MississippiComanche Posted December 12, 2023 Posted December 12, 2023 Just thought I'd get to see if there are any write-ups for this before I get started this week. I searched the site and I couldn't find anything specific to the 2.5L.
89 MJ Posted December 12, 2023 Posted December 12, 2023 Not that I know of. What are you looking to find out about it?
eaglescout526 Posted December 12, 2023 Posted December 12, 2023 Ha! You aren’t removing that easily. You have to unbolt both manifolds at the same time, unbolt the pipe at the connection, unplug everything and remove the fuel lines(do this at the quick connect to save you some time) and then to separate and replace the exhaust manifold you have to unbolt the EGR tube and the two should be separated from each other. It’s not an easy job. Unless your manifold is trash, cracked and causing issues, drive it.
cruiser54 Posted December 12, 2023 Posted December 12, 2023 ^^ Yeah. Getting the bolts out is the easy part as they're usually broken off or missing.
MississippiComanche Posted December 12, 2023 Author Posted December 12, 2023 Yea the main motivation behind me wanting to do it is a suspected exhaust leak near the manifold. Sounds louder by the engine than it used to and I smell exhaust/gas in cab every time I run the truck. Just trying to identify all possible sources of the smell.
eaglescout526 Posted December 12, 2023 Posted December 12, 2023 I’d look at the rest of the exhaust before pulling that manifold first. Only because if you do pull it, you’ll be down the MJ for a day or two. Has the floor been repaired?
Salvagedcircuit Posted December 13, 2023 Posted December 13, 2023 This guy just did one on his comanche, but he is very much a novice with the 2.5 and is learning a bit here. https://www.youtube.com/watch?v=NtCUx2c4TJ4
gogmorgo Posted December 13, 2023 Posted December 13, 2023 You should be able to see cracks without pulling it off. If you just need to change the gasket you should be able to just unbolt the manifolds and move them away just far enough to scrape the gasket surfaces and slip in a new gasket, without disconnecting too much else. Unless the 2.5 intake is bolted to the power steering pump the way the 4.0’s is, I don’t remember, but that’s a few extra steps if that’s the case.
eaglescout526 Posted December 13, 2023 Posted December 13, 2023 9 hours ago, gogmorgo said: Unless the 2.5 intake is bolted to the power steering pump the way the 4.0’s is I spaced that, it is bolted to the manifold. And if there’s cracks on the exhaust manifold, it has a shield/heat exchanger on it, so you may not see the crack right away.
gogmorgo Posted December 13, 2023 Posted December 13, 2023 30 minutes ago, eaglescout526 said: I spaced that, it is bolted to the manifold. And if there’s cracks on the exhaust manifold, it has a shield/heat exchanger on it, so you may not see the crack right away. I don’t remember a heat shield on mine but that might be a ‘91 thing? I haven’t dug my 2.5 out from under the last couple dumps of snow yet or else I would have looked. Real advice, when you’re going for the manifold nuts, don’t be afraid to come at it from underneath. It really helps to see what you’re doing. Just don’t drop things on your face while you’re down there.
eaglescout526 Posted December 13, 2023 Posted December 13, 2023 10 minutes ago, gogmorgo said: 91 thing Might be Renix but I know the same manifold is used all the years including HO. But it’s got the heat exchanger for the air box.
mjeff87 Posted December 13, 2023 Posted December 13, 2023 Check the very rear of the manifold....the front and rear connectors are studs, not bolts. Odds are the rear one is snapped off. There's *just* enough room back there to get a right angle drill involved to remove the remains of the stud if it's snapped off flush (or down in the head).
eaglescout526 Posted December 13, 2023 Posted December 13, 2023 37 minutes ago, mjeff87 said: the front and rear connectors are studs, not bolts. I wish this was always the case. Both my 84 XJ and 88 MJ don’t have these studs but use bolts instead. So it’s likely a year change over thing in probably 89. Course you can upgrade to the studs though.
