Area52
Everything posted by Area52
  1. Unless things have changed in the years since I looked at gear sets for the HP 30, you can't get 5.13 gears into a Dana 30. 4.88 is as high as you can go.
  2. I would think your best bet is to find a Cherokee same year/engine with A/C and swap everything over. You could check over at Naxja.org in the Sierra section and see if someone could offer a shop to help.
  3. Distributor turns, cleaned ground at oil dipstick bolt, driver's side rear engine head to body, battery negative to body and drivers side inner fender by the ECU. Cleaned ECU contacts. Still no spark. Next up - check distributor camshaft position sensor, and ignition coil connector.
  4. So I picked up Lurch's 92 back in July. He had a no spark situation when I got it. He had replaced the CPS, coil and dist cap. I replaced the ASD relay and checked fuel pump was putting out pressure. Replaced the CPS anyways and still no spark. I back probed the CPS orange wire and got about 8 volts with the key in the "on" position. So that would mean grounds are probably good yes? And CPS getting power? Are the grounds any different on a HO than a Renix? I'm more familiar with the Renix engines . Next step check the sensor in the distributor? Anything else? Thanks to everyone on here, this is a great spot for us MJ folks.
  5. First of all, thanks to all who are on here and keep this going. I love Comanches and thought I would share my story of my first one. The year was 1989 and I was a young sailor in the Navy moving from one duty station down south to another up north. My ride of choice in those days was a very very rusty 1976 Firebird. I drove this thing several hundred miles to where my family lived in WV and Ohio. The exhaust fell apart and attracted the attention of the local P.D. while I was driving and got a fix it ticket. Instead of fixing it and throwing more money into a losing cause, my dad offered to help me find a new vehicle before I had to leave to report to my new duty station in a few days. He wanted me to get something more "sensible", me - not so much, but not having too much money and my dad said he would co-sign a loan with me, we went to the local Buick dealer. Not seeing anything that peaked my interest, I looked across the street at the Jeep/Eagle dealer and there sat two mid sized pickups that I had never seen before. One a dark blue Pioneer short bed 2wd and the other a red short bed 4wd Eliminator. Of course the red one called out to me so over we went to the Jeep lot to test drive it. Alas, after running the numbers even with my dad co-signing the loan, I couldn't afford the Eliminator, but I did buy the blue one and my love affair with MJ's has never stopped. I had that truck for 4 years before selling it ( to concentrate on my 1969 Camaro). I regret selling it to this day. Outside of an initial transmission problem, it never failed me once. Since then, I have owed three more ( two going to my sons) and am looking to get another one soon. thanks for reading
  6. New member in San Bernardino. Looking to buy a Comanche.
