need help with driveabilty problem
my buddies XJ will fire up and idle poorly and when fuel is applied it stumbles
we have swapped parts with my mj
ecu
knock sensor
air sensor
water sensor
any other ides
we also adjusted the tps
How about a new fuel filter and some good injector cleaner... like maybe a healthy shot of SEAFOAM?
Check the plugs, cap and rotor as well!! ;)
CW
X2
Remember...always go for the simple stuff first as that is usually the problem. ;)
Did it ever run properly? If not, don't discount the possibility that some previous "technician" may have had the distributor out, and reinstalled it a tooth or more out of position.
Also, be sure the catalytic converter isn't clogged.
map sensor is new
injectors are new
fuel filter new
we pulled the dist and made shure every this is tdc
i work for a jeep dealor
i asked one of our tecks
he mentioned the egr valve was stuck in the open position
fuel filter new
we pulled the dist and made shure every this is tdc he mentioned the egr valve was stuck in the open position
MAYBE that is a problem on mine as well, runs 90% better now than when I first got it BUT.....
map sensor is new
injectors are new
fuel filter new
The MAP sensor is in the manifold, the control is on the firewall. Did you change both? A new sensor does not mean the signal is being translated correctly to the ECM.
this is still a problem
we have
checked fuel pressure
31 lbs if i rember right
replaced fuel rail
pulled and reinstalled distributor
replaced cap
rotor
all injectors
2 sets of used 1 compleet set of new
5 coials 4 used 1 new all work fine in outher rigs
we are stumped
working on the truck 3 ase tec's 2 morpar tech,s 1 toyota tech 1 mopar parts rep
First perhaps mention year and drivetrain.
Ever consider the CPS?
COMPUTERIZED ENGINE CONTROLS
POWERTRAIN CONTROL MODULE (PCM)
The Powertrain Control Module (PCM) is a dual microprocessor
that receives various signals from engine sensors and provides the
necessary signals to control engine sub-systems. The PCM has a voltage
converter that converts battery voltage to regulated 5-volt or 8-volt
outputs. The regulated 5-volt output is used to power Manifold
Absolute Pressure (MAP) sensor, Throttle Position Sensor (TPS) and
logic circuits. The regulated 8-volt output is used to power
crankshaft position sensor and camshaft position sensor in
distributor.
The ignition and fuel injection systems are controlled by
the PCM. Based on present engine operating conditions, the PCM is
programmed to provide a precise amount of fuel and the correct
ignition timing to meet existing engine speed and load requirements.
The PCM adjusts ignition timing based on inputs it receives
from camshaft position sensor, MAP sensor, coolant temperature sensor,
throttle position sensor, vehicle speed sensor, transmission gear
selection (automatic transmissions only) and brake switch.
The PCM adjusts idle speed based on inputs it receives from
selection (automatic transmissions only), A/C clutch switch and brake
switch.
The PCM also controls the speed (cruise) control system and
alternator charge rate by controlling the alternator field.
NOTE: Components are grouped into 2 categories. The first category
covers INPUT DEVICES, which control or produce voltage
signals that are monitored by the PCM. The second category
covers OUTPUT SIGNALS, which are components controlled by
the PCM.
INPUT DEVICES
Vehicles are equipped with different combinations of input
devices. Not all devices are used on all models. To determine the
input device usage on a specific model, see appropriate wiring diagram
in L - WIRING DIAGRAMS article in the ENGINE PERFORMANCE Section. The
available input signals include the following:
A/C Pressure Switch & Evaporator Switch
When A/C switch is in ON position and A/C low pressure switch
and evaporator switch are closed, an A/C select signal is sent to PCM.
If A/C low pressure switch or evaporator switch opens, the PCM will
not receive an A/C select signal.
When A/C function is selected (A/C switch on), the A/C
request signal provides information to the PCM from the A/C
temperature control thermostat (evaporator switch). This signal
indicates evaporator temperature is in the proper range for A/C
operation.
The A/C request signal is used by PCM to determine required
Idle Air Control (IAC) motor position and to activate or deactivate
A/C compressor clutch. When PCM receives an A/C request signal, it
repositions the IAC motor to increase idle speed. The increased idle
speed compensates for additional engine load caused by engagement of
A/C compressor.
On 4.0L, whenever A/C compressor clutch is energized, PCM
also energizes the radiator (cooling) fan relay. This occurs
regardless on engine coolant temperature.
Alternator Output
The PCM keeps charging system voltage at 13.5-14.8 volts.
Charging system voltage will be adjusted by PCM based on battery
temperature sensor, located within PCM housing. The voltage determined
by PCM as final goal for charging system is called "control" voltage.
