8
Everything posted by mjeff87
You comin' over on Friday? Did the 350 starter work or not? There's a 4.3 with a starter on it down at the 'yard....if you can't make it over, I'll pull it off for ya before it gets snagged. Jeff
Exhaust manifold install probs
mjeff87 replied to RedBullMJ's topic in MJ Tech: Modification and Repairs
It does sound like a vaccuum leak, likely the intake manifold. Did you get all the manifold bolts back in, and tight? The other component you are mentioning is the EGR valve. It is normally closed at idle and on acceleration....it gets a vac signal from the solenoid (follow the vac line out of it, across the back of the engine to the passenger side, and you'll find the solenoid, ECU controlled). Sounds like your EGR valve itself is stuck (partially) open. At idle, with the exhaust tube connected, it should not be allowing exhaust into the intake. Sounds like you have a couple problems. Jeff -
And he used the leftover scrap from the cage to make the lift blocks.. :roll: crooked-assed shackle on the drivers side rat's nest of a winch cable on the drum got fairlead???
Yeah, MJ's are driver drop. But, that's not a problem!!......that beauty uses some kinda new-fangled invisible front shaft. You can just run it straight across the oil pan, and it won't interfere with anything :D Jeff
Saw this on another forum. It's so good I had to share with y'all...... http://cgi.ebay.com/ebaymotors/Monster- ... dZViewItem :eek: run away......fast..... Jeff
Jeep dealership IPL's and parts manuals
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
FWIW....this is what I had (wrong): Image Not Found but THIS is what I needed (what a contraption of a bracket, huh? :eek: ) Only $5.44 at the local U-pull :D Image Not Found Jeff -
Aftermath of a Dead Alt.
mjeff87 replied to Kenosha Warrior's topic in MJ Tech: Modification and Repairs
Do you have State Farm by any chance? When I converted mine, they still listed it on the policy as a 2WD, because of the VIN #. They tried to enter it as 4WD but the computer system wouldn't let them :nuts: I penned a letter and had them append it to my file stating that I had done the conversion (with all OEM parts), just in case something would ever happen. Trying to argue with them was pointless..... Jeff -
yeah...like I said...give it some time, and all systems should revert back to normal. I've no idea why, it's just the nature of the beast :) You are now A #1 certified at alternator replacement! :cheers: Jeff -
Just got done putting a new heat pump in (just the outside unit...$1300:(), and am about to replace the water heater. Just when you think you have some "Jeep" money...something always comes along.. Jeff
Check the floorboards like Oiz said. Check the bed above the wheelwells for rot. Crawl under the rear of the bed and inspect the brake lines (they're apt to rot out in the back). If it's a manual tranny, look inside above the fusebox at the back end of the clutch master cylinder and see if it is leaking (and dripping brake fluid down onto the fusebox), and if it has an internal slave cylinder, check the bottom of the bellhousing to see if it's wet with fluid (means the slave is leaking, and you have to pull the tranny to repair). Pop the airbox lid and inspect the air filter...if it's soaked with oil, the CCV system needs a good cleaning. Check the exhaust manifold for cracks/leaks (especially where the individual runners meet at the collector). None of these is a deal breaker per se, but if you see problems, you might be able to knock some $$$ off the purchase price (then post up on here what's wrong and find out how to fix it :;) HTH, Jeff
Congrats :cheers: I haven't had a car note since 1999, and I love it. (of course, both of my vehicles are piles, and have 170K+ miles on them :D ) Jeff
I am, but my MJ didn't come with AC originally. I have the compressor, compressor bracket, and extra idler pulley, but I found out the hard way that there are 2 different types of alternator brackets for the 2.5....one with AC and one without. I haven't been able to find an '87-'90 2.5 with AC down here in the junkyard to pull parts from, so I'm gonna see what they cost from the dealership (gaaaah!) There's actually a main bracket, and two smaller brackets in the rear also, that I need. (what's worse is that it has to be '87-'90....the 91+ is a different alternator (externally regulated via the ECU) and mounts in a different location). Like looking for a needle in a haystack.... -
I do believe that Wellsville is closing, or already closed. Maybe Nate will chime in on that..
Interior and dash lights, parking brake release
mjeff87 replied to ChiefJosh's topic in MJ Tech: Modification and Repairs
Then the 5A fuse is probably ok (check it anyway). The engineering gurus at AMC designed that dual circuit like that on purpose....the dash lights go out if the brake lights go out, to let the driver know there's no brake light illumination in the rear. Kinda of a "safety feature" of sorts... And I feel your pain on the garage. I don't have one either. Those coin-operated wishy-washy car washes work in a pinch, tho :D (especially when it's raining 'cause there's usually noone in the bays) Jeff -
Additionally, there's a small 5A fuse in the upper right corner of the fuseblock (think it's labeled "INST"). Check to see if it's blown. If it's ok, wiggle it around a bit (pull it out slightly also) to make sure it's making good contact. I fought with my dash light for about a month one time until I discovered that one out :D Jeff -
Need parts illustrations/diagrams/part #'s for your Jeep? Go here.... http://www.xjjeeps.com/tech_reference.a ... ion=2&ID=0 FYI...the 1988-1990 manual is mislabeled. It is actually 1987-1990. Lots of info on lots of models (J series, XJ/MJ/ZJ/YJ/CJ/TJ......) I finally found out the part number for the alternator bracket I need to install OBA on my MJ :D thanks to that site! Jeff
If y'all don't make it too far away from PA, I might could maybe make it. Jeff
I have new (to me) leafpacks to go under the MJ, but want to replace the stock bushings. Any recommendations? TIA, Jeff
I'm heading to the 'yard tomorrow...I can look for one for ya if you want. Last time I got one (was a couple years ago), it was around $10. Does it have to be from a 5 spd? You can't swing a dead cat without hitting a billion 4.0/AW4's, but the manuals are sparse (not to say there aren't any, though...) Jeff
You should be getting about 13.8-14.2 V with a meter off of that alternator. -
Oiz.....no man who drives a Jeep, anywhere, is allowed to make a statement like that :chillin: Jeff
Here's our newest one: http://www.comancheclub.com/forums/prof ... file&u=761 Jeff
Give it a little time, and see if they come back. When my alt went, and fried my battery, all sorts of weird things were going on in the dash (and the wipers, and the radio, and the heater.....). I did a roadside repair on the interstate and got it fired up but the bizzare things were still happening, especially the wipers. I had 40+ miles to drive it home (in a monsoon of a rainstorm :cry: ), and after about 20 minutes into the trip, suddenly everything sprang back to normal :nuts: How long have you run it since the new installs? Jeff -
:roll: Oops...yeah. Forgot about the crosspin :oops: Jeff
Not too difficult. Pull the diff cover and drain the fluid, push in the axleshaft you are replacing from the hub side (it should move in about 1/4"), which will expose the C clip (you might have to spin the shaft around a bit to access the back side of the clip). Pull the clip out with a pair of needlenose pliers, and pull the axleshaft out of the housing. While you have the shaft out, do not spin the carrier, or else the spider gears will fall out and you'll have to put them back in. Slide the new shaft in carefully, so you don't rip the seal in the tube, until it seats fully. Reinstall C clip, replace cover and refill with new lube. HTH, Jeff
