pug
Everything posted by pug
  1. Got bolt out without messing up bushing. Next question I am wanting to add 4wd mj rear spring and add the 2wd main leaf. How far up do I need to cut 2wd main leaf
  2. I got the bolt out today. Had to cut flush with spring bushing. Now the remainder of bolt is stuck in the metal sleeve. What else can I use to replace sleeve?
  3. OK thanks
  4. Any idea how to get rusted bolt out of leaf spring bushing.
  5. Yes on the pin said it had to be notched. Yukon gear recommend the pin also. Will have to get a carrier for the front.
  6. Any opinions on Ford performance gears 4:56 part# m-4209-88456. Will I need to buy the cross pin also part# 8002791. Thanks
  7. Yes I replaced Dana 35 for a ford 8.8 and the front is out of a 1998 Cherokee hp. So it looks like 4:56 is what gears i am going to get. Just need to find out what brand get.
  8. Oops on 4 10-4 11 reply. What brand of gears should I buy for 1998 8.8 and 1998 d 30.
  9. They are factory 4 10-4 11.
  10. So what brand gears would you recommend. Rear is 8.8 front is a d 30.
  11. Yes sir. I was thinking about 4 88s just don't want truck running high rpms and still want to be around 15-16 mpg
  12. On the flats 70 mph all day long 18-19 mpg. Incline downshift to 4th gear. Pulling trailer is all with in 5 miles no hwy driving but some hills
  13. Tire size is 31 10.50 15. Not going any bigger daily driver and use to pull 6x12 trailer with zero turn and walk behind mower. Would 4 56 make that big of a difference pulling. also would 4 88 be to low for highway driving without trailer.
  14. 4 10s not sure whats up front. No on transmission. Getting help on swap
  15. I have a 1990 2.5 ax5. 1 should I just get gears installed and rear main seal fixed $1500-$2000. 2 just install 4.0.
  16. pug
    1990 2.5 Tb
    Correct tbi 2.5. How much and do you have a picture. thanks
  17. Were the yellow spring is. Its the bracket that holds in place throttle cable hooks on to. Want to know if I can spot weld bracket to the pin that goes through spring to bracket. there is about 1/4 of play causing high idle.
  18. It is a tbi . There is a lot of play were cable hooks on wanting to know if it can be fixed. Need a picture to show were the play is at
  19. pug
    1990 2.5 Tb
    wtb 1990 tb for 2.5
  20. I replaced wire harness to iac. Started up idles good 700rpm drove about 30 miles still good. Went to work still good drove home idels 1000rpm. looking tb looks like weld broke were throttle cable hooks on that opens up butterfly. Does anyone have a picture of a 1990 2.5 tb. I can show were it is broke. thanks
  21. I did notice today one of the wires to iac motor was broke. So I unhooked didn't change anything also smoke was coming out of tb when I shut off. will replace fuel filter and tps has being replaced in last 6 months. thanks
  22. New thermostat 195. Yes truck is heating up within 5 min
  23. Driving to work Monday morning about 5 miles from home truck starts bogging down and back fires through tailpipe. Pulled over won't start. I take of tbi cover starts up and drive to work (20miles) no problems. I get off work starts up drive about 5 miles same thing happens. Its being doing this the past 3 days any idea what it might be. 1990 2.5 tbi ax5
  24. Have a couple questions. 1 how much do you save. 2 what is factory invoice. 3 can you do a trade in with employee pricing..thanks
  25. The coils are 4-5 years old. Never bowed before brackets
