I have a 1998 231 4.0 ax15. When i turn or start to take off there is a clicking sound. I thought it was the axel joint or hub assembly so i replaced. Took out for test drive same clicking noise. Put transfercase in 4 high clicking noise was gone. Any ideas of what it could be. thanks
air filter is 2 weeks old and the pvc you are talking about is it supposed to be just a elbow or is it a elbow with some sort of valve in it going to the air cleaner.
I have oil in the throttle body. Started to run rough on the way home. I thought it was the manifold gasket again so i took of the air cleaner tube and seen the oil. Any ideas thanks
Changed manifold gasket today and yes it was burned out on the bottom. I drove around all day no ticking parked it for about an hour started ticking again. Tighten everything down again drove around the block no ticking. I let it cool off went to get something to eat started ticking again. Haynes manual says to tourqe 22lbs. Is this correct or am i doing something wrong. Thanks
I have a 1990 2.5 tbi. I have a exauste leak from manifold area it only ticks when higher rpms so i am thinking it is gasket. My question is if it was a cracked manifold wouldnt it tick at all rpms.
I was bored today so desided to switch shocks from left side to right side. Drove acouple miles started nose diving on the side i switched shocks. they are doethch shocks. Any opinions what new shocks to buy. thanks
I will try to get some pictures. Shockes are about 3 months old. Also there is nothing bolted to the factory upper control arm mounts on the axel left ar right side
I have the two lower long arms. Then for the third arm back then they called it a tourqe arm. It goes from middle of drivers side long arm to the coil spring base to bracket that is welded on. Sorry i do not pictures
I have one of the old long arm kits the 3 link. The flex is awsome. Over the last couple of months i have noticed the front end wants to nose dive on the passenger side I was wondering if i could put upper control arms back on in the factory location. Would this help keep the front from nose dive.
