if they are factory they twist off
Not all of them do. Some have a bolt that goes threw the bump-stop up into the snubber.
BINGO!!
Its gonna depend on year and other things.
But they will either have a bolt welded to them. Just grab a stilson wrench and remove. no need to even touch the rubber at all. Or a bolt threw them. This one required the removal of the rubber snubber, then appropriate sized socket and ratchet for removal. lithium grease will help with reinstallation.
Good luck,
CW
Hmm, I'm going to have to start calling a pipe wrench that - I've NEVER heard it before. Is it a demographic thing?
Monkey wrench, Stilson wrench, Pipe wrench, samo samo.....
But I'm sure there are origins, but :dunno:
Mr Stillson got the original patent for the pipe wrench (1869).
Monkey wrenches are different than pipe wrenches (made for nuts with flat sides rather than round pipes), but the name is commonly used in reference to a pipe wrench (albeit improperly).
Monkey wrench:
To me a monkey wrench is a crescent wrench is an adjustable wrench. Crescent wrench makes no sense, I actually have a set of crescent wrenches somewhere and they are crescent shaped, they're for accessing bolts put in retarded places (behind things) by the engineers who dreamed up the design for whatever I'm working on.
Stilson was the guy who invented the pipe wrench. But I've only ever heard it called a pipe wrench... I think.
Monkey wrench:
Score one for Pete.
Correct. Pipe wrenches are not Stillson wrenches. I actually have a Stillson in one of my toolboxes, inherited from my father who probably inherited it from his father. I can't remember when it was last used, but it has to have been at least 30 or 40 years ago. It's kind of beat up, but I keep it just to have it around for the "cool old tool" factor.
Back to the original question: The early XJs and MJs (up through 1990, at least) have the front bump stops threaded in. The rubber bumper fits in a metal cup. The metal cup has a threaded stud on the upper side. If you droop the suspension, you can fit a small pipe wrench or large pair of ChannelLocks between the coils and unscrew the stop.
Cresent is a brand name. Its like calling locking pliers "vice grips".
It's a common misconception that all pipe wrenches are Stilson wrenches. Not so. A Stilson has a pivot, like this:
An ordinary pipe wrench looks like this:
That be a graphite wrench, used primarily for transferring smudges onto paper.
Don't quit your day job... I hear comedy is a tough business... :popcorn:
