Jeepers8606 Posted November 5, 2024 Share Posted November 5, 2024 Good morning all, please get out and vote today. 31 years as a Jeep owner, but new MJ owner, looking for guidance. I'm interested in swapping out the 89 MJ power windows, replacing with manual, and the fixed forward window with an opening (butterfly) vent window. Sounds like a pending classified post to me. Has anyone performed this swap? Will a 4 door XJ set up work in this situation? Any guidance would be greatly appreciated. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted November 5, 2024 Share Posted November 5, 2024 Yes it will work but most get away from the manual windows because the regulators are hard to find in good working condition. The front doors on a 4 door XJ (up to 96) are the same as the MJ. You can swap in the 97+ full size windows into the old doors if you want to eliminate the the small window section entirely. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 5, 2024 Share Posted November 5, 2024 The smokers window setup can be swapped from an earlier model XJ MJ and is a pretty simple bolt in swap though you will have to remove your door glass. You have factory power windows in an MJ? Thats a rare option! You can swap to a manual regulator though they are admittedly hard to find in good working order. Another option is swapping in the single full size glass from a 97+ XJ. There is a youtube video on that process. Alternatively, get your power windows working right and enjoy an option that many of us wish we had Link to comment Share on other sites More sharing options...
schardein Posted November 5, 2024 Share Posted November 5, 2024 Just a heads up, the opening wing windows are cool, but they tend to leak. I deleted them from both my 91 XJ and 91 MJ. Are your power windows factory, or an aftermarket conversion? Link to comment Share on other sites More sharing options...
Jeepers8606 Posted November 5, 2024 Author Share Posted November 5, 2024 To the best of my knowledge, the power windows are factory, as they have the door locks in the same panel, very similar to my SJ window controls, I haven't gotten that far with the VIN lookup. Yes, my CJ 7 vent windows did leak a little, YJ do not leak, and once I swap to the manual windows, I'll never have to find a window regulator, like on my WJ (3rd regulator) Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 5, 2024 Share Posted November 5, 2024 Downgrading from power to manual? Interesting. There are ways to make your power windows better and faster. Manual regulators are nice yes but stupid rare. No one makes new ones, all the old ones that are approaching 40 are either getting replaced from years of abuse or age. If you find a doner with manual, then go for it. There’s two types of manual regulators. 1st gen is riveted to the door. 2nd is bolted to the door. A factory power door MJ is quite rare as others have said. Even the high trim MJs didn’t have such. Maybe power lock but not windows unless swapped from a 2-door. since we’re on the topic, has anyone ever screwed around with XJ rear window regulators and bent them to match the fronts? Link to comment Share on other sites More sharing options...
Jeepers8606 Posted November 5, 2024 Author Share Posted November 5, 2024 Never had an issue with any of rear windows, jeep dog hasn't been trained to use them, yet. Link to comment Share on other sites More sharing options...
schardein Posted November 5, 2024 Share Posted November 5, 2024 9 hours ago, Jeepers8606 said: To the best of my knowledge, the power windows are factory, as they have the door locks in the same panel, very similar to my SJ window controls, I haven't gotten that far with the VIN lookup. Yes, my CJ 7 vent windows did leak a little, YJ do not leak, and once I swap to the manual windows, I'll never have to find a window regulator, like on my WJ (3rd regulator) I understand your reasoning for converting from power windows, just be aware that the manual regulators are notorious for breaking, not working, and requiring replacement. I've sold a handful of them, and they aren't cheap. They are hard to find in good (used) condition, are a lot of work to pull (from a junkyard vehicle), run $20-$35 each at the yard, and are expensive to ship because of their size. Be aware that if your current door panels have the "Jensen Accusound" speaker grills (it will say that on the speaker grill), and you add a manual window regulator, the window crank will hit the speaker grill. Manual window crank was used with the generic (not Jensen branded) speaker grills only, or "radio delete" models with no speakers. Link to comment Share on other sites More sharing options...
