pug
Everything posted by pug
The spring i am talking about is a fork pivit spring. Goes on opposit side of external slave cylinder on the inside of fork. Hope i didnt make this confusing.thanks
External slave. There is some springs that hold the throwout bearing to the fork inside the bellhousing
Thats what i was thinking also can you buy the spring that goes on the throw out bearing or do they com with the new clutch kit. thanks
transmission front seal i guess because whole inside of bellhousing is coverd with oil.
Throwout bearing went out no big deal. I did notice a lot off oil in bellhousing clutch disk is dry rear main seal is dry. Transmission shifts into gear smooth. The main shaft that goes into back of the motor has a littlle play in it would this cause a worn seal. thanks
Yes trailer lights were working properly.
Not forsure it was the one for the hazards and fuel pump. I think a 20 amp fuse Has being running good ever since.
I just bought a new trailer for hauling lawn mowers drove it 200 miles no problems. I get it home unhook it no problem leave to go out of town for the weekend 250 miles away tbi backfires then dies no flashers nothing. Try starting it nothing but will turn over. I am thinking its the cps thats not it. look under dash at fuses blown fuse. Replace it and being good for 500 miles no trailer hooked up. 2.5 ax5 4x4 any ideas thanks
Short notice doesnt help either. I think there is a couple more events this summer will post when i find out. I know they have a website i hope i am spelling this write www.hannibalrocks.com. thanks
How about a meet and great may 19 at hannible rocks for rrock. Will be driving up from st.louis about 2 hrs away.We have a lake house up there on Mark Twain Lake if anone needs a place to stay or stop by. thanks
No keeping bfg 31x10.50 15
The mechanic didnt say he wouldnt put them. He just said he thought it was to low of a gear.I just want something with a little more power and mpg.
Motor has only 1200 miles on rebuild. So motor is good. It has power just not going up hills or pulling the trailer. I have the gears just don't know what ratio to use 4:10 or 4:88
Just got home from fishing trip branson mo. 4:10 and a 4cyl not very good for going up hills had to downshift to 3rd gear. Good thing i wasnt pulling a boat. Gas milage was getting 18.3 mpg doing 65-70 mph on 18 gallon tank if thats what size tank i have.For work pull a small 4x8 trailer with walkbehind mower not much weight just no power going up hills and sometimes mulch.thanks
Went to drop truck off monday for gear install. Mechanic said he would not use 4:88 he would use 4:56. I have 8.8 with 4:10 now don't know about front. I have a 1990 2.5 ax5 and 31x10.50 15 not going any bigger tire size.Just use as work truck sometimes pull a trailer with mower and mild trail rides. Any help thanks
Ok thanks will try tomorrow.
Installed 91+ thermostat housing today doesnt look bad. Only problem i have is a very small leak were temp switch goes into housing. The relay i order says do not use teflon on switch or it will not be grounded any ideas. Ismurphy i have a new pre 91 housing just don't have the tap for 3/8 npt.
Nice write up lsmurphy. Was looking online at oreillys 91+ thermostat gasket has same part # as earlier gaskets. So whats the differance in the thermostat housings between 91+ and earlier years. $41. for pre 91 or $12. for 91 +. The 91+ has 3/8 npt threads allready would make alot easier if this would work. thanks
I guess my question is. i want to have switch hooked into thermostat housing so when coolant gets to 195 temp fan will kick on. i allready have relay and cicuit breaker. The temp swith is wong size. I didnt know there was a differance between 3/8 and 3/8 npt
Whats the differance in housings from 86-90 and 91+ on 2.5. thanks
airspeed do you have a part# for you sending unit for thermostat housing. thanks
would this work. How do i get a picture on here of this product Speed 3101 Fan Control Thermostatic Kit & 50 Amp Relay Brand: SPEED UNLIMITED Our Part Number: S003101 Manufacturer's Part Number: 3101 UPC: 830017009419 Condition: New
http://www.xjtalk.com/showthread.php?t=5646
