What's the best source for fuel injectors these days?
  • jodawill changed the title to What's the best source for fuel injectors these days?
The Junk Yard. Our Comanche isn't the nicest and we didn't pay a lot for it, so we have a rule, the parts can't cost more than the vehicle. Recently had a fuel injector go bad so we pulled some out of a Renix XJ in the junk yard and chuckled when we found they were Ford injectors. So ours is presumably the 3rd vehicle (Mustang/Crown Vic. etc. XJ, our MJ) those injectors have been in.
But if you want something not used, take a look at the sources I went to in the link below.
I got 6 from 3 different Expeditions at the junkyard.  early 2000s I think?  (the front 2 are super easy to pull, but you can get 6 from one if that's all they have).  the injectors you want will have the same shape as your original.  if they are a different shape, that's the wrong year.
