jpnjake Posted December 7, 2024 Share Posted December 7, 2024 Hey guys, a couple weeks ago I was replacing my rear brake line and found my 02 sensor wires just dangling, turns out at some point the wiring on the sensor broke off of the sensor (explaining my sudden drop in fuel mileage and lack of power lately). Then I found all the conflicting information about the 02 sensors themselves, some say none available work(find JY one), some say they swear by the Bosch, and others say the Bosch don’t work at all and to go with the NTK, so just curious if any one else has ran into this problem and what your experiences and solutions have been TYIA Pic for attention Link to comment Share on other sites More sharing options...
89 MJ Posted December 7, 2024 Share Posted December 7, 2024 That Cub Cadet looks like a blast. It seems like a crapshoot, but maybe Bosch is the way to go based on this thread: You can also use a wideband and a REM to get it in closed loop. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted December 8, 2024 Share Posted December 8, 2024 At this time, the only thing I can suggest is whatever O2 sensor you purchase, test it before you install it. The bosch 12009 re-labels I received from that random seller on amazon were not correct. They were wired incorrectly, the wrong resistance, and did not respond correctly with heat. I have been scooping up new old stock o2 sensors when I find them on ebay but I have not seen one since september. I gave my last one to my brother for his XJ. You may have an easier time in a junk yard. It's sad. Link to comment Share on other sites More sharing options...
llhat Posted December 8, 2024 Share Posted December 8, 2024 was there not a thread about the 'correct' and 'best' O2 sensors available 'now'? Link to comment Share on other sites More sharing options...
speeding_infraction Posted December 8, 2024 Share Posted December 8, 2024 Switching to REM + wideband would probably be the most reliable/accurate, but you will have to drop a little more coin Link to comment Share on other sites More sharing options...
pizzaman09 Posted December 8, 2024 Share Posted December 8, 2024 I tried a Bosch when I first purchased my truck 3 years ago based on my success with Bosch for other vehicles O2 sensors. It was a mistake, the sensor was super slow to respond and would slowly wave back and forth from rich to lean over and over again. I purchased the recommended NTK sensor and it fixed everything. I had a smooth idle and more power just about everywhere. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted December 8, 2024 Share Posted December 8, 2024 4 hours ago, TurboedMJ said: Switching to REM + wideband would probably be the most reliable/accurate, but you will have to drop a little more coin has anyone done a writeup on the wideband conversion? Did nick do one? I'm tempted. I already have the REM. might make sense at this point. Link to comment Share on other sites More sharing options...
89 MJ Posted December 8, 2024 Share Posted December 8, 2024 41 minutes ago, Salvagedcircuit said: has anyone done a writeup on the wideband conversion? Did nick do one? I'm tempted. I already have the REM. might make sense at this point. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 8, 2024 Share Posted December 8, 2024 2 hours ago, pizzaman09 said: … the sensor was super slow to respond and would slowly wave back and forth from rich to lean over and over again… It is supposed to toggle between lean and rich very quickly. Link to comment Share on other sites More sharing options...
pizzaman09 Posted December 8, 2024 Share Posted December 8, 2024 10 minutes ago, fiatslug87 said: It is supposed to toggle between lean and rich very quickly. Exactly! The Bosch one was very slow, like 30 seconds to toggle back and forth based on what my REM was showing. The NTK is super quick. The NTK fixed my lean rough idle. Link to comment Share on other sites More sharing options...
jpnjake Posted December 10, 2024 Author Share Posted December 10, 2024 On 12/8/2024 at 2:22 PM, pizzaman09 said: I tried a Bosch when I first purchased my truck 3 years ago based on my success with Bosch for other vehicles O2 sensors. It was a mistake, the sensor was super slow to respond and would slowly wave back and forth from rich to lean over and over again. I purchased the recommended NTK sensor and it fixed everything. I had a smooth idle and more power just about everywhere. Thank you, I’ll have to give this one a shot, gonna buy it straight off their website! I was waiting for someone to report good news of this part as the Bosch one seems like hot garbage On 12/7/2024 at 3:29 PM, 89 MJ said: That Cub Cadet looks like a blast. It seems like a crapshoot, but maybe Bosch is the way to go based on this thread: You can also use a wideband and a REM to get it in closed loop. Thank you Carter, it is a lot of fun, probably the most fun purchase of the year right behind the trailer! looks like as of rn nick isn’t producing rem units due to a supply chain issue, i definitely want to pursue that option tho On 12/7/2024 at 7:27 PM, Salvagedcircuit said: At this time, the only thing I can suggest is whatever O2 sensor you purchase, test it before you install it. The bosch 12009 re-labels I received from that random seller on amazon were not correct. They were wired incorrectly, the wrong resistance, and did not respond correctly with heat. I have been scooping up new old stock o2 sensors when I find them on ebay but I have not seen one since september. I gave my last one to my brother for his XJ. You may have an easier time in a junk yard. It's sad. Such a shame that parts from 20+ years ago are the only reliable source. Just like how when you buy a new part you have to question if it was better than the one you just replaced (It never is) Link to comment Share on other sites More sharing options...
89 MJ Posted December 10, 2024 Share Posted December 10, 2024 17 minutes ago, jpnjake said: Thank you Carter, it is a lot of fun, probably the most fun purchase of the year right behind the trailer! looks like as of rn nick isn’t producing rem units due to a supply chain issue, i definitely want to pursue that option tho I bet it is! That's a shame that they aren't in production right now. Hopefully that gets resolved quickly, I saw he posted about a new 3D printer on FB not too long ago. Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 10, 2024 Share Posted December 10, 2024 Please report back how it’s working and whether it’s three or four wires coming out of the body into the three pin connector. Link to comment Share on other sites More sharing options...
Htchevyii Posted December 10, 2024 Share Posted December 10, 2024 I'm using the 4 wire Bosch in both of mine. As far as I can tell, they have been working fine. Both go into closed loop pretty quickly. The one in the MJ probably has 20k on it. I thought that I had a problem with the sensor on the XJ, but it ended up just being the relay. I still have the used OEM one that I bought when I worked at the Dodge dealer years ago. I had no idea that I would still own the MJ. I should have bought so many more parts! At least I replaced both manual window regulators when I worked there! Link to comment Share on other sites More sharing options...
jpnjake Posted December 16, 2024 Author Share Posted December 16, 2024 Finally received mine today, I ended up ordering the ntk on amazon, not off their website since it would come sooner. It ended up being a 4 wire unit. ohm reading cold was right at 5 ohms so that’s good news at least. Going to install then update again on whether or not it works. In the case that it doesn’t, currently planning on returning this one and buying one off their website and just waiting. My hope is the company will have all the new 3 wires and that the amazon seller just had a bunch of 4 wires from the last batch Link to comment Share on other sites More sharing options...
