Windshield Glass Replacement
I'm going to have my windshield replaced by Safelite and move to the rubber trim.
In an effort to minimize the confusion, am I best off reserving the glass and install as a 1998 Cherokee?
For those that have had this done, should I remove the metal trim and clips beforehand or is this something a competent installer should just be able to handle?
The prices *are* different between a 1988 Comanche and a 1998 Cherokee.  (Cherokee is cheaper.)
Quote
2 hours ago, Tex06 said:
Yes. However the newer jeep will advertise a 1 piece rubber Weatherstripping that they will use in place of the trim. Fit may vary a bit (it's what I have on mine).
That's what I'm looking for.  I was planning on removing the metal trim (permanently).
Thanks for the quick replies!
That's what we've done too. I asked the glass installer to give me back the metal trim, but no regrets with the rubber seal. Don't have to worry about it flying off or coming off in a car wash.
I haven't done this myself - Yet but that seems to be the consensus, tell them its a 97+ XJ and no other details.
I've approached 2 different glass suppliers on this - its an 87 but the 97+ xj glass will fit with the newer rubber seal. Both companies would nto even consider doing it though its clearly proven time and time again - it fits without issue.
