eaglescout526 Posted October 11, 2023 Posted October 11, 2023 According to my paper catalog, secondary seal. But it’s door seal to prevent the rain from running down in that channel and causing rust to the hinges and what not.
cruiser54 Posted October 12, 2023 Posted October 12, 2023 That's mounted on the body, right? Not the door?
cruiser54 Posted October 12, 2023 Posted October 12, 2023 Nice catch. For clarification, I was referring to the diagram on the left's #5.
EUREKA Posted October 12, 2023 Author Posted October 12, 2023 I was also referring to the diagram on the left's #5
cruiser54 Posted October 12, 2023 Posted October 12, 2023 that one mounts on the A-pillar, correct? If so, there's a trick to cut down on drafts and wind noise. Get those pieces from a later model XJ. They're way more rigid and don't pucker along their length.
ghetdjc320 Posted October 14, 2023 Posted October 14, 2023 There was an aftermarket version of these available until maybe a couple of years ago. It was just some stock rubber material with that bend and some double sided adhesive tape. Worked well enough. Surely someone can find a similar piece of rubber stock
EUREKA Posted October 14, 2023 Author Posted October 14, 2023 On 10/12/2023 at 1:31 PM, cruiser54 said: that one mounts on the A-pillar, correct? If so, there's a trick to cut down on drafts and wind noise. Get those pieces from a later model XJ. They're way more rigid and don't pucker along their length. Yep that's the one.
EUREKA Posted October 14, 2023 Author Posted October 14, 2023 Looks like part numbers 55005012 is one side and 55005013 is the other. One of them on Ebay in Germany, https://www.ebay.com/itm/304438432959
91Pioneer Posted October 14, 2023 Posted October 14, 2023 I removed the driver one on my 89 and now I have a lot more wind noise. My door shuts badly so I took it off to see if it was causing the door closing issue, it was not. If I was you I'd grab one from the junkyard because it will be very cheap and if it's in good shape it's reusable. You could put some 2-sided tape on the back and use plastic rivets in the holes to put it back on if you want to be like the factory. Well that's how it was attached on mine.
EUREKA Posted October 14, 2023 Author Posted October 14, 2023 That's the response I get constantly, and I understand that I am in a rare situation but, I live 3 hours and 10 minutes drive (155 miles) from an auto wreckers. That's 6 hours 20 minutes rounds trip.
cruiser54 Posted October 15, 2023 Posted October 15, 2023 Can you order the late model ones anywhere?
ghetdjc320 Posted October 15, 2023 Posted October 15, 2023 3 hours ago, cruiser54 said: Can you order the late model ones anywhere? Not the latest versions, they are out of stock. Good info here on some options though:
cruiser54 Posted October 15, 2023 Posted October 15, 2023 On my 87 when I got it, the PO had sealed those wonky early style strips to the A pillar. There was way less noise than my 90 had. So, I added some trim screws to the warpy parts of the 90's weatherstrip flattening it out and it became much quieter.
EUREKA Posted October 15, 2023 Author Posted October 15, 2023 Looks like I'm going to have to rivet some small aluminum angle to the spot and install a piece of door seal on it. Or find some other weather strip with adhesive back that will do the job. I didn't see this one coming.
EUREKA Posted October 15, 2023 Author Posted October 15, 2023 Looks like I have one of them, not in the best shape. I might find the other one around here somewhere.
cruiser54 Posted October 15, 2023 Posted October 15, 2023 It's still pliable? I added trim screws in between the existing clips to flatten it out.
EUREKA Posted October 15, 2023 Author Posted October 15, 2023 Its a bit stiff but I have it in the sun right now. Trying to get it flattened out. I'm not finding the other one though.
ghetdjc320 Posted October 15, 2023 Posted October 15, 2023 A long soak in diesel worked really well for the ones in my truck
ghetdjc320 Posted October 16, 2023 Posted October 16, 2023 13 hours ago, cruiser54 said: and I thought I was a Redneck!! , “island hacks”. Whatever works
