Everything posted by 90MJext
I found this site for people looking for custom header(s). http://www.stainlessheaders.com/customheaders
I really don't know why they don't use their other "right". You have the right to leave the country at any time. to hell with being P.C.
typical, I'll check on this weekend, my daughter's house flooded (stuck toilet tank valve)
looks good, Bo did you get wet. we got done around 1pm with the floor.
it flooded south of here (Paulding Co.), so far everything is still good.
picked up my "new" intrument cluster, from a turbo coupe and will pick up the motor, tranny and wiring harness this weekend.
nice job, similar to what I did in my Grand Cherokee.
Found a white '86 longbed, 2.8, auto, column shift at Cagle's Junkyard today. the bed looks to be in good shape, outside of tailgate good, steel bumper good shape, pass taillight, 3 window slider. did not have time to talk about price. Contact information: Cagle Auto Parts 1139 Old Alabama Rd SW Cartersville, GA 30120 (770) 382-0199
pony tail
I'm good with the selected colors.
haven't posted in a while a little progress: cleaned up the ZJ power steering gearbox (awaiting paint), ZJ LCA (painted- done), pressed out ball joints (PITA), burned out axle bushing, Stripped paint on frt axle with aircraft stripper (awaiting paint) cut bracket off 8.8 (awaiting to be paint stripped) will post pics later
Started putting steering linkage together and grinding down old brackets on 8.8
Bill Brand '88 Sporttruck '90 Eliminator (under construction) Live in Cartersville Georgia work for Cartersville Police Department
99 Clutch Master Cylinder into 87 MJ
90MJext replied to 64 Cheyenne's topic in MJ Tech: DIY Projects and Write-Ups
nice work -
since you have silver on the list, check out "slate grey" it a fleet color. supposedly cheaper in price than automotive grade, not in quality.
Looks good
Thanks for the compliment. Been collecting parts: spring over conversion from Motion Offroad, thanks again all new steering linkage from NAPA. awaiting delivery 97 ZJ OHC, WJ LCA, ZJ V8 steering gearbox and front swaybar for 100.00 I've also had a chance to disconnect and start removing the Dana 35. More later
This was done on a '97 ZJ overhead console. The purpose is to more light into the interior without spending a lot of money. Parts needed console phillips screwdriver (to remove console) soldering iron solder LED panels, http://cgi.ebay.com/12V-Super-White-115 ... m153.l1262 shrink tubing Torx T10 bit plastic epoxy wire strippers needle nose pliers 1. I removed console from headliner. 2. I removed light housing from console, Torx T-10 bit, there are two screws on the front housing and three on the rear. Image Not Found 3.I removed the bulb. I used needle nose pliers remove the bulb contacts had to press in the sides. Image Not Found Image Not Found 4. I placed a LED panel into housing, running wires out the backside of the housing. Image Not Found when you are satisfied on the positioning, use a epoxy to hold it. 5. When I was doing the front housing I had to remove a section. before on the right, after on the left Image Not Found 6. I let the epoxy cure and then reattached the housings. 7. I cut the bulb contact off, and stripped and tinned a section of wire for each of the contacts. For the front the wires were 2 grey (switches) and 1 pink, the rear were 2 grey (switches) and 1 grey going towards the front. 8. I soldered the red wires together and to the pink wire (front) and single grey wire (rear). I soldered the black wire to the appropriate grey wire and shrink tubed all connections. front: Image Not Found rear: Image Not Found 9.Reinstalled the console. front Image Not Found rear Image Not Found rear hatch light (not done yet) used for comparsion Image Not Found results:the interior is a lot brighter and only spent $2.00 (w/o shipping) for LEDs and little bit of time.
Bo, Sorry for you and your family's loss. Bill
I'll put in $25
