Alexia's 1987 To 1997 Comanche
  • Please log in to reply
575 replies to this topic
#1 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
  • LocationHuntsville, AL
Posted 04 March 2012 - 11:58 PM
I bought this 1987 Comanche 4.0 Manual 2WD from RockinMJ today, 2012-03-04. It is having a starting issue that appears to be a bad fuel pump or electrical to the pump. We had a fun time getting it up on the trailer after the ratchet straps failed to help. Since it had a fresh battery and could crank I hopped in, put it in first gear, and used the starter motor to get it up on to the trailer. Even worked to get it off and backed into the garage!(With a few stops to recharge.)
I consider myself the Jeep medic. I find a Jeep in need of love and healing, bring it home, and begin a long process of restoring it. Last year I found a deer collision XJ that I rebuilt the front end and redid the entire interior. Since this is a Comanche and quite rare now I plan to keep this one around. This is going to be a complete tear down and rebuild. There is some light surface rust across the roof and hood. The rest of the body has only one small dent that a is a simple fix, a lightly dented bed corner hidden by the bed liner, and a small bulge on the bottom of the tail gate that will take me less than a minute to fix with a hammer. The under side of the cab and bed look to be rust free. I am expecting a bit of light surface rust under the carpets.
Plans
  • 1997+ XJ Conversion(So cliche, but so worth it.)
  • 4.7 Stroker with Supercharger
  • JCR Offroad Front Bumper - Already delivered and waiting for paint.
  • LineX Bed Liner
  • 4WD Conversion - Donor is 4WD and have a NP242 ready to swap for full time 4WD.
  • D44 Rear Axle
To Do After Drive Train Installation
  • Adjust front axle caster angle and alignment.
  • Adjust sway bar angle.
  • Torque front suspension to specifications.
Before First Drive
  • Verify brakes are bled.
  • Verify parking brake is adjusted and works.
That's a nice Jeeeeeep you have there. Be a ssssshame if something happened to it.
Posted Image
Posted Image
Posted Image
Inching it back into the garage with the starter.
Posted Image
Posted Image
Did not even have it in the garage yet and I was already working on it.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
1997 Jeep Comanche - 4.7L Stroker - 5.5" Lift - 32" Tires - Build Progress
2004 Jeep Wrangler Unlimited - Electric Lime Green - Savvy/Currie 3" Lift - 32" Tires
#2 Exxon Valdez Jeep
Exxon Valdez Jeep
    Comanche Aficionado
  • Members
  • 324 posts
  • LocationTemple TX
Posted 05 March 2012 - 12:38 PM
Did you tow it home with a TJ?
and oh yeah :wavey:
"Of course its safe officer, I built it myself!"
The Jumpmanche http://www.comanchec...php?f=7&t=29678
#3 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 05 March 2012 - 01:48 PM
and oh yeah :wavey:
LJ - It worked out well enough.
#4 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 06 March 2012 - 12:03 AM
This is a 25 year old floor that has been water logged for a while.
The nasty moldy, slimy, and stinky carpet has already been tossed out in the trash bin. I will certainly have this floor cleaned, rust removed, and sealed by the end of the week while doing other things.
Two items I learned removing the interior.
[*:d77g95l8]The B pillar lights disintegrate on contact.
[*:d77g95l8]Lots of old brittle plastic bits.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#5 87Warrior
87Warrior
    MJ Maniac
  • Members
  • 3,689 posts
  • LocationJunction City, KS
Posted 06 March 2012 - 09:47 AM
That truck seems pretty clean. A great base to start your build from.
Nice looking LJ as well!
#6 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 08 March 2012 - 04:40 AM
Thanks! :D
I am a pouncing tiger when it comes to deals. I just arrived back from Tennessee scoring a 1997 XJ donor for $500. I drove to meet the owner at 12:30AM as it was first come first served. I go back later today to pick it up with a trailer. It is wrecked in the rear, which is perfect! Also it is 4WD so the MJ will be converted in the process.
#7 mvusse
mvusse
    Obsessive Comanche Disorder
  • Members
  • 6,422 posts
  • LocationStrasburg, OH
Posted 08 March 2012 - 06:09 AM
What is all that metal that was under your carpet? Is that one of those mythical "floors" I've heard about?
87 Comanche Pioneer 4.0 4x4 auto, Wilbur. 7.5" lift, welded front HP D60, Sterling 10.25" rear, 37x12.50R16.5 Military Bajas on modified HMMWV double beadlocks.
87 Comanche 2.5 4x4 5 speed, The Purple People Eater, stock daily driver.
96 Cherokee Sport 4.0HO, Sparkles. 4.5" lift, 32s, 2wd converted to Selec-Trac. Built for my daughter.
#8 RockinMJ
RockinMJ
    Comanche Aficionado
  • Members
  • 301 posts
  • LocationJacksonville, AL.
Posted 08 March 2012 - 08:59 AM
Sweet deal on the xj. If you find anymore you need to hook me up. I can't find any deals like that.
#9 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 08 March 2012 - 11:37 AM
This was a posted on Craigslist and have to jump on it immediately scenario since the owner already had several people call to come today.(So I came in the NIGHT! Mwuahaha!) There are more damaged front end pieces than I would like, but it has the majority key critical pieces such as drive train and interior.
