HuntinHopin Posted September 2, 2024 Share Posted September 2, 2024 As the title states, I’m looking for a set of seatbelts for an 87 with bench seat. My 15 year old wanted a MJ and we finally found him one but it came with no seat belts. What other seat belts will bolt right in if I can’t find an original set? Also looking for visors, ashtray, glove box lid lock, and an oh crap handle. However, obviously seat belts are most important. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 2, 2024 Share Posted September 2, 2024 9 more posts and our classified sections will open up to ya go browse. Link to comment Share on other sites More sharing options...
The86manche Posted September 3, 2024 Share Posted September 3, 2024 Most of the parts you need can be found out of a 84-96 cherokee. I think even cherokee seat belts can be made to work Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 3, 2024 Share Posted September 3, 2024 I know I do have some of this stuff on hand as well. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 3, 2024 Share Posted September 3, 2024 I have bought some aftermarket seat belts and they work great. Mounting the retractor is the hardest part. You just need to make a bracket with 2 holes to match the original mounting location. See this post for more info. The ones I got were total length of 133" and they are to long. I have seen some that are 110" and would work much better. Here is a link. I will probably buy some of these in the near future. https://www.seatbeltplanet.com/i-30500018-3-point-lap-shoulder-retractable-seat-belt-all-metal-push-button-buckle.html?q= Bonus is they look like the Chrysler era jeep seat belts and are brand new. Link to comment Share on other sites More sharing options...
HuntinHopin Posted September 4, 2024 Author Share Posted September 4, 2024 Awesome. Thanks for the replies. Hitting the junkyards this weekend. If we can’t find what we need, I will be reaching out to you eaglescout526. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 4, 2024 Share Posted September 4, 2024 11 minutes ago, HuntinHopin said: Awesome. Thanks for the replies. Hitting the junkyards this weekend. If we can’t find what we need, I will be reaching out to you eaglescout526. Sounds like a plan! Link to comment Share on other sites More sharing options...
schardein Posted September 4, 2024 Share Posted September 4, 2024 3 hours ago, HuntinHopin said: Awesome. Thanks for the replies. Hitting the junkyards this weekend. If we can’t find what we need, I will be reaching out to you eaglescout526. What junkyards are you planning to go to? Head to Buddys in Springfield. They have an 89 Comanche, when I was there Friday, it still had seatbelts in it. Link to comment Share on other sites More sharing options...
gogmorgo Posted September 5, 2024 Share Posted September 5, 2024 Not sure which seats you have, bench or buckets, cause the thread title says one and the post says the other. You can use the bucket belts with the bench as long as you don’t mind not having a lap belt for the middle seat. The bucket belts are the same as the 4-door XJ belts. The bench seat belts are also the same just with different plastic sleeves to hold them up above the bench, and the added lap belt. The lap belt bolts down with the same bolts as the female ends for driver and passenger belts. I don’t know if you’d be able to use the rear centre lap belt out of the xj or not, never looked too close. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 5, 2024 Share Posted September 5, 2024 27 minutes ago, gogmorgo said: I don’t know if you’d be able to use the rear centre lap belt out of the xj or not Nope. AMC put them on the same bracket for the rear on the XJ. They separated them for the MJ. Link to comment Share on other sites More sharing options...
gogmorgo Posted September 5, 2024 Share Posted September 5, 2024 1 hour ago, eaglescout526 said: Nope. AMC put them on the same bracket for the rear on the XJ. They separated them for the MJ. Yeah I was thinking there was something preventing that but I parted out my last xj too long ago to remember. But pretty well any generic/universal lap belt should work. Link to comment Share on other sites More sharing options...
HuntinHopin Posted September 6, 2024 Author Share Posted September 6, 2024 schardein-Buddy's is where we are headed. They have an MJ and two Cherokees. Hopefully we can find some things. Was the MJ pretty picked over? gogmorgo-thanks for bringing up the mistake in the title. I fixed it. We have a bench seat. Our biggest issues right now are electrical issues. He has headlights, brake lights, and emergency flashers. However, he has no turn signals, tail lights, or dash lights. So far, I have inspected and replaced fuses and cleaned up the ground behind the rear tail light. Also inspected bulbs and bulb housings to make sure they were all good. I switched the flasher relay and the turn signal relay with no change. However, there is quite a bit of play in the flasher relay when either of them are plugged in to that spot. Any suggestions on next step? Link to comment Share on other sites More sharing options...
Pete M Posted September 6, 2024 Share Posted September 6, 2024 keep in mind that 84-87 AMC belts don't click into 88+ chrysler belts, so you'll need the complete set of one or the other. Link to comment Share on other sites More sharing options...
schardein Posted September 7, 2024 Share Posted September 7, 2024 8 hours ago, HuntinHopin said: schardein-Buddy's is where we are headed. They have an MJ and two Cherokees. Hopefully we can find some things. Was the MJ pretty picked over? Pictures here. When I got there, it was missing the tail lights and tail gate. Just about everything else was there. Went back a week later and it was missing a few more things. Most of the interior is still there though. I grabbed the carpet panel from the back of the cab, so the B pillars are already removed (and not damaged), so the seatbelts should be really easy to get to. Link to comment Share on other sites More sharing options...
HuntinHopin Posted September 8, 2024 Author Share Posted September 8, 2024 Went today and was able to get just about everything we needed/wanted. The Comanche at Buddys was missing one of the male ends of the seatbelt but we were able to grab one off of a Cherokee. Wrong color but will work for now. We also grabbed an ash tray, glove box lock, oh crap handle, horn, and running light. Now if we could just get the darn lights figured out…to be continued I reckon. He’s chomping at the bits to drive this thing. Link to comment Share on other sites More sharing options...