The control voltage will be used to determine alternator field control
and to detect if charging system is operating properly.
If sensed voltage is lower than "control" voltage, PCM will
alter duty cycle and ground alternator (rotor) field for a longer
period of time and create a higher alternator output which should
raise sensed voltage level. If sensed voltage is higher than "control"
voltage, PCM will alter duty cycle and lower alternator output which
should lower sensed voltage level.
Battery Voltage Signal
The PCM uses battery voltage level to regulate alternator
field (rotor) duty cycle and alter fuel injector pulse width according
to available voltage. If battery voltage drops, PCM will increase
injector on time to compensate for the reduced fuel flow of injector
caused by the lower voltage. This will permit injector to deliver
proper amount of fuel to the engine.
Brake Switch
The brake switch is mounted on steering column support
bracket, under instrument panel. The PCM uses the brake switch to
determine when brakes are applied. When brakes are applied (brake
switch on) and if PCM sees a TPS opening and a lower speed sensor
rate, it recognizes a deceleration condition and opens up the Idle Air
Control (IAC) motor. The brake switch signal will also disengage speed
(cruise) control operation, if it was engaged.
Coolant Temperature Sensor
The coolant temperature sensor is mounted on top of engine,
next to thermostat housing. It provides an analog signal to the PCM
that is used to calculate injector pulse width and ignition timing
when engine is cold. Input from the coolant temperature sensor will
also affect Idle Air Control (IAC) motor position and spark advance
operation.
Crankshaft Position Sensor
The Hall Effect type crankshaft position sensor is mounted on
transaxle bellhousing. The sensor reads slots (4 per cylinder) on
flywheel/flex plate. The signal generated provides engine speed and
crankshaft position information to PCM. The PCM uses this information
to determine proper fuel injection and ignition timing.
When a flywheel/flex plate slot passes the crankshaft
position sensor magnet, output voltage of the Hall Effect sensor goes
high (5 volts). When the metal between the slots is aligned with
sensor, output voltage goes low (.3 volts).
This high/low voltage signal is sent to PCM each time one of
the slots passes the crankshaft position sensor. The PCM uses this
information to determine when to energize the injectors for fuel
delivery to the proper cylinders.
Ignition Circuit
When ignition switch is turned to the ON position, the PCM
receives a signal that the ignition circuit has been activated. The
PCM will start monitoring input signals.
Manifold Absolute Pressure (MAP) Sensor
The MAP sensor is mounted on engine compartment firewall. The
MAP sensor is used by PCM to calibrate amount of air/fuel mixture
supplied to the engine. This sensor measures manifold absolute
pressure. Ambient barometric pressure is also measured when ignition
switch is first turned on, during engine cranking, and at wide open
throttle.
The MAP sensor transmits a low voltage signal (1.5-2.1 volts)
at idle when manifold vacuum is high, and a higher voltage signal (3.
9-4.8 volts) during open throttle when manifold vacuum is low.
Input voltage (from the PCM) to MAP sensor ranges from 4.8-5.
1 volts. Adjustments made as a result of this input will usually
affect injector pulse width, ignition timing, idle speed and upshift
indicator light.
Manifold Air Temperature (MAT) Sensor
The MAT sensor is located on intake manifold, with sensor
element extending into the air stream. The sensor measures the
temperature of air entering the intake manifold. This sensor provides
an analog voltage signal to PCM. This signal is used to compensate for
changes in air density due to temperature.
The MAT sensor is a Negative Temperature Coefficient (NTC)
thermistor-type sensor. Its internal resistance varies opposite with
temperature. At cold temperatures, the resistance is high. As
temperature increases, its resistance decreases.
Oxygen (O2) Sensor
The heated oxygen sensor detects amount of oxygen content of
the exhaust gases and produces a voltage signal. PCM uses this signal
to determine system output signals which control air/fuel mixture.
Variations in voltage signal from O2 sensor serve as air/fuel
ratio indicators. When oxygen content is low (rich mixture), voltage
signal will be approximately one volt. When oxygen content is high
(lean mixture), voltage signal will be approximately 0.1 volt.
The O2 sensor contains a ceramic heater in the sensor
housing. The heater operates on 12 volts. The heater is used in cold
starts to help O2 sensor heat up quicker and to maintain the O2
sensor’s Zirconia semiconductor at operating temperature.
In "closed loop" operation, PCM monitors O2 sensor input
(along with other sensors) and adjusts the injector pulse width
accordingly. During "open loop" operation (cold oxygen sensor), PCM
ignores O2 sensor input and adjusts injector pulse width to a preprogrammed
value based on other sensor inputs.
