Everything posted by SuperWade2
It must have been a thread off or something the last time I installed it....once I got it out, it when back in with no prob once I stuck the carpet back in....Probably a cheap chineese torx bit...the craftsman one held up OK (although I felt better knowing I could take it into Sears for a replacement had it broke).
Garbage...I tried to trim, and it started to fall apart at both sides...so it went away...
Just a personal preference...Not a fan of hooks... saw a cheap one snap and impale itself in the side of rig once a few years ago, scared the bejesus out of me and if it would have hit someone...well, that could have been the end of them... Most of the guys I wheel with use the safety thimble on their winches (which is also what I have on my Winch on my TJ) and I'll probably only leave the d-rings on if/when I go wheeling. The two that I stuck on there for the pic live most of the time in my Recovery Bag that I take wheeling. I have another 4 that I leave on my TJ all the time (2 front and 2 rear). Wade
Installed http://store.hicountryoffroad.com/Xtreme-Tow-Hook-Bracket-with-D-Ring-Mounts-_p_41.html#...
Got my D_ring Tow Mount point things installed. I still need to get a couple of the Pass side through bolts drilled/sleeved/instaleld, but they are both and the drivers side seem solid... And I did end up taking the lower air dam plastic thing off and trimming the lower edge of my flares. It was pretty beat up anyhow... I think it looks OK... I also tossed a fresh coat of spray on my front axle, and am about 75% done reinstalling my interior (basically just the seats left to go back in. Also bent my Sway Bar disco Pin on the axle out a little bit so I can actually get the disco on and off without a BFH. SW2
I'm running 2" Coil Spacers (I think it was a Rubicon Express Budget Boost Kit) that I pulled off my TJ and stuck up front on my MJ...works fine...
If that were an MJ with <400miles, the guys here would be on it like a fat kid on a cupcake...
1986 Jeep CJ-7 Laredo 369 Actual mile - $39995 http://dallas.craigslist.org/ndf/ctd/1453035324.html 1986 Jeep CJ-7 Laredo 369 Actual miles AS NEW NEVER TITLED, STILL ON MSO, YES YOU WILL BE THE ORIGINAL OWNER. Special ordered by Dealer/Collector, delivered new to a private collection in early 1986 and has been properly stored, maintained and covered since 1986. The 86 Laredo was the top of the line and the last year for the CJ-7 this is a special ordered Automatic. It is estimated that less than 250 Automatic Laredo’s were built in 86, also has two other very rare options, cruise control and factory cassette. The collector also requested that the top not be installed. He did not want any holes drilled into the body. The black soft top is still in its original factory Whitco box. To see all of the factory options please refer to invoice and window sticker. This is one of the lowest mileage and finest CJ-7’s in existence. We have the original certificate of origin (MSO), original invoice, window sticker, books, manuals, etc… It is as close to new as you will ever find. We offer worldwide shipping and financing with approved credit. We have specialized in 76-86 Jeep CJ’s for over 25 years this is without a doubt one of the finest in existence. This opportunity to buy an as new CJ-7 Laredo may never present itself again. Thanks for interest. VIN# 1JCCE87E4GT100785
How are the "OEM" Tow Hook Brackets connected? I can connect this one with the 1/2" hole in the back (which is there and sleeved) and the 2 bolts from under the frame at the swaybar mount. So I'd have 3 points of connection on the Pass Side, which isn't optimal, but if that's what the OEM brackets have, then I don't feel too bad. On the Drivers side, it uses the 3 through bolts for the steering box plus the 2 for the swaybar mount (plus 2 extra's behind the mount on the lower side), so that side should be good and solid. Wade
Well, I started looking at the Tow Hooks and while they seem to be pretty straight forward, my MJ doesn't have any of the 7/16" stock tow hook holes drilled in the frame that this thing is suppose to use. I don't really know how, without taking off the bumper, and fender and god knows what else how I'm suppose to get in there to drill new 7/16" holes for the through bolts. Any Advice? Nothing is ever as easy as I plan on it being... Sw2
