pug
Everything posted by pug
  1. how do you bypass and will it damage the motor. thanks
  2. Can a egr valve be cleaned or just replaced. thanks
  3. Just installed rebuilt motor was ideling and running great. Now since its getting colder out idels and backfires through throttle body only when i first start up in the morning or sitting more then 8 hrs after it warms up it runs great. Any ideas 1990 2.5 thanks.
  4. You can have valve cover if you want it i even have a gasket from rebuild kit. Just let me know.
  5. Rubbr or poly for leafspring and shackel bushings.thanks
  6. You might try yanceys in perry/columbia. I bought a 1998 alluminum cover for $25.00 back in july make sure you get the bolts though. I got one not the best of shape it doesnt leak let me know. Did the egr tube and throttle body work for you.thanks
  7. I did a search could only find for 4.0. Is there one for a 1990 2.5. thanks
  8. I drilled out then tapped worked great. thanks
  9. Will do thanks
  10. 6 quarts in a 2.5 with 10 oz of brake in additive.
  11. Yes checked when i got back only 5 miles. Then checked about 1/2 hour later.
  12. Put in rebuilt engine added antifreeze oil etc. Took out for test drive everything was good when i got back checked oil it was a quart low. I this normal no oil leaks made sure dipstick was all the way down also. thanks
  13. if i drill out were will the metal shavings metal shavings wind up. Any place that would damage bthe motor. thanks
  14. Sorry 2.5 it went from bellhousing to i don't remember. I didnt do like you are supposed to do when you pull motor and mark everything.
  15. Does anyone have a picture of the bar that goes from the bellhousing to the motor and what is it for. thanks
  16. yes it was. He said somebody came took some parts off of it. Also said anything i want i can have. Was raining after work didnt want to be out in the rain. I did see the manifold and egr tube when i drove by. let me know if you still need
  17. I will stop by tomorrow to check its by the house. Its a little hole in the wall scrap yard at someones house
  18. A day late had one took to scrap yard.
  19. pug
    WTB egr tube
    going to scrap monday still need part
  20. I went to take off switch and it broke off flush with cylinder head. Any ideas on how to get out. thanks
  21. pug
    WTB egr tube
    Still need egr tube. Taking motor and everything else to scrap monday. Thanks
  22. pug
    WTB egr tube
    Tube is still on intake manifold make offer. I get off work at 3:20 pm m-f. thanks
  23. pug
    WTB egr tube
    I work in Mexico monday through friday go to lunch from 12 to 12:30 pm. Just let me know a time. Are you an elk or just a volunteer. thanks
  24. pug
    WTB egr tube
    Yes Perry by mark twain lake. Will be in mexico tomorrow morning just let me know if this is closer then perry.
  25. pug
    WTB egr tube
    I have the tube it is still connected to intake. Let me know if you still need it. Were you at in missouri.
