Jackrabbit41 Posted 3 hours ago Posted 3 hours ago Hello, all these black Friday deals are making me want to do my gears finally. I’d really like to go to 5.13s. Stock 4.0l and ax15 and np231. Running 35s. I have a ford 8.8 in the rear and a 1995 HP Dana 30. I put 4.10s in them years ago and always wish I would’ve gone more. Anyone running this set up? Yes I could get a different transfer case and it would a solve my issues but I also would like more torque usability in 2hi and 4hi. I never need to go more then 50-55mph so that’s not a concern. The axles are both completely stock. I will leave the front open but going to get rid of my LSD in the rear because I go through them so fast. Going to run a lunch box locker or something in the 8.8. I will be doing this work myself which I haven’t done before but I have all the tools to do it and I’m pretty handy. Thanks yall. Pic for attention
ThatJeepGuy Posted 2 hours ago Posted 2 hours ago I ran 4.56 in my old d30/8.8 (grizzly locker)setup for years on 36" iroks. With an auto trans 4L was where it lived while in the trails. I wanted numerically higher gears for the road driving though. 4.88/5.13s would have been nice for the road but prolly would've had me wearing out the front shafts even more soo than I was (basically a set of shafts per trip). Tcase change? Not sure what your suggesting (d300 with gear swap/ atlas?clune/eco box??) Your 231 with the 272:1 is about as standard you will find thats simple bolt in without changing drivehsafts. Your on the right track with a gear change though, I can't speak to the optimal ratio choice for a manual but I'm sure others can chime in
Jackrabbit41 Posted 22 minutes ago Author Posted 22 minutes ago 2 hours ago, ThatJeepGuy said: I ran 4.56 in my old d30/8.8 (grizzly locker)setup for years on 36" iroks. With an auto trans 4L was where it lived while in the trails. I wanted numerically higher gears for the road driving though. 4.88/5.13s would have been nice for the road but prolly would've had me wearing out the front shafts even more soo than I was (basically a set of shafts per trip). Tcase change? Not sure what your suggesting (d300 with gear swap/ atlas?clune/eco box??) Your 231 with the 272:1 is about as standard you will find thats simple bolt in without changing drivehsafts. Your on the right track with a gear change though, I can't speak to the optimal ratio choice for a manual but I'm sure others can chime in I’ve never had axle shaft problems, you think I will once I raise gears? At by transfer case I meant atlas but I don’t really need/want one
