Jackrabbit41 Posted Monday at 02:48 PM Posted Monday at 02:48 PM Hello, all these black Friday deals are making me want to do my gears finally. I’d really like to go to 5.13s. Stock 4.0l and ax15 and np231. Running 35s. I have a ford 8.8 in the rear and a 1995 HP Dana 30. I put 4.10s in them years ago and always wish I would’ve gone more. Anyone running this set up? Yes I could get a different transfer case and it would a solve my issues but I also would like more torque usability in 2hi and 4hi. I never need to go more then 50-55mph so that’s not a concern. The axles are both completely stock. I will leave the front open but going to get rid of my LSD in the rear because I go through them so fast. Going to run a lunch box locker or something in the 8.8. I will be doing this work myself which I haven’t done before but I have all the tools to do it and I’m pretty handy. Thanks yall. Pic for attention
ThatJeepGuy Posted Monday at 03:18 PM Posted Monday at 03:18 PM I ran 4.56 in my old d30/8.8 (grizzly locker)setup for years on 36" iroks. With an auto trans 4L was where it lived while in the trails. I wanted numerically higher gears for the road driving though. 4.88/5.13s would have been nice for the road but prolly would've had me wearing out the front shafts even more soo than I was (basically a set of shafts per trip). Tcase change? Not sure what your suggesting (d300 with gear swap/ atlas?clune/eco box??) Your 231 with the 272:1 is about as standard you will find thats simple bolt in without changing drivehsafts. Your on the right track with a gear change though, I can't speak to the optimal ratio choice for a manual but I'm sure others can chime in
Jackrabbit41 Posted Monday at 05:31 PM Author Posted Monday at 05:31 PM 2 hours ago, ThatJeepGuy said: I ran 4.56 in my old d30/8.8 (grizzly locker)setup for years on 36" iroks. With an auto trans 4L was where it lived while in the trails. I wanted numerically higher gears for the road driving though. 4.88/5.13s would have been nice for the road but prolly would've had me wearing out the front shafts even more soo than I was (basically a set of shafts per trip). Tcase change? Not sure what your suggesting (d300 with gear swap/ atlas?clune/eco box??) Your 231 with the 272:1 is about as standard you will find thats simple bolt in without changing drivehsafts. Your on the right track with a gear change though, I can't speak to the optimal ratio choice for a manual but I'm sure others can chime in I’ve never had axle shaft problems, you think I will once I raise gears? At by transfer case I meant atlas but I don’t really need/want one
Area52 Posted Monday at 08:51 PM Posted Monday at 08:51 PM Unless things have changed in the years since I looked at gear sets for the HP 30, you can't get 5.13 gears into a Dana 30. 4.88 is as high as you can go.
Eagle_SX4 Posted Monday at 09:38 PM Posted Monday at 09:38 PM 46 minutes ago, Area52 said: Unless things have changed in the years since I looked at gear sets for the HP 30, you can't get 5.13 gears into a Dana 30. 4.88 is as high as you can go. They have been available for about 10 years according to some of the forum threads I have seen from a Google search. Not as common as the other ratios but they can be found.
ThatJeepGuy Posted Monday at 09:44 PM Posted Monday at 09:44 PM Again, I have an auto trans soo this is my opinion, try 4.88s. I'm primarily doing tight aggressive trails with ledges and rock crawling soo the shaft problems were just part of that game. If your more the adventure offroad type/overlanding I think you'll be alright.
derf Posted Monday at 11:45 PM Posted Monday at 11:45 PM That much torque can be hard on the 27 spline shafts up front. And absolutely upgrade the u-joints while you're in there. The stock joints in early XJ/MJs are weak. You'll need new shafts for the bigger joints but they're not super expensive.
Jeeper1093 Posted Tuesday at 11:19 AM Posted Tuesday at 11:19 AM The pinion is very small on 5:13 gear for a Dana 30 and prone to breaking under stress. I would go with 4:88
