AX-15 upgrades/other transmissions
I've been looking around the interwebs trying to find upgraded AX15s and/or good ways to make the transmission stronger. During my search, I found this:
https://speedtekautoracing.com/products/jeep-ax-5-close-ratio-uprated-1000nm-transmission-gearset
could anyone speak to the reliability of this website? I also discovered nitride treatment, which is basically heat treating everything and hope it holds (according to my calculations, max input should be around 4-500 hp). The reason I'm looking for upgrades is because I want to retain 4wd for traction during launch and I am not looking to run a divorced tcase. I also want a 5 SPD. I'm planning on building a high power 4.0 (north of 400hp NA, with a turbo coming later) and need something to put behind it.
On 2/16/2024 at 11:46 AM, TurboedMJ said:
After some research on this company Speedtek, it appears that they aren't the best to deal with, but the question remains. What's breaks first on this transmission?
From my research and some first hand experience: The stock gearset is plenty strong. If you need more torque handling the 2 main upgrades are the thrust washer and bearing retainer plate. 500ish HP an TQ have been run fairly reliably with those mods. If you need to speed shift and are mashing gears, then some upgraded shift forks are in order. There was a revision to the 5th gear synchro hub in later years. Main shafts have been broken occasionally and cryo treating may help but only under severe and repeated abuse.
Keep in mind that most of the “upgrades” are made for the Toyota R series and are compatible with the AX15.
Should all be possible, the Toyota R series transmissions were used in the Supra Turbo, and there are lots of people clearing 1000hp with those.  I am not quite sure where to point you with that tidbit of info, but undoubtedly there are people applying parts to build up those transmissions which should translate to the AX-15.
The R154 was in Supra's for certain years in the usdm. Many more years in the JDM. The AX15 will not hold that much torque though with spirited driving. There are many factors here like vehicle weight, axle ratio, and driving style. The NV3550 that later replaced the AX15 for a time was rated at 300lbft of torque with a gross vehicle weight of just over 7k pounds. The AX15 was not officially rated on torque but new units have been advertised as capable of 385lbft with no listed GVW. That torque number likely holds true for all the AX15 years.
There are new AX15s available from a few different suppliers. Advance adapters and Novak both offer to drill the tail housing to clock the tcase down a bit for XJ/MJ applications. Rockland standard gear also offers the “terminator” ax15, but it’s just a regular new ax15. All these companies advertise there units have the “latest revisions”. In my research, this has just been the 5th gear update which updates the synchro hub. That is not a strength upgrade just a functional upgrade.
Marlin crawler will do a quality rebuild with all the upgraded parts for around 1900. My concern with rebuilds has always been the quality of the bearings and synchros used in these kits. Lots of low quality hardware in the off the shelf kits. You can source some quality bearings separately though. I had an ax15 rebuilt (not by Marlin) with a crown kit. Lasted all of maybe 12 months with many issues behind a jeep stroker in a YJ. Second unit was just a used ax15 with 140k miles and it worked flawlessly. So i’d trust oem components more than any of those kits.
My current AX15 was original to my 90 MJ. I rebuilt the shifter, installed the newer style input shaft bearing plate for the external slave setup, and replaced the tail seal. Flushed with redline mt90 and refilled. That’s what’s in my LS swapped MJ now. I’m really not concerned about it holding up. If it does die at some point, I’ll rebuilt it with quality Japan made bearings and seals (since it’s a Japanese tranny) and add some upgraded parts from Marlin for the R151.
I agree with this, but I just wanted to throw out some food for thought. I know lots of Supras are drag raced, but I have no clue how many have the manual in them. How many of these 1000hp Supras have the traction to break parts though? If you can't put the power down, you're not going to be as hard on parts. I'd bet a Jeep doing 4 wheel drive launches or aggressive offroading would cause more damage. This is all purely guessing and food for thought.
15 minutes ago, TurboedMJ said:
I'm going to call Marlin Crawler and Novak tomorrow and ask about tailhousings and input shafts. Should be able to get some conclusive info.
What questions do you have? There is a huge knowledge base of people here who aren’t trying to sell you anything :L:
Haha. Just want to confirm some things. Basically an AX15 tailhousing and bellhousing can bolt on to any r series trans from Toyota? 150, 151, 154? And the Toyota input shaft will need changed to a jeep input shaft, correct? Lastly, what are the differences between the 150 and 151?
Yeah Marlin can probably answer that as it’s more of a Toyota tech question. The AX15 is basically an R151 and similar to the rest of the R series but not identical. Out of curiosity, why would you want to put an ax15 bellhousing on an r series tranny?
Sorry, should have clarified. I want to put a 4.0l bellhousing on an r series tranny. But if Marlin can rebuild my AX15 and have it hold a decent amount of power than I will just go that route.
Gotcha, there is no rated torque handling differences between the R151 and AX15. The R154 I suspect is the same in regards to torque handling but on a lightweight Supra making power at higher RPM’s it’s likely adequate.
I've been following a guy on Instagram who's swapping a 3UZ into his 3rd gen 4runner using a R150 and 35's. If the older 150 can handle the 3UZ's stock 330 ft/lbs while turning 35s I think you're on the right track.
  • 7 months later...
If you’re looking at the TR6060, checkout what speedtech engineering has been doing with the ax and r series with their gearsets. You can run custom ratios and have a 750ftlb+ rated tranny with custom ratio’s. Add that to the marlin upgrades and you easily have the ultimate r/ax series tranny that should outperform the tremec
I have seen them. Problem is I can't find much, if anything about them online. Only a couple threads from 2017 which are not positive. Does anyone on this forum have experience with them?
I’m not up on Toyota, or jeep for that matter even tho I’m building three. So what did you find out on what tranny is tough enough? Wanna have my ax15’s built to stand 500 hp and a lot of torque but not sure if it’s doable. Stuffing sbc and heavily modded. Building more of a mud or sand racers. Not a rock hopper.
The speedtek gearset should have higher torque handling than the tremec and they’ll mix ratios at your request. Combine that with the marlin mods and you’d have quite gearbox for a jeep. Someone has to be willing to try it… maybe that will be me :holdwrench:
I'd love to see it! I definitely won't be doing this for at least a year at this point so I'd love to see some other folks experiment in the mean time.
I may pull the trigger and go with the 3.4 1st gear set as I will be towing occasionally. I do believe though that I’ll grab at least the marlin parts and will post up what I find in my build thread. Also need to source a good quality rebuild kit. I plan on keeping my engine fairly stock aside from headers and intake along with some reliability items. I’m guessing somewhere right around 400 at the crank. I feel like axle gearing also plays quite a role in how the tranny holds up in real life situations.
