pug
Everything posted by pug
  1. I got everything spliced together everything works. I just wired 2 wires wrong. When turn signal goes on left or right only one part of turn signal works on the front. Then when i turn off it comes back on. I thought i read you don't use one of the black wires . thanks
  2. Is there a link still on the how to wire front header panel and headlights. thanks
  3. Just curious what is the purpose of the shock
  4. I guess gears is my best bet then.
  5. Do you know if anybody makes performance cams for the 2.5. I thought i saw a link begining of the year that said would not open till spring. They made aftermarket cams for 2.5. thanks
  6. I was going to use the block from the 88 then transfer everything over from the 1990 if i could. Is this possible. thanks
  7. Parts that are good front and rear axels, transfercase, rear driveshaft, header panel with all side markers, hood, tail lights. both side glass. The bad all rusted out floores bed cab. I still need to fined out what gears are in it if i can get him to let me open front diff were would it be marked for gear ratio.
  8. If i get this truck its got one on it looks pretty good shape.
  9. Were would the casting number be.
  10. The seller changed his mind. Now he wants $300. with out motor but everything else. Does this still sound like a good deal or not.
  11. I wish it was that easy. don't have atrailer also needs wheels and tires. I see that you live in camdenton. I will be down that way 1st week of october fishing.
  12. What ever came with 4.0 auto. The truck i am looking is all rusted out 2.5 runs good speedo says its got 180000ish on it tc is good trans hard to shift into 3rd gear. Interior seats door panel rough light are like brand new same with the tail lights. Hood and front header panel is good. Just one problem no place to keep.
  13. Did not know that. So would you keep the none cad axel (1998) if that matters or would you get the cad axel if it has 4 10. He wants $200. for whole truck.
  14. It was not engaged. Just spinned rotor and pinion turned. If thay are 4 10 could i change over everything from hp 30 to this axel or would i be better of saving my money and getting 4 10 in hp
  15. The truck is sitting on blocks no wheels. I can turn the disk brakes and watch pinion turn just don't know how to tell by turning rotor and watching pinion. I did turn tonight pinion went around 2 times to the rotors 1. If that helps. thanks
  16. How do you tell what gears you have if there is no tag and the owner will not let me take the cover off. I think it is a 1988 can't read the door tag or vin. Also i have a hp dana 30 would it be best to keep this or change over to other axel if it has 4 10. 1988 is a 2.5 5 speed 4x4. thanks
  17. I guess my question is what is the differance in the engine blocks from year to year for the rebuild kits to be that much different in price.
  18. I am not sure either. I thought $100. differance in price was alittle high.
  19. I just wanted to have a project for winter. My motor has 283000 on 2.5 still runs great . Just don't want to take a chance. I can drive my xj if i have to. I thought all the blocks were the same until i saw all the rebuild kits and prices.
  20. What is the different in years on 2.5 from 1988 to 2000. I am looking at a winter project on rebuilding my spare 2.5. When i looked at rebuild kits they are for all different years. I am going to change power steering alternator etc. from old to rebuild. There was a $100. differance in kits for the years . thanks
  21. long arm. thanks
  22. Anyone going september 10-12 at gateway international raceway.
  23. Does anybody have any pictures of custom crossmembers for mj/xj. thanks
  24. pug
    rc truck
    iI just saw after i posted.
  25. pug
    rc truck
    http://www.facebook.com/l/11394;www.rcn ... ial-honcho
