Gjeep Posted March 21 Author Share Posted March 21 Used a portion of a scraped MJ room to check fitment (mainly interior clearance) for the 3rd brake/ cargo light combo… and it works. Ford Ranger sockets were the go-to because they are rubber (quiet) and the right size. Now to trim the real roof. Link to comment Share on other sites More sharing options...
Gjeep Posted March 22 Author Share Posted March 22 Got to cuttin’ – always a bit stressful to put areas that are somewhat visible under the knife. Measure, measure, measure, cut. Great fit and looks right. Had been searching for just the right era appropriate look for years. Drilling mounting holes next… Link to comment Share on other sites More sharing options...
watchamakalit Posted March 22 Share Posted March 22 Looks good! I have a feeling this idea may make it's way to my truck..... Link to comment Share on other sites More sharing options...
Gjeep Posted March 24 Author Share Posted March 24 Long live Tomken Machine. Not sure if they’re still in business, but they were the go-to for my lifted XJ/ MJ’s sway bar end needs. Beefy and same design as stock but fatter bushings. I decided to go with the factory heavy duty XJ 28mm factory front sway bar with Energy greasable bar bushings. And with temperature up in Oregon, on went the matte black ‘Jeep’ tailgate letterset. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 24 Share Posted March 24 Can’t wait to see this on the road. Link to comment Share on other sites More sharing options...
Gjeep Posted Wednesday at 10:48 PM Author Share Posted Wednesday at 10:48 PM Carpet in place and ready to be trimmed first thing in the morning. Those who have installed carpets know the insane amount of extra material that surrounds the core. It’s nut. I’ll call this ‘in place’ but it still needs to move a good 4” forward once cut down. Tomorrow… Link to comment Share on other sites More sharing options...
NRT_Chris Posted Wednesday at 11:11 PM Share Posted Wednesday at 11:11 PM 23 minutes ago, Gjeep said: Carpet in place and ready to be trimmed first thing in the morning. Those who have installed carpets know the insane amount of extra material that surrounds the core. It’s nut. I’ll call this ‘in place’ but it still needs to move a good 4” forward once cut down. Tomorrow… I just did this. I used my old carpet as a template. There are more pics on my thread "one owner 92" Link to comment Share on other sites More sharing options...
Gjeep Posted Thursday at 05:18 PM Author Share Posted Thursday at 05:18 PM Thanks NRT_Chris for the tip. ACC did a good job this carpet stamp – the usual front of footwell issues weren’t present. Two thumbs up. The driver side rocker stamp is never proper and takes a heat gun to shape around that side reinforcement plate; And the rear cab wall is spot on passenger side but then goes wonky off by 2” driver side. Again, heat gun to the rescue. Finally, matting will be stuffed in the trans tunnel areas so when the center console is installed it will fit without gaps. But for now, the carpet is coming out as next up is the windshield replacement with the newer style gasket surround. The black Mesa fabric bucket seat bottom upholstery is headed in for repair. I’ve already removed the piece that wraps over and around the frame that the upper seat latch clips into. The little piece of vinyl takes a beating and typically looks like hell even when the rest of the seat looks brand new. It’s the bolt covered rubber ‘bumpers’ Jeep installed to adjust/ prevent seat back wobble. The rubber tip of the bumper breaks off and then exposed bolt tears into the vinyl. Holes in the replacement panel will be cut AFTER the seat is together and flap clipped into place, so no misses on the cut location. Link to comment Share on other sites More sharing options...
NRT_Chris Posted Friday at 01:43 AM Share Posted Friday at 01:43 AM Carpet looks great 👍 Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted Friday at 03:36 AM Share Posted Friday at 03:36 AM Always a pleasure checking in Link to comment Share on other sites More sharing options...
Gjeep Posted Saturday at 11:54 AM Author Share Posted Saturday at 11:54 AM Fine tooth combing the little things to move forward on assembly… Put together the shoulder belt assembly, attaching it to the modified MJ bracket with grade 8 hardware and sleeved the bottom attaching point (at rocker) to keep it looking factory. Also sleeved the buckle for form and function – the C4 Corvette has an identical length seat belt buckle setup, and what I like about it is it keeps the center console from getting damaged/ carved into as so many of them (especially AMC era) get. It angles the buckle inward and away from the console plastic. Took some time to find just the right set up for this. Lots more details to accomplish for this build before I start getting the interior back together. Next up is the overhead console. Also, been on an insane journey that I now give up on... I wanted to simply replace the Dana 35 hard brake lines. Ordered from Inline Tube just that – first time I got I don’t know what; second time I was hopeful as the line at least has the shape of a pumpkin but turned out to be near 8” too long with incorrect bends. I lost a good month and a half trying to get something that seemed like it would be a simple buy delivered. I give up and will bend my own lines like I did last MJ build. Link to comment Share on other sites More sharing options...
Gjeep Posted Saturday at 05:53 PM Author Share Posted Saturday at 05:53 PM Got it done – Rear axle brake lines bent, flared and in place. Off the list. And cut the overhead console for the hands-free mic. Time to clean up and refinish. Link to comment Share on other sites More sharing options...
Gjeep Posted Sunday at 05:45 PM Author Share Posted Sunday at 05:45 PM I’m a huge fan of test fitting before final assembly. Nothing worse than having things looking good and last minute find out modifications need to be made. The overhead console install is one of those projects where it’s essential. This console I made taller than in my other MJ, so the XJ modified (front) mounting bracket needed to be bent a little differently and the rear mount platform needed to be taller. Good contour fit of the reshaped shell and the headliner insert cuts were spot-on. My highly technical tool, the Q-Tip, served to mark the location of the rear most screw (found inside the sunglass bin) with a dab of black paint; and it also confirmed the height the bracket needed to be at to seat the console properly keeping it flush to the headliner. All good there. Link to comment Share on other sites More sharing options...
