23 – CPS timing advance mod
RENIX CPS ADVANCE MOD
The sensor portion of the CPS needs to slide up the perforated bar towards the top of the engine.
Mark the perforated bar’s top end with paint or marker.
Place the CPS in a vice,  just not quite clamping the bar, the sensor resting on the vice jaws, with the Top part protruding.
Place a bolt that fits tightly into the hole at the Top part of the bar.
With a hammer, tap the Top part of the bar and it will slide through the sensor portion of the CPS. Stop when the sensor portion is about 3/8″ from the edge of the bolt hole.
Revised 1-31-2016
  • 3 weeks later...
  • 6 months later...
19 minutes ago, garyweb3 said:
Found it. Thanks. I also noticed that the engine has timing marks on the front cover. Is the timing adjustable and if so what should it be?
No it’s not. Timing is controlled by the ECU and ICM.
I honestly have no idea if this mod will positively improve the 2.5L or not. I have yet to do this mod. Not sure if I want to really.
