1990 shortbed with 2000 swap
  • Replies 57
1 hour ago, Salvagedcircuit said:
Teach me your ways  :drool:
Nice
Take your time and you too can make anything shine!
After the clear cures enough run up through the sanding grits, I went up to 2000 grit. Probably could have stopped at 1200 or 1500 grit honestly with how the Meguiars compounds worked out.
Then went to buffing. I used three compounds to cut, buff then polish.
No secrets here, Just elbow grease and patience!
Measured for shocks and started finalizing wire locations.
The truck came with some JK taillights, so am wiring them in with the correct JK connectors to keep it a plug and play on down the road when they may need replacement.
Backed the truck out to see the color in the sunshine.
  • 4 weeks later...
Time to start putting the interior together!
I took out the wires in the harness for the rear XJ doors. The way I figured it, The less wires, the less to go wrong down the line.
Also undid a "repair" to the cluster wiring and added more ground locations to keep it all well grounded.
Painted up the grill with some SEM trim paint for a nice pop of black.
Cleaned up the radio harness. Even though it would have hid behind the radio, I couldn't just leave a mess like that in there.
New MJ carpet, I went with the version with the extra mass backing to keep the cab quiet.
Tried on a set of Icon wheels with some 31s for kicks and giggles. Also picked up a JCR winch bumper off of marketplace.
Next the rear bumper and bed will be bedlined.
  • 2 months later...
I gave the bedliner from RE paint supply a shot. turned out very nice!
Also a thanks to my brother who plastic printed up a new set of tailgate alignment wedges, the tailgate closes nice and straight.
Will note I'm not a total fan of the JK taillight adapters that came with the truck, Looks like a rushed print job. had to glue them back together several times.
For what it is, if I were to do JK lights, I'd build a metal version.
Thanks boxyjeep, Thanks for  the complement! I've been ok with the JK lights, But I'd love to model a pair of your lights!
Now for a update pic, threw on some 31s to take it to get inspected. Boy do they look small with 7" of lift and notch flares.
Well it's true, The bushings on the rough country track bar are good for about 500 miles. You can see how they have deformed.
Changed them out for Moog 7252 bushings on both ends with 9/16" bolts.
Do recommend doing this to the RC track bar, Did help tighten up the steering.
Borrowed from A-man930 with his wheelwell liner idea. Picked up a roll of .070" plastic from Summit Racing.
Part number is AAF-ALL22400 for those who are wondering.
Little bit of CAD drawing with some paper, some heat gun action to bend it similar to the stock liner and just like that, one clean looking wheelwell.
Looks great! I'm betting the CAD made the fit up easier
1 hour ago, grainofsalt said:
ghetdjc320, There are some changes coming to how it sits.
No, Don't need that much wheel travel. Still doing shakedown on it, So far it's been doing real good.:L:
Sounds good :L:. Great color choice with the paint/rims combo. Truck looks great, just hadn't seen that much wheel arch opening as a final product and wondering if there were some plans in the works. Out of curiosity, how much space is there from the top of the tire to the bottom of there flare?
