pug
Everything posted by pug
  1. What kind of damage can a rod bearing do internally also will replacing rod bearing work or be a waste of time. I think they said it spun the bearing. 1990 2.5. thanks
  2. Just happend today i bought another engine 180,000 on it runs good don't know if i should rebuild or run it. Got your message if i deside to get rid of it you can have it. Maybe i will know something when i drop the flares off next week. thanks
  3. Is there a link for removing the engine. 2.5 1990 would rather just pull the motor. Motor went from ticking like lifter to loss of power to loud knocking on the side of block. Shut it off and i got it towed home. thanks
  4. pug
    WTB Bumper 86 MJ
    I have a 88 black bumper free. P/U only needs end cap.
  5. pug
    computer chip
    slrmotorsports.com I thought he sold them sorry. He is just a distributer. Still under a $100. for a chip is not to bad
  6. pug
    computer chip
    http://www.stu-offroad.com/siteindex.asp has anybody heard of this company good or bad. $70.00 for a chip is cheap
  7. So the bottle is different. My 98 with 4.0 has a cap on radiator and overflow bottle. Looks like same set up as the 2.5. I am confused on what a open and closed system is then.thanks
  8. I am not going aftermarket bumper just something simple. Were i can still use licene plate light and licene plate in factory location
  9. What is the differance in the bottles besides the size. thanks
  10. Can i use a newer style overflow bottle instead of the big bulky one. I am converting over to the newer style winshield washer tank inside fender and the factory overflow bottle is in the way. Its a 1990 2.5. thanks
  11. It is spot welded on the bracket to the frame in about 4 spots. I don't understand why it has the bolt going through the brackets and frame. I am not worried about the bumper it is bent up and rusted. Could i cut the bumper off and use remainder the bracket to tie into.Sorry no pictures
  12. Went to take o rear bumper today and po welded bumper and brackets together. So i was going to take off from the frame brackets are welded also. My problem is i can't get nothing up there to get the welds off any ideas. It is a stock bumper and brackets. thanks
  13. How was the bedand was it swb. thanks
  14. Time wise how long do you think it will take. It took 1.5 hrs to replace oil pan and rear maine seal on my 4.0. Leaking pretty bad on the sidesand front .thanks
  15. Do you have to remove starter to remove oil pan and is there anything else i need to do gasket sealer etc. thanks
  16. pug
    jy
    Any good junk yards in lake of ozarks area. Will be down this way october 6 through 10. thanks
  17. Thanks factory cables are cheaper then the 8.8 cables.
  18. What e brake cables do you use. The 8.8 or the factory d 35 cables. thanks
  19. I am going to do the fender flares and bumper end caps. thanks
  20. Will hurculiner or any type of bedliner stick to plastic. thanks
  21. Thanks nice and cheep. Trying to stretch xj end caps around the bed of my mj. Only need to go about 1/2 inch. don't care antidisestablishmentarianism it looks like putting bedliner over them and flares.
  22. Thanks i will try.
  23. What will heat up plastic to strech. I don't want it to melt though. Any ideas thanks
  24. Has anybody used thishttp://www.eastwood.com/autobody/seam-sealer.html
  25. Thats what i was looking for. thanks