Park/Neutral Switch
On vehicles equipped with automatic transmission, a gear
position indicator signal is sent to the PCM when gear selector lever
has been moved to the Drive range. This signal comes from the
park/neutral switch (neutral safety switch on AW-4 transmission) and
allows the PCM to adjust idle speed, fuel injector pulse width, and
ignition timing advance.
Power Steering Switch
On 2.5L with power steering, a power steering switch is used.
The switch is located on pressure line, next to power steering pump.
The power steering switch sends a signal to PCM when system
pressure rises to greater than 250-300 psi (17.6-21.1 kg/cm ) when
engine RPM is low. The PCM, through IAC motor, will then increase idle
speed to prevent engine stalling.
Serial Communications Interface Receive
The Serial Communications Interface (SCI) receive circuit is
the serial data circuit that is used when diagnosing vehicle with
Chrysler’s Diagnostic Readout Box-II (DRB-II). The PCM receives data
from the DRB-II through this SCI receive circuit.
Speed (Cruise) Control Switches
The speed (cruise) control switches provide 3 separate inputs
to the PCM. The ON/OFF switch informs PCM that speed control system
has been activated. The SET switch informs PCM that a set vehicle
speed has been selected. The RESUME switch informs PCM that the
previously selected set speed has been selected.
Start (Cranking) Signal
The start (cranking) signal from starter relay signals PCM
when starter is engaged. When PCM determines starter is engaged, it
begins to monitor inputs from crankshaft position sensor and camshaft
position sensor.
The PCM uses these signals to determine spark timing and
whether the first fuel injection should occur at cylinder No. 4 or 1
(4-cylinder) or cylinder No. 3 or 4 (6-cylinder). Once synchronization
has been established, the PCM energizes the proper injector and
provides the ignition output needed to start the engine.
Camshaft Position Sensor
The camshaft position sensor is located in distributor. This
Hall Effect type sensor works in conjunction with engine speed signal
of crankshaft position sensor providing PCM with inputs necessary to
establish and maintain proper fuel injector firing order.
When leading edge of pulse ring enters the sync signal
generator on the camshaft position sensor, the resulting change in the
magnetic field causes a 5-volt reference signal to be induced. On 4-
cylinder engines, this indicates to the PCM that piston No. 4 will be
the next piston at Top Dead Center (TDC). On 6-cylinder engine, it
indicates that piston No. 3 will be at TDC.
When trailing edge of pulse ring leaves the sync signal
generator on the camshaft position sensor, the resulting collapse of
the magnetic field causes reference signal to drop to zero volts. On
4-cylinder engines, this indicates that piston No. 1 will be the next
piston at TDC. On 6-cylinder engine, it indicates that piston No. 4
will be at TDC.
The TPS is mounted on throttle body and monitors opening
angle of throttle valve. It contains a potentiometer operated by the
opening and closing of throttle plate. PCM uses TPS input signal to
determine throttle position under all operating conditions and adjust
fuel injector pulse width and ignition timing accordingly.
The PCM supplies a 5-volt reference signal to TPS. The TPS
output voltage (input signal to PCM) represents throttle blade
position. The TPS output voltage varies from one volt at minimum
throttle opening (idle) to 4 volts at wide open throttle.
Maby this is too simple but I chased a problem like this last year I almost got into the motor I'm 50 yr old mechanic,my pop says to open the hood in the dark lowand behold the wires were bad lite show all over theay looked great but were badd ??? :nuts:
Replace the cable going from the negative terminal of the battery to the block. Clean both connections real well. Get the cable at Autozone that has a second wire that runs from the battery side and bolt it to the inner fender. Replace the ground braid from the back of the block to the firewall.
This worked for my problem. If it works for yours we might as well sticky it. It seems to be happening to a couple people with XJ's in my area.
list of new parts
positive batt cabel
negitiv battery cable
o2 sensor
cps
tps
idle air
mapp sensor
mapp sensor controler
coial
egr valve
pvc tubing and all related vacume lines
ecm
all parts are new mopar parts
all old parts have been checked and installed in outer rigs with not change to there running
the truck owner is a ground free also a eletricain by trade
there are 5 i kid you not 5 engin to body grounds 3 body to batt 2 batt to engine
You might feel this is enough. It absolutely SHOULD be as long as they are done correctly and are making a good ground. Pull a couple off and be sure there is nice clean metal between the strap and vehicle. Then add some dielectric grease!!
When diagnosing a problem, look at/for the clues. Always remember, new doesn't always mean right or fixed. While edundancy can be a good thing, something else to remember is. If someone does something wrong a thousand times its still done wrong. Get it?? Here is one I like.. "I done cut that board three times and its STILL short!!" :roll: :eek: :D
Good luck,
CW
