knever3 Posted 4 hours ago Share Posted 4 hours ago I posted in the wanted section and poked around in the search, but not finding what I am looking for. I have the old Renix style oil filter that points to the rear of the engine, my short oil filter hits my Mean Green starter. I need to change to the one that locates the filter upwards, plus it's hard to find filters for this Dinosaur. Does anyone have one that want to part with, plus links to the O-rings would be a bonus!! Thanks! Link to comment Share on other sites More sharing options...
89 MJ Posted 4 hours ago Share Posted 4 hours ago IIRC, the Renix oil filter points up at roughly 45*. Sounds like you already have the HO one. Link to comment Share on other sites More sharing options...
hgeranium Posted 3 hours ago Share Posted 3 hours ago What 89MJ said. The Renix one is what you're looking for Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted 3 hours ago Share Posted 3 hours ago The oil filter adapter can be rotated to any angle you want. There is a location roll pin pressed into the block that can be removed and you can turn it any way you want. If you want to change the oil filter to the newer 3/4 thread the part number for the threaded adapter is 53007563AB. The oring sizes are listed here by Cruiser54 Link to comment Share on other sites More sharing options...
fiatslug87 Posted 3 hours ago Share Posted 3 hours ago Here is Cruiser’s write up on the switch so you can verify what you have. Link to comment Share on other sites More sharing options...
