bmb5589
Everything posted by bmb5589
  1. Well I must have looked it up online wrong then I'm not very good when it comes to this stuff but I would like to do it and learn. What all would swapping a auto to a standard require I forgot to mention the new-used engine I put in the truck is a 2.5l out of a 90 jeep wrangler..couple more hp and torque pounds
  2. I have a 1986 jeep Comanche 2.5l custom just recently replaced the engine due to it taking a $#!& on me. The transmission has been leaking an did before the swap I replaced the front pump seal but it still is leaking. I have been told that the lines sometimes will gum up and I should have them flushed to see if that solves the problem. Where is the best and cheapest place to have a transmission flushed ( I live around State College Pennsylvania). I was thinking also about swapping out my what I believe is a TF 904 3-speed automatic transmission for some kind of standard transmission. If I did this what transmission should I swap with and how hard would it be to do a auto to standard swap?
  3. Paradise MJ it is leaking out of the bell housing it looks like I haven't took the time to really look at it though...the trans fluid builds up on the bell housing and drips off though
  4. I believe it is the TF 904 its automatic 3 speed and yeah that's a good call I should look at that and see...you would think the guy that worked on my trans would have looked at that $#!& though....
  5. I have a 1986 jeep comanche 2.5l that i recently replaced the engine in. Before i replaced the engine the trans leaked and it did afterwards aswell...i replaced the shaft seal on the front and it still leaks. Has anyone else had this problem and if so how did you fix it. I would love to get it to stop leaking trans fluid cause I'm always worried about it Thanks guys
  6. alright well thats good to know...i wish i had the money to drop a bigger engine in it but idk well see eventually right now i need to get it inspected
  7. ok thanks man i hope i got a good buy i just don't wanna have to put alot of money and time into the engine how much do you think the truck is actually worth?
  8. Thanks alot for the input and i hope that i don't open too big of a can of worms haha i need a vehicle that runs and is inspected! in this photo you can't see the damage to the driverside tail light i just snapped a quick pic the last time i was back home from college.
  9. I bought a 1986 jeep comanche 2.5l 4 cylinder custom edition 4x4 with a long bed from a family that had it on there farm. The truck has only 45,000 origional miles there is barely any rust on the body but there was a fender bender on the back left tail light and the sockets are dry rotted. The engine leaks oil i can see it burning on the exhaust where it comes out of the manifold and i think its possibly leaking transmission fluid. The dash lights don't work but the headlights work and it runs strong. I payed 400 dollars for the truck did i get a good deal? how much is the limit as to what i should put into it to get it inspected