Jeepers8606 Posted November 5, 2024 Author Share Posted November 5, 2024 Clearance, Clarence, got it, but still not over Macho Grande Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 5, 2024 Share Posted November 5, 2024 2 hours ago, schardein said: I understand your reasoning for converting to power windows, just be aware that the manual regulators are notorious for breaking, not working, and requiring replacement. I've sold a handful of them, and they aren't cheap. They are hard to find in good (used) condition, are a lot of work to pull (from a junkyard vehicle), run $20-$35 each at the yard, and are expensive to ship because of their size. Be aware that if your current door panels have the "Jensen Accusound" speaker grills (it will say that on the speaker grill), and you add a manual window regulator, the window crank will hit the speaker grill. Manual window crank was used with the generic (not Jensen branded) speaker grills only, or "radio delete" models with no speakers. My manual regulators went out on my last MJ and it was almost impossible to find replacements. Link to comment Share on other sites More sharing options...
watchamakalit Posted November 6, 2024 Share Posted November 6, 2024 11 hours ago, ghetdjc320 said: My manual regulators went out on my last MJ and it was almost impossible to find replacements. Not impossible, I can find you a handful rather quickly, but I know where they are stashed. Lol. They are easier to find than that dadgum ac line. Link to comment Share on other sites More sharing options...
ja_racing Posted November 7, 2024 Share Posted November 7, 2024 On 11/5/2024 at 7:21 AM, Eagle_SX4 said: Yes it will work but most get away from the manual windows because the regulators are hard to find in good working condition. The front doors on a 4 door XJ (up to 96) are the same as the MJ. You can swap in the 97+ full size windows into the old doors if you want to eliminate the the small window section entirely. How do you do that? Is there a thread or write up that would be cool 97+ windows in old doors Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted November 7, 2024 Share Posted November 7, 2024 1 minute ago, ja_racing said: How do you do that? Is there a thread or write up that would be cool 97+ windows in old doors Bleepinjeep did a good video Link to comment Share on other sites More sharing options...
NickyV Posted November 24, 2025 Share Posted November 24, 2025 Reviving this thread because it relates to a project I just tackled over the weekend. I finally replaced my busted passenger side window regulator. Anyway, here's the TL;DR version of my question for @schardein or anyone who knows: Has anyone found window cranks that play nice with the Jensen Accusound grilles? Here's the backstory: I was at the junkyard a while back and I decided to get fancy and I pulled some Jensen Accusound grilles from an XJ in the JY. I liked the look of them. I have rectangular grilles covering the 6x9s I have in the pillars, so I thought, why not rectangular grilles in the doors as well. Suffice to say I had not read this thread. The window crank definitely hits the grille... well... more like skips off the surface of it. And actually, if I'm careful about it, I can apply pressure and kinda have the crank at an angle, so I don't scrape the grille. But this is not a good solution. Seems like it just needs a smidge more clearance. Then again, I'm not sure I got my handle on all the way. There seems to be more space between the door card and the crank than there should be. I tried giving it a few love taps with a rubber mallet, but I didn't want to damage the regulator I just spent so long putting in place. Here's my experience putting in the window regulator for those who find this thread in the future: I bought the replacement regulator back in like 2020-21 and had been dreading this job because I'd heard horror stories. But it actually wasn't that bad. Yes, I had to drill out the rivets, but all in all, it was a manageable job. Probably a full day of work for me and I'm still building my chops. Someone with more experience could do this in a couple of hours. To make life easier for yourself, make sure you have all your bolts ready to go ahead of time and beware that the brackets on these window regulators are held on by 35-year-old tack welds. One of the brackets broke after I had the regulator in the door. It was getting dark and I didn't want to pull it back out (I don't have a garage). Thankfully, it was the bracket at the top of the regulator. I zip tied the regulator housing to the bracket. I think this will be fine. If not, I'm going to have to pull it out... but I guess it will give me an excuse to finally start to learn welding. I replaced the rivets with short bolts and a combination of locking nuts, locking washers and Lock Tite. I do not want those things coming loose unless I say so! I'm planning to make a video on this and I will soon start my own build thread so I can share all the videos I make. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 24, 2025 Share Posted November 24, 2025 30 minutes ago, NickyV said: Seems like it just needs a smidge more clearance. Then again, I'm not sure I got my handle on all the way. Yeahhhh there’s a reason why those speaker grills are found on higher end XJs with power windows haha. Link to comment Share on other sites More sharing options...
NickyV Posted November 25, 2025 Share Posted November 25, 2025 Dangit. Well... at least I only put one of them in. And I ain't giving up just yet! Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 25, 2025 Share Posted November 25, 2025 2 hours ago, NickyV said: Dangit. Well... at least I only put one of them in. And I ain't giving up just yet! I wouldnt. Toss em in and enjoy the "luxury" sound haha. Ive got those grills in both of my jeeps. The XJ hardly hits them and same with the MJ but the pass side of both do hit them. Link to comment Share on other sites More sharing options...
