mjeff87
    8
Everything posted by mjeff87
  1. Monroe part #32207 Jeff
  2. couple tips FWIW.... DON'T use an air impact to tighten the clutch cover bolts....use a torque wrench in steps with a cross-pattern DO use locktite on the clutch cover bolts DO replace the slave while you're in there, if it's internal. Not a bad idea to replace the RMS and check the welch plug in the back of the block and replace (but you'll need to pull the flywheel to do this) DO replace the flywheel and the pilot bearing if they are anything less than 100% Jeff
  3. That's what I planned on doing, but didn't happen. Drove home shock-less. It was, in a word, unsettling.....but I made it fine. Not sure about your situation since you already have built in lift (AAL or otherwise), but I can tell ya from experience that stock length shocks with an SOA will not work. Let me look in the morning to see if there's a part # on the shocks I got. I know they are Monroe's, and they fit a Toyota application, but I can get more specific detail when it's light out. IIRC, they were only like $15-$20 each, not bad for a temporary work-around. Jeff
  4. I may be from the 'burgh Don.....but even I have some standards I won't lower myself to :ack: Bud Lights and margaritas (with Herradura tequila) for me Bad thing is I have to be up and on the other side of the state Monday morning for a work meeting. Pray for me, will ya? Jeff
  5. Bookmarked :thumbsup: Already got the eats lined up for the game, but I might just whip that up for the meet/greet and new house party this summer :yes: Jeff
  6. that ROCKS! Jeff
  7. Palomalu! :rotfl2: (sorry Brent :rotf: ) Jeff http://nl.youtube.com/watch?v=At69PJ3ymIg
  8. dang Rick, sorry to hear that......my thoughts and prayers are with you. Take care buddy. Jeff
  9. you know why dem gators are so orn'ry?? dey got all dem teeth an' no toothbrush.... Nice pics Rich, good to see that us MJ brothers roll in more than just mud and rocks :cheers: Jeff
  10. Jim Henson.....what a creative mind and a visionary as well. Hindsight being 20-20, can you remember even a fraction of the talent they had on the show back in the day? Alice Cooper, Johnny Cash, Paul Simon, Liberaace......ad infinatum.. a gold mine, and all we saw were puppets at the time :nuts: Strikingly familair to Hanna-Barberra of several decades before. We were all listening to classical music and didn't even know it :yes: Jeff
  11. http://www.youtube.com/watch?v=YevYBsSh ... re=related If you don't know it......you're too young ;) Jeff
  12. :agree: yoi and double-yoi Taz..... damn near got me misty-eyed with that one. Jeff
  13. I'm in for at least a hoodie and a couple T's.....lemme figure out what I want and I'll be back to you in a bit. Jeff
  14. Give it up for the Pop Rocks!!!! http://nl.youtube.com/watch?v=DkTflRQzCZg Jeff
  15. welcome to the club...stay away from the tan couch in the corner, and you have to buy us all the first round :cheers: Difference on the trannies is pretty straightforward looking at them. If yours has a clamshell casing and has an obvious center rib running the length of the body with a bunch of bolts on it, it's a BA10/5 (bad). If you don't see the center rib but rather three seperate sections bolted together lengthwise, it's an AX15 (good). I'm sure someone will post up good pics of what I'm describing....I just don't have any readily available. SYE's aren't really needed for driveshaft vibes on MJ's due to the longer wheelbase and subsequently longer rear driveshaft length. You can more than certainly install an SYE to gain the advantage of a sealed output on the TC, but it's not necessary like it is on a XJ/YJ/TJ. You could run a later model 231 TC and get the same benefit of the sealed output, but you'll still have the slipyoke versus the fixed yoke. All depends on what you want to spend your $$$ on. Jeff
  16. oh hell ya :thumbsup: Jeff
  17. Lead......is that bolt-on SOA kit available for the D44 or just the '35? thx, Jeff
  18. Negative.....Renix is '87-'90. You can convert a 2WD Ax15 TO 4wd, but it's a fairly involved process and generally not worth it. Cost/labor wise, it's better to just source a 4WD version. They are the same transmission from the bellhousing back to the midplate, but the 2WD has a long extension housing bolted onto the back that you cannot bolt a transfer case onto. The 4WD version has a smaller extension housing bolted on with a flange to accept the transfer case. As well, the output shaft on a 2WD is much longer than the 4WD version, so you'd have to replace it as well when you tore it down to swap the rear sections. JeepCoMJ and a few others have converted 2WD AX5's to 4WD (essentially the same tranny, just a lighter duty version).....hopefully they'll chime in with the particulars on what you would need to do specifically to convert if you really want to. Jeff
  19. Don't go all Bruce Banner on us.......the Incredible CW!! :rotfl2: Jeff
  20. The Renix 'puter is the same whether auto or stick, it doesn't matter. But, if you use an auto harness you'll have to jump the NSS wires to get it to fire, and you'll have to splice in the backup light switch from the AX15 into the auto harness wiring. I've got the wires you need to do this to identified in my post. You'll also have an extra TPS connector in that auto harness, which you can either ignore (it feeds the TCU that you won't be using), or you can use an auto throttle body that has the second connector. Just plug it in....it won't do anything, but it won't hurt anything either. Jeff
  21. small world....my wife's father's family all grew up in 37, and her parents just moved into 40 ;) Never ran any trails up that way though....spent most of my time up off the Gray Run area, firetower, Mountain road and the gasline, down over into New Florence (game land #42). Jeff
  22. yeah, I'm talking about under the hood too......right beside where the HVAC fan motor is, up on the firewall. There should be two hard plastic vac lines coming out of a foam-type recatangular block....they are the lines I'm refering to. They control the valve that lets coolant pass thru the heater core: Image Not Found
  23. txv....now there's a term not often uttered. You do refrigeration for a living ;) ? Yes, those lines need to be connected (one should be pink and one black, but that's beside the point). There's a vaccuum operated valve that opens/closes the coolant supply to the heater core, and those lines control it. When you move the HVAC lever in the cab, not only does it send a vac signal to the plenum to direct air movement, it also sends a vac signal to that valve to open and circulate coolant thru the heater core (XJ/MJ only, YJ/TJ's don't have that and have constant flow thru the core). Connect one of your lines to the vac line that comes from under the battery tray (mentioned earlier) to provide the vac signal, and the other line to the diapraghm on the heater control valve. Then you'll have circulation thru the heater core, and warmth ;) Jeff
  24. Bear, I was looking at those pics, and I coulda sworn some of them looked like they were up off the LHHT, or out the Windber/New Ashtola way...... I'm from Johnstown, down in the West End. We need to meet up the next time I get up into town :cheers: Jeff
  25. I can't speak to the power difference between Renix and HO, but I can tell you that swapping the interior harness is not fun at all. It took me and Jerry about an hour just to get the interior stripped on the junkyard MJ I got the harness from, and we weren't being "gentle" about it.....if I were planning on reinstalling everything it would have taken quite a bit longer ;) I can tell you that the difference between the TBI 2.5 and the Renix 4.0 I swapped in is quite noticeable, and I'm very happy with the swap. Down-the-road plans for me include building a stroker and swapping it in at some point, but that stock engine has more than enough ooompfh for what I'll ever need. 4.56's with 33's, the thing was downright dangerous if you let it be. Jeff
