Pete M Posted May 15, 2024 Share Posted May 15, 2024 so bastardizing two 2wd packs isn't getting me enough lift to match the front 3" coils , even with the longer shackle. what's everyone seeing out there that's affordable. hoping for sub-$150 for a long add-a-leaf, maybe? Link to comment Share on other sites More sharing options...
89 MJ Posted May 16, 2024 Share Posted May 16, 2024 Maybe see if marketplace has a 5” lift for an XJ. I added the main leaf from one of those with the eyes cut off for the lift in the rear of my MJ. It kept a similar rake to stock after my 3” front springs were installed. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted May 16, 2024 Share Posted May 16, 2024 I used some Iron Rock Off-road full length add a leafs for a XJ on my Eagle and was happy with them. I saw they have a 5.5 inch add a leaf that might work for what you want here is the link https://www.ironrockoffroad.com/product/iro-55-leaf-spring-add-a-leaf.html Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 16, 2024 Share Posted May 16, 2024 Spring over axle give you too much lift? Link to comment Share on other sites More sharing options...
coheed Posted May 16, 2024 Share Posted May 16, 2024 I have the add a leafs that got me to 3.5" with a shackle I'm not gonna use any more if you're interested. They're the full length ones from a zone off-road kit I got from @scguy a few years ago. I'd let them go cheap. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 17, 2024 Share Posted May 17, 2024 My MJ project is sitting on 3” front BDS coils and their full length MJ add a leaf. If you like the stance it would probably work for you. This was a 4 leaf 4wd pack before adding the 5th leaf. I had to redrill the center pin to match the MJ pack but that was no big deal. When I had my springs apart, I took the time to mix and match the left and right leaves to get me equal free arch on both. Driving with no passenger and a full tank had the left side sitting a bit lower than the right. Now they are back to even. It still has a slight rake but it’s down to about an inch. Last time a measured a factory rake it was about 2.25-2.5” Wish I had some better full stance shots but it’s exactly the stance I was looking for. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted May 17, 2024 Share Posted May 17, 2024 2 hours ago, ghetdjc320 said: My MJ project is sitting on 3” front BDS coils and their full length MJ add a leaf. If you like the stance it would probably work for you. This was a 4 leaf 4wd pack before adding the 5th leaf. I had to redrill the center pin to match the MJ pack but that was no big deal. When I had my springs apart, I took the time to mix and match the left and right leaves to get me equal free arch on both. Driving with no passenger and a full tank had the left side sitting a bit lower than the right. Now they are back to even. It still has a slight rake but it’s down to about an inch. Last time a measured a factory rake it was about 2.25-2.5” That might be the best solution but I couldn't find the add-a-leaf on BDS's website could you share a link? Link to comment Share on other sites More sharing options...
Pete M Posted May 17, 2024 Author Share Posted May 17, 2024 trying something outside the box. found a more generic long AAL that was on super-sale and we'll be trying that in a few days. it's designed to lift a fullsize truck 1.5" so it should work? Link to comment Share on other sites More sharing options...
Pete M Posted May 17, 2024 Author Share Posted May 17, 2024 On 5/16/2024 at 12:02 AM, TurboedMJ said: Spring over axle give you too much lift? yes. 5.5-6.5 is too much to match the front Link to comment Share on other sites More sharing options...
Pete M Posted May 17, 2024 Author Share Posted May 17, 2024 On 5/16/2024 at 7:09 AM, coheed said: I have the add a leafs that got me to 3.5" with a shackle I'm not gonna use any more if you're interested. They're the full length ones from a zone off-road kit I got from @scguy a few years ago. I'd let them go cheap. if this experiment falls through I'll be in touch. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 17, 2024 Share Posted May 17, 2024 BDS 114202. It’s a complete kit including center pin. Cheap too. They say it’s actually good for a 2.5” lift but not sure. Worked perfect with the 3” fronts though Link to comment Share on other sites More sharing options...
1999 MJ Posted May 18, 2024 Share Posted May 18, 2024 19 hours ago, ghetdjc320 said: What rear fender flares are those? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 18, 2024 Share Posted May 18, 2024 1 hour ago, 1999 MJ said: Those are notch flares. They were just sitting there for mock up. They’ll be installed later Link to comment Share on other sites More sharing options...
