pug
Everything posted by pug
  1. I have a 1990 2.5 full gauges. With in the past week i noticed. Once when the gas gauge gets about half full it starts bouncing around .Then goes to full and stays. Is this normal for this year of vehichle
  2. Just orderd one $50. includes shipping from quadratrac.
  3. I have a plastic valve cover.
  4. Thanks for info. Is there any way to fix this problem are do i have to buy a new valve cover.
  5. I have a 1990 2.5. There is thee holes on the top outside of the valve cover.1 for the oil cap, 1 for the pcv, and 1 for something that goes from vale cover to air box. My question is the baffel or what ever it is inside of the valve cover broke off. The one hole that goes to air box. It was hitting the rocker arms so i took it out the knocking sound is gone now i have oil everywere. Can i block this line off what is its purpose anyway.
  6. Dumb question. What is the differanc between metric ton springs the other mj leaf springs.
  7. pug
    Bolt pattern
    Thanks need spares for my mud terrains.
  8. Iwent on the web site looking for stock leaf springs. I didnt see anything. If you sell them could you give me price and s&h to 63010. thanks
  9. pug
    Bolt pattern
    1998 xj wheels. Will these fit on the mj.
  10. Is there any place that sells stock height leaf springs. New
  11. Just watched snow angels with Kate Beckinsale. There is a lifted mj roll bar duel exaust good shape.
  12. pug
    Plastic welder
    Sounds like it is going to be a fun project for me.
  13. pug
    Plastic welder
    Is the welder electric or air. It says max 15 psi so how would it get heat if it is not electric. I have never even seen a picture of one. Just read about them.
  14. pug
    Plastic welder
    Do you have to cut the plastic. Then melt it together or doesit cut to.
  15. pug
    Plastic welder
    I wasnt realy worried how they looked. Just didnt want them to fall apart. I will put herculiner or something with a texture on it.
  16. pug
    Plastic welder
    Has anyone used one of these. I was going to buy one to try on the 97+ fender flares for the bed.
  17. Is there a link or does somebody have some pictures.
  18. Will the newer lenses work on a mj.
  19. I have amother question. Is ther a write up on how to mod the rear fender flares to fit.Also what about the tailight lenses.
  20. Well i got everything on.I thought the wire harness was going to be a pain. Turned out that was the easy part. I would post pictures but i do not have a camera. Thanks again
  21. Does anybody know if i can just plug in the 97 harness to the 90 harness without splicing together.
  22. Yes that is all i am replacing. The two front ferders and header panel + the new wire harness.
  23. What will i have to do to change fenders and the header panel.
  24. Is anybody going to be around lake of the ozarks 10-1-09. I'm going to be down for afishing tournament. I will be busy the rest off the weekend.
  25. Is the 97+ cherokee same as 96 and older.For the fenders and header panel. i know the wires are differant for the header panel. thanks
