IDXJ
Everything posted by IDXJ
  1. I have already backed out my stops so my tires(35's) don't rub. I really don't want to back them out anymore and lose even more turn radius. I may take it out and put a small bend in the tie rod end in a press.
  2. :bowdown: :bowdown:
  3. So, I'm installing the JCR UTK steering system and Have an issue. The tie rod hits the lower tracbar bolt long before I get to full right turn. I shaved about 1/2 the head off the bolt but, still hits. The tierod is new and straight. There is no for/aft adjustment. Anybody else running this and have issues? How'd you fix it?
  4. Mine's Dirt Devil. Works for me.
  5. I ran one up to 250k and 33's with 4.56's. Never had an issue. I also got my MJ for dirt cheap cause the BA 10/5 went out twice in 100k. Swapped in an AX15....
  6. How many miles? Have you changed the O2 sensor? I had wierd problems kinda like yours and it turned out to be the sensor. Gremlins are a pain.... :fs1:
  7. In your write up(which is great) you reset the odometer on the replacement gauge after pulling it. I believe that is illegal about everywhere. Why didn't you just swap the speedo with the one you removed from the truck? I just did this swap and the repacement cluster had like 75k more miles on it. I just swapped in the old speedo.
  8. Yeah, the big gauge worked fine. I was also thinking it might be a bad gauge. I'll try the local JY. Thanks guys.
  9. Do the sending units interchange? I have a parts Chero. here that I can pull one from.
  10. I just did a gauge cluster swap on my '88 Comanche. The original cluster had gauges, not idiot lights. Just didn't have a tach. I got a cluster from an '87 Cherokee with gauges and a tach. Eveything works fine except the fuel gauge. The replacement gauge reads 1/2 tank when I fill it up. My question is: do the XJ's and MJ's use different gauges? Thanks.
  11. Don't be too jealous. this was about 3 weeks ago. For reference, the CJ has 36's on it.
  12. IDXJ
    Look what I got!
    Looks like a pair of sheet metal shears or a cutoff wheel could make that mod. :cheers: Hey! Easy there Lucky.... My XJ is my wheeler. My MJ is my driver.
  13. IDXJ
    Look what I got!
    My son's girlfriend had this made for me for Christmas. It's 19"x18" and cut from 10 ga. steel. Way cool!
  14. You're gonna have a real bad exhaust leak too if you don't replace that muffler bearing.
  15. Thanks for the links. I can see no reason to put the outer seal in. The one piece axle diameter is quite a bit smaller than the sealing area on the old shaft so, it won't do anything.
  16. Thanks for the links. I can see no reason to put the outer seal in. The one piece axle diameter is quite a bit smaller than the sealing area on the old shaft so, it won't do anything.
  17. I am going to replace the 2 piece shaft on my '88 and other than the shaft itself all I will need is a new inner seal correct? Anyone done this? I guess that both sides would use the same seal too? TIA. Dave
  18. I am going to replace the 2 piece shaft on my '88 and other than the shaft itself all I will need is a new inner seal correct? Anyone done this? I guess that both sides would use the same seal too? TIA. Dave
  19. But, I think they are 5x5 bolt pattern. :???:
  20. Ever since I put the 2-low kit in my XJ, I've not liked the shifter. When I'm wheeling I find that I am in and out of 2-low and 4-low a lot. I did not like the bend in the shifter that makes the handle horizontal in 2-high. When shifting the AX15 and the T/C I wanted the handles closer together. So, I removed the T/C shifter and cut the handle portion off. Then I welded a 3/8" bolt to the end that I had just cut. Ground the head of the bolt down for aesthetic purposes and painted the shifter. Re-installed it and put a new shifter handle on. Now it is within easy reach when wheeling. I really like this mod.
  21. Well, I went looking for the original post over at NAXJA and it has been deleted. The boys over there got extremely wound up so, it got shut down. Sorry I can't get you bigpimpinben's (multipurposemj)story that included cutting the tree down.
