware had one $12. worked great. thanks
  6. pug
    3/8
    3/8 pipe thread
  7. pug
    3/8
    Ok will try local parts store thanks
  8. pug
    3/8
    Is it a standard tap i can get at auto part store or hardware. thanks
  9. pug
    3/8
    Is there a differance between 3/8 thread bolt and a 3/8 pipe thread bolt. thanks
  10. Yes it is a gauge not a idoit light. Gauge works it just leaks from the sender. Does anyone know what the size bolt would fit in there until i can get a new sender. thanks
  11. Yes just wrapped it once.
  12. The teflon did not work. I can tighten it down pretty snug wants it gets under pressure starts leaking. Then starts cutting out and backfiring because of cps is getting wet.
  13. What kind of sealer and it is going to be hard to get surface dry. I guess the washer is a bad idea. thanks
  14. How far does the switch need to be down in the the block. Mine is strip at the top of it was going to put a washer on to keep from leaking until i can get new one order. 1990 2.5 thanks
  15. I have rockkrawler 6.5 coilsthey are starting to bow out. I guess thats what it is called and new tires are starting to wear yes i did get frontend alliend. thanks
  16. What is the best coil spring to buy for a 8 inch lift for a mj.thanks
  17. When i add the extra leafspring the clamp that holds the leaf together will not be tall enough. Do i need to have these clamps. There are two clamps one at each end of the spring pack. thanks
  18. Thanks for the link.
  19. Ok thanks
  20. I might be getting a slider finaly. Just wanted to make sure gaskets are the same. Is there a link on how to install or is this something a glass company should install. thanks
  21. Finally put on my new 31x10.50 15 km 2
  22. Got a email back. They said next week i hope so
  23. Is there rubber gasket the same for a slider as a full back window.thanks
  24. Still have not received drop brackets order last monday. Has anybody else order from rro and had problems. thanks
  25. Sometimes it backfires through tbi. Then sometimes it runs like there is nothing wrong for 3 to 4 days. I just changed o2 less then 3 months ago.
