maddzz1
Everything posted by maddzz1
  1. Is it possible to put a small "required info" spot at the beginng of the title section? Also, people still can't figure out that their is a section for stuff that is not theirs, even tho it says "ebay, craigslist, stuff that is not yours" :shake:
  2. :hmm: So, if that really works that way, then certain members wouldn't have to worry about getting "time-outs" and go stand in the corner anymore, because most of us would not see what they type :dunno: I'm going to have to try that :brows: It works, I had a certain member on there for awhile. I hope it wasnt me due to not having an avatar. :rotfl2: After you posted that I tried to put one up but I think it was too big. I don't know how to resize it, I will check Taz's how to post again and see if I missed the resizing part
  3. Nice. I need to get the lame pioneer stickers off of mine.
  4. If its the same a the automatic there are two reverse torx bolts at the top of the bell housing. They are not easy to get at. You should replace them with regular bolts when you reinstall
  5. My bad. When you wrote M/T I thought you meant Metic Tonne package. :doh:
  6. If you only replaced back to the T at the raer axle, It sounds like you didnt replace the hard lines that go to the wheel cylinders. Is this correct? If so, That is probally where the leak is (possibly the wheel cylinder itself). Mine rotted away just above the axle near the wheel cylinder on my MJ and my XJ.
  7. here's a link to the FSM elec manual: viewtopic.php?f=9&t=12734
  8. I don't think any manual transmissions came with 3.55's, only automatics. Is there a chance the previous owner swapped the axles? None of the 6yl, M/T came with the 3.55's. LINK I didnt see that on that link. The only thing it said was that 93-94 XJ's w/ the tow package got 3.73's. MJ's werent made in 93-94. I think all MJ's with the automatic transmission (AW4) got 3.55's Someone correct me if I'm wrong about this.
  9. I don't think any manual transmissions came with 3.55's, only automatics. Is there a chance the previous owner swapped the axles?
  10. I was wondering if you had finished this up. It s coming along nice, looks like it will be very clean you button it all up.
  11. There is another site that has them too. can't think of the site name tho. It is a guys name or something. Someone must know it.
  12. Wiring schematics for just about any car radio wiring can be found here: http://www.the12volt.com/Default.asp?
  13. Good luck man
  14. You should put your location in your info. Alot of guys on here have stuff laying around they will give if you are local. Any 84-96 cherokee fender will also work if shipping is expensive.
  15. I just re-routed the column shift cable when I put in the floor shift. Mike (comanche87) did the same. It is a tight stretch but it works fine.
  16. Ian, I have one at the house that you can have. It has the cassette player. Someone on here gave it to me but when I hooked it up only the AM worked :dunno: You can come by and pick it up. If you need the directions again I can PM them to you. JIm
  17. Banned may have been a bit harsh - I think he is in time out :D Thats funny, when the baby gets a little older he can explain to her what it feels like to be put in time out. :rotfl2:
  18. I didnt see the post and don't know what was said, so Ill just ask this: Is there a way in this board format to block the posts of certain members? I know you can in some formats. It will show you all the posts except those of the people you blocked. I have never benn offended by anything goblazers has said, but then I don't think Ive ever been offended by anything someone said on a message board.
  19. What size are the brake line fittings for the rear axle? It is actually for my 94xj with an 8.25. The brake line i bought has the wrong size fittings. Now i have to track down the fittings and cut and flare the line :fs1:
  20. http://www.cherokeeforum.com/f11/lifted ... obo-39327/
  21. Maybe they will show up soon. After all, Chico actually popped out the closet last week ; so anything is possible. :D
  22. Either ba10 or Ax15 Look here for pics of both: viewtopic.php?f=9&t=21018
  23. Removing rear proportioning valve:
  24. Inside gas tank: Difference in sending units: OEM and aftermarket one that works for XJ