#10 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 08 March 2012 - 11:38 AM
It was a factory option. :D
#11 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 08 March 2012 - 03:22 PM
The license department at the court house is a giant troll. They want me to bring the donor XJ to the court house to make sure the VIN matches since it is an out of state transfer. Guess I am taking up two parking spots with a trailer!
#12 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 11 March 2012 - 08:25 PM
I picked up a donor 1997 XJ for $500 plus my $170 in costs to go get it. The owner is a true Jeep lover and was really sad to see it go. Unfortunately it was beyond reasonable repair. Even I would not attempt to repair it! It was hit at 60mph in the right rear which sent the XJ spinning air born slamming the right fender into a truck waiting to turn. Luckily for my donor needs the passenger door is untouched! I promised that all the useful parts would go on to be used in other Jeeps and that the carcass would be properly recycled.
My goal is to be ready to pull the entire drive train from the XJ by next weekend. I am fairly close to this goal.
Bunch of MJ Interior Pieces. Anyone want to trade their grey interior for burgundy red?
Posted Image
Donor XJ inside my tiny garage. Notice my space saving by putting the lawn mower under the rear.
Posted Image
One good fender removed. Will have to source a hood, right fender, and header panel still.
Posted Image
It took a lot of wrestling to get the XJ dash out. They are lot heavier than the previous generation and better secured.
Posted Image
More front end disassembly! The entire front wiring harness, lights, and grill inserts are fine. Only a new header panel will be needed.
Posted Image
Sort of touched the MJ. It can wait a bit.
Posted Image
#13 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 16 March 2012 - 12:23 AM
This is how I deal with stubborn Torx bolts in the door. Just cut the hinge off!
Posted Image
Posted Image
Dash removed from the Comanche. Lots of little pieces of brittle plastic broke as it came apart.
Posted Image
#14 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 18 March 2012 - 09:07 PM
Lot more off both Jeeps. Drive train is about ready to be pulled from the XJ.
Posted Image
HVAC unit removed from the XJ! No pressure in the AC system so this was a simple unbolt and yank. Passenger side door cut off as well.
Posted Image
Getting everything cleaned up in the living room and storing it in an empty closet.
Posted Image
Plastic containers for various parts from each Jeep. All labeled with labeled plastic bags for fasteners.
Posted Image
#15 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 25 March 2012 - 10:20 PM
I know these pictures tend to be boring, but stripping vehicles is long and boring!
Dehatched
Posted Image
Deinteriored 1
Posted Image
Deinteriored 2
Posted Image
Space Saving, Storing the Hood and Hatch under the Jeep!
Posted Image
Bunch of useful parts coming off.
Posted Image
Useful interior parts, but someone else will get them.
Posted Image
#16 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 29 March 2012 - 01:48 AM
I have been slowly cutting the Cherokee apart to recycle the carcass. As well, I will be cutting around the frame rails to make a drive train stand to work on the parts.
Posted Image
One big Jeep and a few minutes later I have a taco roof.
Posted Image
#17 RockinMJ
RockinMJ
    Comanche Aficionado
  • Members
  • 301 posts
Posted 30 March 2012 - 11:36 AM
Alex you going to come down and help me do my conversion when I get my 97 and up cherokee. You should be a pro by then.
#18 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 30 March 2012 - 03:25 PM
Ha! The 1997+ XJs have a lot of sanity in their design so they are easy to disassemble. Electrical harnesses that easily come apart and are physically separated by compartment. The harnesses under the hood separate easily into an engine section, upper fire wall, and light harness. I have absolutely everything labelled down to tiny details and have individual fasteners taped to the matching part. If you need help, just ask!
I have Euramtec B-Pillar lights coming in the mail. I also have a newer 1998-2001 full gauge cluster shipping out soon with about 50,000 miles on it. I will have to rewire the dash connectors slightly for the 1997 dash wiring to support the newer cluster.(Just swapping a couple wires between connectors, simple!)
My friend/coworker is doing a garage crawl this weekend with me. Going to get some engines pulled and I will be out helping him wiring up his drift car.
#19 RockinMJ
RockinMJ
    Comanche Aficionado
  • Members
  • 301 posts
Posted 30 March 2012 - 06:06 PM
Yeah I found a sweet deal on a 97 called on it while I was at work and it was gone by the time I got off work the next day. Just gonna keep my eyes open for another sweet deal.
#20 Alexia
Alexia
    Administrator
  • Administrators
  • 1,235 posts
Posted 01 April 2012 - 02:32 AM
Just making a list of parts I need to buy.
Header Panel
http://www.quadratec...2503_802_07.htm
Right Fender
http://www.quadratec...2502_806_07.htm
Bushwacker Flares
http://www.quadratec...2506_801_07.htm
Engine Mounts, Transmission Mount, Black Carpet, Heater Core, AC Dryer, Accessory Belt, Carpet(ACC Part # 116387CUTPILEMB)
http://www.rockauto.com/
Square of Black Carpet for rear interior board.
Chrysler 8.25 Spring Perches
MOPAR P4120074 - Dealership
Metric Ton Leaf Springs
http://www.hellcreeksuspensions.com/
Air box lid, Fuse box lid, and a few other interior parts.
http://www.daveysjeeps.com/
Engine Build Information
1999+ Intake
New head bolts
Gasket Set
New Power Steering Pump Bracket
